CN 53-1211/G4 ISSN 1674 -5639昆明学院学报 2012, 34(3):23~27Journal of Kunming University 242012年6月昆明学院学报 镧离子掺杂类普鲁士蓝复合汞膜电极的制备及电分析测定铅 方 利,段德良,鲁建丽,吕政富,武云,曹秋娥,王家强 (云南大学化学科学与工程学院自然资源药物化学重点实验室,云南昆明650091) 摘要:在镧离子掺杂类普鲁士蓝(La-PB)修饰的玻碳电极表面电沉积汞膜,制备了一种新型化学修饰复合汞膜电极La-PB/MFE/GC;研究了修饰层厚度、镀汞方式和汞膜成长过程对复合汞膜形成的影响;并以 Pb²*为探针离子,对镧、钴离子掺杂类普鲁士蓝复合汞膜电极和常规玻碳汞膜电极的汞膜稳定性和金属离子的溶出伏安行为等进行了对比研究;同时,应用该电极结合示差脉冲阳极溶出伏安法对实际水样中微量 Pb²+的质量浓度进行了测定.结果表明,Pb²*在该复合汞膜电极上的阳极溶出氧化峰电流在4.82×10-9~4.82×10-mol/L 范围有良好的线性关系(r=0.9955,n=13),检出限为9.06×10-10 mol/L,RSD 值为2.6%,加标回收率为97%~102%.可用于实际样品的测定. 关键词:复合汞膜电极;类普鲁士蓝;镧离子掺杂;溶出分析特性;铅 中图分类号:0657.1;TQ460.72 文献标识码:A 文章编号:1674-5639(2012)03-0023-05 Preparation of the Composite Mercury Film Electrode Modified with PrussianBlue Analogue Doped with lanthanum Ion and its Electroanalysis of Lead FANG Li,DUAN De-liang,LU Jian-li,LU Zheng-fu,WU Yun, CAO Qiu-e, WANG Jia-qiang (Key Laboratory of Medicinal Chemistry for Natural Resource,School of Chemical Science and Technology, Yunnan University, Yunnan Kunming 650091,China) Abstract: A novel composite mercury film electrode modified with lanthanum-doped Prussian blue analogue(La-PB) (La-PB/MFE/GC) was prepared by electrodepositing mercury film on the La-PB film with glassy carbon electrode. The effect of La-PB film thick-ness, mercury electrodepositing mode and mercury film growing procedure for building composite mercury film electrode were dis-cussed. Mercury film’s stability and voltametric behavior were contrastively studied of La-PB/MFE/GC and MFE/GC using Pb+ asprobe ions. Using this electrode by anodic stripping differential pulse voltametre to determine trace Pb+. The area of peak current andlead(Ⅱ) concentration had a good linearity relationship in range of 4.82×10-—4.82×10-’mol/L (r=0.995 5,n=13), with de-tection limit was 9.06×10-10 mol/L(S/N=3) and RSD was 2.6% and recovery was 97%-102%. This method can be used to de-termine the concentration of lead for the real samples. Key words: chemical modified electrode; Prussian blue analogue; composite mercury film electrode; anodic stripping performance; lead 汞膜电极(MFE)对氢有较高的过电位、突出的电化学特性,迄今汞膜电极仍被广泛地应用在负电位区间的电位窗宽,可与许多金属生成汞齐等用于环境样品中定量检测痕量、超痕量重金属离子及有电氧化还原特性的生化物质质.