上海通微分析技术有限公司Unimicro (Shanghai) Technologies Co., Ltd.苏州环球色谱有限责任公司GLOBAL CHROMATOGRAPHY CO..LTD.@HALO and Fused-Core are registered trademarks of Advanced Materials Technology, Inc.广州:020-29183493上海(全国):021-3895-3588 北京:010-82176650西安:029-89297872苏州:0512-68054587 HALC1Fused-Core@Particle Technology Application Note: 58-AM Isocratic Separation of Amphenicols on HALO RP-Amide PhaseHalo RP-Amide色谱柱快速分离酰胺醇类化合物 PEAKIDENTITIES: 1. Thiamphenicol(甲砜霉素)2. Chloramphenicol(氯霉素) TEST CONDITIONS: STRUCTURES: Column: 4.6x 50 mm, HALO RP-Amide Part Number:92814-406 Mobile Phase: 55/45-A/BA=0.025M Ammonium acetate buffer, pH=5.8B=AcetonitrileFlow Rate: 1.0 mL/min. CI NO2 Pressure: 92 Bar Temperature: 35 °C Detection: UV240/280 nm, VWD Injection Volume:0.5 pL Sample Solvent: Acetonitrile Response Time: 0.02 sec. Thiamphenicol Chloramphenicol Flow Cell: 2.5 pL semi-micro LC System: Shimadzu Prominence UFLC XR Extra column volume:~14 uL This separation shows a rapid HPLC method for the analysis of amphenicols using HALORP-Amide phase. To improve the sensitivity of detection the first peak was monitored @ 240 nm and the second @280 nm. www.advanced-materials-tech.com _0L 仪器信息网
关闭产品配置单
上海通微分析技术有限公司为您提供《上海通微快速分离药物中酰胺醇类抗生素(甲砜霉素和氯霉素)》,该方案主要用于其他中null检测,参考标准《暂无》,《上海通微快速分离药物中酰胺醇类抗生素(甲砜霉素和氯霉素)》用到的仪器有null。
