空气流动中流场,速度场,速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共4种
下载方案
The present feasibility study demonstrates flow field measurements on the suction side of an
airfoil in high-lift configuration under test in an industrial-grade wind tunnel using time-resolved
tomographic PIV. The influence of the parameters most relevant to tomographic PIV in industrial wind
tunnel environments has been studied. The successful application of this measurement technique takes a
significant step towards the necessary scale-up and toughening to bring tomo-PIV from laboratory-scale to
industrial application.
北京欧兰科技发展有限公司为您提供《空气流动中流场,速度场,速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中流场,速度场,速度矢量场,时间分辨速度矢量场检测,参考标准《暂无》,《空气流动中流场,速度场,速度矢量场,时间分辨速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、自适应粒子成像测速场仪(PIV)、时间分辨粒子成像测速系统(TR-PIV)、体视层析粒子成像测速系统(Tomo-PIV)。
我要纠错