玻碳汞膜电极(GC/MFE)或金属汞电电表表面上的汞常由于不同的分布状态,膜上负载的汞量会随着测定次数增加而损耗,影响测定数据的重复性和分析结果的重现性.尝试以不同的方法改进汞膜的组装,构建化学修饰型复合汞膜电极并用于痕量重金属的溶出法测定,以多核氰桥无机导电聚合物为内膜修饰层的复合汞膜电极是有效的手段之一.无机多核过渡金属氰桥化合物的类普鲁士蓝(PB)材料以其包含 [Fe(CN)]/ [Fe(CN)。]优良电子传递能力的氧化还原电子对,同 时有类似于有机聚合物的三维网状结构、化学稳定性好、制备简单和成本低的特点B-刀. 拟以玻璃碳基电极( GC)为基底,分别制备镧离子和钴离子掺杂类普鲁士蓝修饰的复合汞膜电极,并与直接在基底表面镀汞膜(GC/MFE) 对比,期能筛选出稳定性、灵敏度以及抗有机共存物污染能力得到明显改善,可应用于微量 Pb *测定的新型复合汞膜电极. 实验部分 1.1 仪器和试剂 1.1.1 仪器 检测采用三电极系统:对应选用GC/MFE、镧离子 ( 基金项目:云南省应用基础研究基金资助项目(2011FZ011) ) ( 作者简介:方利(1990一),男,江西吉安人,硕士研究生,主要从事电分析化学研究. ) ( 通讯作者:段德良(1971一),男,云南腾冲人,高级实验师,博士,主要从事电分析和电催化研究.E-mail: dlduan@ ynu. edu. cn ) 和钴离子掺杂类普鲁士蓝复合汞膜电极(GC/La -PB/MFE 和 GC/Co-PB/MFE)为工作电极;铂电极为对电极;Ag/AgCl(参比液为3.0 mol/L氯化钾)为参比电极. 1.1.2 试剂 硝酸、盐酸、硝酸镧(氧化镧质量分数在45%以上)、硝酸钴、铁氰化钾、邻苯二甲酸氢钾、氯化铁、氮气,其它所用试剂均为分析纯. Pb标准储备液:为4.82×10- mol/L;镀汞液:量取1.0 mL 的1×10-mol/L HgCl,,1.0 mL 的0.1 mol/L 的 KCl溶液,用0.10 mol/L NH Cl溶液稀释至50.0mL,且用0.1 mol/L HCl 调pH至2.0;修饰液:0.1 mol/L K,SO(pH=3.0)的硫酸钾溶液;封尾液:配置7.5 mL 0.1 mol/L KCl +1.0 mL 1.0×10-mol/L KSCN +0.5 mL 0. 1 mol/L HCl(pH=2.4)溶液,浸润时间8 min. 实验用水为超纯水;电解杯及所有玻璃杯均用超纯水洗净备用;每次电化学实验时,预通N,气5min 后再进行测量,所有实验均在室温下进行. 1.2 裸玻碳电极的预处理 裸玻碳电极以金相砂纸(W5(06),CW2000)上两次打磨后,再用超纯水浸泡、放入超声清洗器中超声3min 以上. 1.3 镧离子掺杂类普鲁士蓝复合汞膜电极的制备 以新配制的0.0l mol/L K,Fe( CN) 6 +0.01 mol/LFeCl,+0.01 mol/L邻苯二甲酸氢钾+0.02 mol/LLa*(称取硝酸镧样品0.2896 g)的混合溶液(V=20.0mL,pH=2.6)中,对预处理好的玻碳电极先行制备镧离子掺杂类普鲁士蓝底膜,即将电极置于溶液中,以50 mV/s的扫描速率于0~1.05V电位范围内扫描5圈成膜.再将该电极置入 0. 10 mol/LK,SO(pH=3.0)溶液中以50 mV/s 的扫描速率于0~1.05V电位范围内扫描,使氧化峰和还原峰的峰型更加尖锐且对称,氧化峰和还原峰的电位值彼此更加靠近,用水冲洗、晾干,即制备好La-PB底膜. 制备好 La-PB底膜在1.0mL 1×10-mol/LKSCN+7.5 mL 0. 1 mol/L KCl +0.5 mL 0.1 mol/LHCl(pH=2.4)混合溶液中(简称封尾液)浸润8 min 后,取出,晾干后待进一步镀汞. 1.4 镧离子掺杂类普鲁士蓝修饰电极镀汞过程的伏安行为 镀汞液预先通氮除氧,将该电极置于镀汞液中并保持氮气氛围,恒速搅拌,设定 CV 法的扫速速率为100mV/s,设定起始电位为0.3V,终止电位分别为-0.2,-0.4,-0.6V3个不同的电位区间,各区间内分别扫描10圈镀汞,使汞膜由慢到快逐步生成,制备具有一定厚度且表面呈银色金属光泽的汞膜.