流体中速度场检测方案
检测样品
其他
检测项目
速度场
关联设备
共3种
下载方案
Turbulence of the round jet has been assessed using invariants
of the velocity gradient tensor. Experimental data, obtained
using Tomographic Particle Image Velocimetry (Tomo-PIV),
using four PCO-4000 cameras with 11 megapixel resolution,
is presented for a seeded free air jet, operating in the turbulent
regime and the Re number based on the diameter of the nozzle
is 10000. Using the acquired 3-D velocity fields, the local
statistical and geometrical structure of three-dimensional
turbulent flow can be described by properties of the velocity
gradient tensor. The invariants of the velocity gradient (R and
Q), rate-of-strain ( Rs andQs ), and rate-of-rotation (Qw )
tensors are analyzed across the turbulent expanding regions at
different distances from the nozzle outlet. More specifically,
the JPDF of invariants is computed, which allows a detailed
statistical characterization of the dynamics, geometry and
topology of the flow during the entrainment process. It should
be noted that the results obtained are indicative of the
preliminary work in this area.
北京欧兰科技发展有限公司为您提供《流体中速度场检测方案 》,该方案主要用于其他中速度场检测,参考标准《暂无》,《流体中速度场检测方案 》用到的仪器有自适应粒子成像测速场仪(PIV)、德国LaVision PIV/PLIF粒子成像测速场仪、体视层析粒子成像测速系统(Tomo-PIV)。
我要纠错
