l流体中速度场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场
关联设备
共4种
下载方案
The motion tracking enhancement technique
(MTE) is a recently introduced method to improve the
accuracy of tomographic PIV measurements at seeding
density higher than currently practiced. The working
principle is based on the fact that the particle field and its
projections are correlated between the two exposures.
Therefore, information from subsequent exposures can be
shared within the tomographic reconstruction process of a
single object, which largely reduces the energy lost into
ghost particles. The study follows a previous work based
on synthetic particle images, showing that the MTE technique
has an effect similar to that of increasing the number
of cameras. In the present analysis, MTE is applied to
Tomographic PIV data from two time-resolved experiments
on turbulent shear flows: a round jet at Re = 5,000
(facq = 1,000 Hz) and a turbulent boundary layer at the
trailing edge of an airfoil (Rec = 370,000) measured at
12,000 Hz. The application of MTE is extended to the case
of more than two recordings. The performance is assessed
comparing the results from a lowered number of cameras
with respect to the full tomographic imaging system. The
analysis of the jet flow agrees with the findings of
numerical simulations provided the results are scaled taking
into account the concept of MTE efficiency based on
the volume fraction where ghost-pairs (Elsinga et al.
2010a) are produced.
北京欧兰科技发展有限公司为您提供《l流体中速度场检测方案(粒子图像测速)》,该方案主要用于其他中速度场检测,参考标准《暂无》,《l流体中速度场检测方案(粒子图像测速)》用到的仪器有体视层析粒子成像测速系统(Tomo-PIV)、自适应粒子成像测速场仪(PIV)、德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)。
我要纠错
