2012年12月第33卷第12期 纳诺仪器nano instrument刘敏敏,等:液相色谱-串联质谱法检测火锅底料中罂粟壳-92 液相色谱-串联质谱法检测火锅底料中罂粟壳 刘敏敏,张朝正,李延志,温家欣 (广东省药品检验所,广东广州510180) 摘 要:研究建立火锅底料中非法添加罂粟壳的液相色谱-串联质谱测定法。采用水提取,乙腈和无水醋酸钠萃取罂粟壳中的生物碱分,液质联用进行检测,采用色谱柱 SHISEIDO CAPCELL PAK CR1 :4 (5um,2.0x150mm)色谱分离,流动相为乙酸铵:乙腈(50:50),0.5%甲酸为A相,乙腈为流动相B相。该方法的检出限为 1 ng/mL,方法定量下限吗啡为 37 ug/kg,可待因、罂粟碱、蒂巴因和那可丁为1 ug/kg,线性范围为 1 ng/m~40 ng/mL,加标回收率64.2%~101.1%。该方法测定火锅底料罂粟碱中吗啡、可待因、罂粟碱、那可丁、蒂巴因5种生物碱的含量快速、准确,适合于火锅调味料食品中罂粟壳的检测。 关键词:罂粟壳;液质联用;火锅底料 Detection of Papaveris Pericarpium Added in Hot Foods Spice with LC-MS/MS LIU Min-min, ZHANG Chao-zheng, LI Yan-zhi, WEN Jia-xin (Guangdong Institute for Drug Control,Guangzhou 510180, Guangdong, China) Abstract: To establish a detection method (LC-MS/MS) for the determination of papaveris pericarpium addedin hot foods. Samples were prepared by water, and extract by acetonitrile and Sodium acetate ,alkaloidsresidues were detected by LC-MS/MS. Chromatographic separation was carried out on a SHISEIDO CAPCELLPAK CR1:4(5 pm,2.0x150 mm, the mobile phase A was acetonitrile: ammonium acetate (50:50), included0.1% formic acid water solution ,the mobile phase B was acetonitrile,with gradient elution. the limit ofmorphine's detection was 2.5 ng/mL and the limit of quantitation was 37 pg/kg, the others limit detection were0.1 ng/mL and the limit of quantitation was 1 pg/kg. the linear plots were obtained between 1 ng/mL-40 ng/mL.overall recoveries were between 64.2 %-101.1 %. The method was a simple, sensitive assay for the hot foodsinspection. Key words: papaveris pericarpium;LC-MS/MS; hot foods spice 火锅是我国老百姓比较喜爱的一种饮食,然而,近年来少数食品生产经营者为了招揽顾客,牟取暴利,在火锅及其调味料中添加罂粟壳及其水浸物等违禁原料,使食物味道鲜美。罂粟壳是罂粟科植物采完阿片后的干燥成熟果壳,内含吗啡 (morphine)、可待因(codeine)、罂粟碱 (papverine) 等多种生物碱"。因此添加了罂粟壳的食物易使消费者成瘾,长期食用者会对其产生依赖性。 目前,锅底料中非法添加罂粟壳的检测尚无标准检测方法。文献报道的方法主要有分光光度法、层析法、示波极谱法、高效液相色谱法、毛细管电泳和液- ( 作者简介:刘敏敏(1979 一 ),女(汉),主管药师,硕士研究生,研究方向:药品、保健食品、食品质量与安全。 ) 质联用法等2-3。本实验采用液相色谱-串联质谱技术,建设了火锅底料中非法添加的罂粟壳中吗啡、可待因、罂粟碱、蒂巴因、那可丁等5种生物碱成分 LC-MS/MS 检测方法,方法灵敏、准确,快速,适用于火锅调味料食品中罂粟壳的检测。 