大尺度涡气旋中反气旋对称性检测方案
检测样品
其他
检测项目
反气旋对称性
关联设备
共2种
下载方案
We performed an experimental study of large-scale wakes in a rotating shallow-water layer.
Standard particle image velocimetry was used to measure the horizontal velocity field, while a
laser-induced fluorescence technique was used to measure the geopotential deviation i.e., the
interface deviation. According to these measurements, we were able to quantify the dynamics in a
wide region of parameter space beyond the quasi-geostrophic regime. For obstacles larger than the
deformation radius and with small Rossby numbers, a significant asymmetry occurs in the wake
between cyclonic and anticyclonic vortices. These parameters correspond to a frontal geostrophic
regime with the relative interface deviation being larger than 0.1–0.2. In this case, anticyclones
remain coherent and circular, whereas cyclones tend to be elongated and distorted. More
surprisingly, for some extreme cases, coherent cyclones do not emerge at all, and only an
anticyclonic vortex street appears several diameters behind the obstacle. The transition from a
quasi-geostrophic to a frontal geostrophic regime is characterized by a strong increase in the
Strouhal number, which can reach a value up to 0.6. Hence, we found that a large-scale wake could
differ strongly from the classical Karman street when the relative geopotential deviation becomes
larger than the Rossby number.
北京欧兰科技发展有限公司为您提供《大尺度涡气旋中反气旋对称性检测方案 》,该方案主要用于其他中反气旋对称性检测,参考标准《暂无》,《大尺度涡气旋中反气旋对称性检测方案 》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、自适应粒子成像测速场仪(PIV)。
我要纠错
