流化床中化学链式反应,高温流体力学研究,PIV,速度场,速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共4种
下载方案
In the present work the effect of temperature on the hydrodynamic behavior of fluidized beds is experimentally studied with modern non-invasive experimental techniques. In particular, the development of a high temperature endoscopic Particle Image Velocimetry (PIV) is presented. An experimental set up has been designed and constructed that allows the study of hydrodynamics up to temperatures of 1000 oC, typical temperatures encountered in chemical looping gasification processes. First the endoscopic PIV results have been validated at low temperatures with a cold flow setup. Subsequently the application of the new technique to high temperature fluidized beds is presented and the obtained results discussed.
北京欧兰科技发展有限公司为您提供《流化床中化学链式反应,高温流体力学研究,PIV,速度场,速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中化学链式反应,高温流体力学研究,PIV,速度场,速度矢量场检测,参考标准《暂无》,《流化床中化学链式反应,高温流体力学研究,PIV,速度场,速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、自适应粒子成像测速场仪(PIV)、时间分辨粒子成像测速系统(TR-PIV)、内窥式粒子成像测速系统(Endo-PIV)。
我要纠错