1材料与试药 1.1 仪器 液质联用色谱仪:美国热电公司,型号为 QuantumAccess MAX/600 PUMP;离心机:德国Eppendorf 公司,型号为X1R;超纯水发生器:美国Millipore 公司,型号为QA;电子分析天平:德国 SARTORIUS公司,型号为CP225D。 1.2访试剂与试药 磷酸可待因(批号:171203-201005,含量:99.6%)、吗啡(批号:171201-200822,含量:99.8%)、盐酸罂粟碱((批号:171214-200404);蒂巴因(批号:171216-200403);那可丁(批号:171224-200403):中国药品生物制品检定所提供;乙腈为色谱纯,其他试剂为分析纯。 1.3 样品 火锅底料均为2011年广东省餐饮食品监督抽检样品。 2 方法 2.1 分析条件 2.1.1 色谱条件 色谱柱为 SHISEIDO CAPCELL PAK CR1:4 (5 pum,2.0x150mm) ,50 mmol/L 乙酸铵:乙腈(50:50),0.5%甲酸为流动相A相,乙腈为流动相B相,流速0.3mL/min;按表1进行梯度洗脱。 表1 分离生物碱的最佳梯度洗脱表 Table 1COptimal elution condition for determination of alkaloidsresidues 时间/min A相/% B相/% 0 100 0 1.5 100 0 1.8 100 0 3.5 10 90 5 10 90 5.1 100 0 8 100 0 2.1.22质谱条件 以三重四极杆质谱仪作为检测器,电化学喷雾离子源,采集模式为正离子模式,质谱条件如下:喷雾电压:5500.0V;鞘气压力:525kPa;辅助气:6L/min;反吹气:0.6L/min。各化合物质谱参数见表2,总离子流见图1. 表2质谱参数表 Table 2 Parameter of Mass spectra of alkaloids residues 名称 去簇电压 定量离子对 碰撞能量 定性离 碰撞能量 (DP)/V (CE) /V 子对 (CE) /V 吗啡 65 286.0/165.3 37 286.0/181.3 37 可待因 60 300.0/152.0 62 300.0/155.0 31 300.0/164.9 36 300.0/214.9 23 蒂巴因 60 312.0/58.3 15 312.0/249.1 15 罂粟碱 65 340.0/202.2 25 340.0/171.1 33 那可丁 60 414.0/220.5 22 414.0/353.3 22 2.2 标准品溶液的制备 2.2.1 空白基质溶液 分别称取与待测样品基质相同的、不含所测成分 试样,按供试品溶液制备方法依法操作,制备空白基质溶液。 A.那可丁;B.罂粟碱;C.蒂巴因;D.可待因;E.吗啡。 图155种生物碱标准品的提取离子流谱图 Fig.1Extraction spectrum of five alkaloids residues 2.2.2 标准储备溶液 分别精密称取吗啡、可待因、罂粟碱、蒂巴因和那可丁标准品适量,用0.5%甲酸的甲醇溶液配制成1 mg/mL 的溶液,作为标准储备液。 2.3 样品的前处理 称取2g试样,于50 mL 聚四氟乙烯具塞离心管中,加入5 mL水,涡旋 1 min,再加入 15 mL 乙腈,涡旋1 min。超声提取 20 min 后,加入1.5g无水醋酸钠,再加入6g无水硫酸镁,涡旋1min,以 4000 r/min 的转速离心1 min,取出后待净化。称取 50 mgPSA,150 mg 无水硫酸镁置于2 mL 聚四氟乙烯具塞离心管中,用1mL微量移液器将上述上清液 1 mL移入此离心管中,涡旋 混合器涡旋 1 min,以5000 r/min 的转速离心1 min,移取上清液 0.5 mL于2mL离心管中,加入20 mmol/L乙酸铵溶液 0.5 mL,混匀,过 0.45 pm 微孔滤膜待测。 3结果 3.1线性范围 分别准确吸取上述标准储备液1.00 mL于 100 mL容量瓶中,用稀释溶剂(取空白基质溶液:20 mmol/L乙酸铵=50:50比例配制成稀释溶剂)定容至刻度。再准确吸取该溶液1.00 mL于200mL 容量瓶中,用稀释溶剂定容至刻度,制成标准使用液。分别准确吸取上述溶液1.00、1.00、1.00、1.00、2.00、4.00 mL于 50、20、10、5、5、5mL容量瓶中,用稀释溶剂稀释至刻度,制成浓度分别为1,2.5,5,10,20,40 ng mL溶液,作标准曲线,结果见表3。结果表明,5种物质在1 ng/mL~40 ng/mL范围内线性良好,相关系数均达 0.999。 表35种生物碱标准曲线 Table 3 the linear of alkaloids residues 名称 回归方程 线性范围/(ng/mI) 相关系数 吗啡 Y=2 676.8+16 134X 2.507 5~40.119 6 r= 0.999 0 可待因 Y = -7 773.5+23839X 1.002 0~40.0800 r= 0.999 9 罂粟碱 Y=65387+272 199X 0.996 0~39.8400 r=0.999 9 蒂巴因 Y=8 438.12+82 633X 1.0080~40.3200 r=1.0000 那可丁 Y=61764+236822X 1.017 0~40.6800 r= 0.998 9 3.2 检测限 以基线3倍噪声值计算方法检测限,测得可待因、罂粟碱、那可丁、蒂巴因的检出限为 0.1 ng/mL,吗啡的检测限为 2.5 ng/mL,按测定方法计算,本方法可待因、罂粟碱、那可丁、蒂巴因的检测限为 1 pg/kg;吗啡的检测限为37 pg/kg。 3.3 精密度试验 取浓度为 5 ng/mL 的基质标准溶液,连续进样6次,记录峰面积,结果表明,吗啡、可待因、罂粟碱、那可丁、蒂巴因6次进样峰面积的 RSD 值在0.8%~2.3%范围内,精密度良好。 3.4 加样回收率试验 取样品2g,分别加入不同浓度水平的标准品适量,照样品处理项下方法依法操作,计算回收率及相应RSD 值,结果见表4。结果表明,本方法回收率试验结果良好。 3.5 方法应用 应用本方法对2011年广东省餐饮食品监督抽检抽得的200批的火锅底料进行检测,共有5批样品检出多种罂粟壳类生物碱成分,添加了罂粟壳的火锅底 表4 回收率实验 (n=6) Table 4 Recovery of alkaloids residues (n=6) 成分 低浓度 高浓度 平均回收率/% RSD/% 平均回收率/% RSD/% 吗啡 59.0 0.1 64.2 1.0 可待因 76.3 1.3 68.1 1.5 罂粟碱 96.9 1.6 94.0 2.3 那可丁 102.8 1.6 101.1 0.8 蒂巴因 60.7 4.0 72.0 4.2 料占2.5%,结果见表5。 表5部分样品检出结果 Table5 Result of some samplesug/kg 序号 吗啡 可待因 罂粟碱 那可丁 蒂巴因 1 160.56 74.38 985.10 271.33 14.78 2 N.D. N.D. 160.54 47.18 N.D. 3 208.77 138.18 592.99 117.50 1.97 4 198.11 N.D. 5 N.D. 12.04 注:N.D.表示未检出。 4 讨论 1)火锅底料中罂粟壳的检测,现在尚无标准,有文献报道,可以参考农残检测的 QuECHERS 法进行提取。实际应用过程中发现该方法回收率低,吗啡的回收率仅为32.5%。生物碱在火锅底料中以盐的形式存在,本方法用水将火锅底料中罂粟壳中的生物碱提取出来,再用乙腈萃取,加无水醋酸钠促进生物碱由水相转移至有机相,最后用无水硫酸镁出去水相。实验表明,本方法大大提高了生物碱尤其是吗啡的回收率,满足了实验所需。 2)吗啡等生物碱为强极性化合物,有文献报道,用Cig柱进行色谱分离。笔者在实验中发现,吗啡等生物碱在 Cis柱上基本不保留,无法进行色谱分离。笔者也曾尝试采用文献报道的 ACQUITY UPLC BEH HILIC色谱柱4,这款正相柱具有重现性差,保留时间飘移严重,难以预平衡等特点,难以在基层实验室推广应用。本方法选择了强阳离子交换与反相 Cis 混合填料,混合比例(1:4)的色谱柱,该柱子克服了原方法的缺点,重现性好,保留时间稳定,容易平衡等特点,能有效分离吗啡等强极性的化合物。 ( 参考文献: ) ( [1]廖文娟,张虹, 任 一平.液相色谱-串联四级杆质谱法测定罂粟壳 主 要成分在止咳药中的含量J.分析化学,2006,34(8):1175-1178 ) ( [2 ] 汪芳芳,亮,曾爱明,等.食品中罂粟壳残留检测的研究现状[J]. ) β-环糊精增敏动力学光度法测定痕量硒 赵桦萍l,靳凤丹,肖忠峰 (1.齐齐哈尔大学化学与化工学院,黑龙江齐齐哈尔 161006;2.燕山大学环境与化学工程学院,河北秦皇岛066004;3.滨州学院化学与化工系,山东滨州256603) 摘 要:基于在硝酸介质中,β-环糊精对硒催化溴酸钾氧化罗丹明B的褪色反应具有增敏作用,建立了测定硒的催化动力学光度法,灵敏度较不加~环糊精的方法提高了2.5倍。测定硒的线性范围:0~40 u.g/L,检出限为 0.381 u.g/L,加标回收率为98.87%,6次测定的 RSD 小于5%。用于富硒大米中硒的测定,结果令人满意。 关键词:动力学光度法;β-环糊精;硒 Kinetic Spectrophotometric Determination of Trace Selenium with B-Cd as Sensitizer ZHAO Hua-ping',JIN Feng-dan丫,XIAO Zhong-feng (1.College of Chemistry and Chemical Engineering, Qiqihar University, Qiqihar 161006,Heilongjiang, China;2.College of Environmental and Chemical Engineering,Yanshan University,Qinhuangdao 066004,Hebei,China;3.Department of Chemistry and Chemical Engineering, Binzhou University, Binzhou 256603, Shandong, China) Abstract: A catalytic kinetic photometric method for determination of trace selenium(1V) with β-CD as sensiti-zer has been developed.The method is based on the fact that the color fading reaction of rhodamine B oxidizedby potassium bromate in dilute HNO3 solution is catalyzed by selenium (1V). The addition of β-CD increasesthe sensitivity of selenium by a factor of 2.5.The linear range for determination of selenium is 0-40 pg/L withdetec- tion limit of 0.381 ug/L.The recovery of standard addition is 98.87 % with precision of<5% RSD (n=6).The method has been applied to the determination of trace selenium (1V) in selenium rice with satisfactory re-sults. Key words: Catalytic Photometry;B-CD;selenium 硒是人体必需的微量元素,被称之为人体微量元素中的“防癌之王”。科学研究发现,血硒水平的高低与癌的发生息息相关。由于“硒”具有高抗氧化作用,人体适量补充硒能起到防止器官老化与病变,延缓衰老,增强免疫,抵御疾病,抵抗有毒害重金属的作用。缺硒是克山病、大骨节病的主要病因。“硒”是人体必 ( 作者简介:赵桦萍(1966 一 ),女(汉),教授,硕士,研究方向:光度分析。 ) ( 现代商贸工业,2009(3):279-280 ) ( [3] 张靖.食品中罂粟碱、吗啡、可待因含量的液相色谱法研究[].中 国卫生检验杂志,2007,17(1):72-73 ) ( [4] 王柯,郑荣,简龙海,等.火锅调料中5种生物碱成分的液相色谱- ) 需的,又不能自制,因此世界卫生组织建议每天补充200 ug硒可有效预防多种疾病的高发。 随着科学技术的发展和人类生活水平的提高,人们越来越重视硒与人类生活的关系,硒的分析也引起人们的关注。测定硒的含量有很多种方法,其中催化动力学光度法因具有仪器普及、操作简便、灵敏度高等特点而日益受到关注,这方面的研究工作近年来有较多的文献报道1-3,但以β-环糊精作为增敏剂催化动 ( 串联质谱测定法[J].中国卫生检验杂志,2011,21(2):363-365 ) ( [5 ] 刘艳琴,王浩,杨红梅,等.液相色谱-质谱联用技术测定食品中罂 粟碱残留[J].食品研究与开发,2010.31(7):130-132 ) ( 收稿日期:2012-04-14 ) ◎China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩2页未读,是否继续阅读?
上海纳锘实业有限公司为您提供《火锅底料中罂粟壳检测方案 》,该方案主要用于半固态复合调味料中非法添加检测,参考标准《暂无》,《火锅底料中罂粟壳检测方案 》用到的仪器有三重四极杆液质联用仪 LCMS-8030、LCMS-8050 三重四极杆超快速液质联用仪。