将该镀好汞的电极保存于超纯水中. 钴离子掺杂类普鲁士蓝底膜(Co-PB底膜)、封尾、镀汞以相似的方式进行. 1.5 伏安性能实验方法 移取10.0 mL 0. 10 mol/L 的 NHCl 溶液为底液置于电解杯中,以GC/La-PB/MFE 为工作电极,安装三电极系统,N气氛围下操作,设定富集电位 -1.0V,2000 r/min 搅拌富集60 s,静止120s.扫描范围-1.0~-0.1V,进行溶出伏安分析空白实验.标准系列准确加入一定浓度的Pb标准溶液,以相同的实验条件进行溶出伏安分析,以峰电流值和Pb²+浓度建立线形关系,实际样品以标准加入法测定计算铅的质量浓度. 新样品分析时,将工作电极放在0.010 mol/LHNO, 溶液中,于-0.1V处做120s氧化溶出预处理,消除镧离子掺杂类普鲁士蓝复合汞膜电极上的记忆效应.所有实验均在室温下进行. 2 结果与讨论 2.1 镧离子掺杂类普鲁士蓝复合汞膜电极的制备 如图1所示,玻碳电电表面电沉积La-PB 内膜时,其氧化峰电位为0.510V,还原峰电位为0.296V.而当玻炭电极表面电沉积 Co-PB 内膜时,氧化还原峰很弱(如下图2).结果表明,玻碳电极表面电沉积La-PB 内膜比电沉积 Co-PB 内膜容易得多,即镧离子掺杂类普鲁士蓝复合汞膜电极更易制备,且沉积效果更好. 图1 玻碳电极表面电沉积La-PB膜的循环伏安曲线 图22玻碳电极表面电沉积Co-PB膜的循环伏安曲线 2.2 镧离子掺杂类普鲁士蓝复合汞膜电极的硫酸钾活化 如下图3所示,GC/La -PB/MFE 电极在被0.1mol/L K,SO溶液(pH=3.0)活化后,其氧化峰电位 降低到0.272V,还原峰电位立降低到0.182V.经活化前后图像对比可知,氧化峰和还原峰的峰型更加尖锐且对称,氧化峰和还原峰的电位值彼此更加靠近.结果表明,GC/La-PB/MFE 电极经0.1mol/LK,SO溶液(pH=3.0)活化后变得更为灵敏且稳定;而GC/Co -PB/MFE 电极在经硫酸钾溶液活化后,变化很微小(如图4). 图33GC/La-PB/MFE在0.1 mol/LKSO溶液中的循环伏安曲线 图44GC/C0-PB/MFE在0.1 mol/L K2SO4溶液中的循环伏安曲线 2.3 镧离子掺杂类普鲁士蓝膜镀汞前的封尾作用 适量的镧离子掺杂类普鲁士蓝是电极制备成功的关键,使其包含的 [Fe( CN)]-/[Fe( CN)]优良电子传递能力体现出来, [Fe ( CN)。], [Fe(CN)。]4-, [Fe( SCN),]配离子的积累稳定常数分别为24.00,31.00和6.08,类普鲁士蓝膜表面的Fe与SCN配位降低表面的Fe量.参照文献区,8~9],选用1.0mL1×10- mol/L KSCN +7.5 mL0.1mol/L KCl +0.5 mL 0. 1 mol/L HCl(pH=2.4)混合溶液(简称封尾液),将修饰膜电极垂直浸润8min 后,取出于室温下晾干后镀汞.以SCN将未完全配位的铁离子配位结合以屏蔽铁离子与汞直接接触.参照文献[10],SCN具有改善汞膜的电化学性质.因此,本实验先将 GC/La-PB,GC/Co-PB内膜同样用SCN 的酸性溶液处理,可实现消除铁溶出峰的同时得到良好的、平坦的溶出基线. 2.4 镧离子掺杂类普鲁士蓝修饰电极还原扫描镀汞过程 将La-PB 膜修饰电极置于镀汞液中,其镀汞过程的还原扫描曲线如图5所示,在0.209,0.189,0.179V处的还原峰应为La-PB修饰电极上底膜修饰物的伏安响应,随着镀汞过程的进行,Hg*获得电子还原为金属Hg;随着扫描次数的增加,汞的沉积还原峰电流逐步增加,峰电位有少量的正移,表明在电沉积过程中底膜具有较好的导电性,且已开始有金属汞逐渐沉积成膜的现象.同时说明汞膜的不断增厚,内修饰膜已经逐步至完全被汞覆盖,形成了完整的复合汞膜. 图5 La-PB修饰电极预镀汞过程的还原扫描曲线 如下图6所示,在0.3~-0.2V和0.3~-0.4V电位范围的NP 曲线表明,Co-PB膜修饰电极镀汞过程中沉积还原峰增高趋势很弱小;而当电位区间扩展至0.3~-0.6Ⅴ时,随着扫描次数的增加,汞的沉积还原峰电流还会减小,说明汞膜没有在 Co-PB膜上呈增厚趋势,未形成完整的复合汞膜. 图6; Co-PB修饰电极预镀汞过程的还原扫描曲线 实验证明在裸玻碳电极表面上镀汞时成膜比较困难(如下图7)、沉积峰电流较小,在扫描时间足够长时,沉积峰电流才有明显增大现象,说明汞膜才有增厚趋势 电位/mV 图7 玻碳电极预镀汞过程的还原扫描曲线 2.5 铅离子在镧离子掺杂类普鲁士蓝复合汞膜电极上的伏安特性 2.5.1 Pb²标准溶液在 La-PB/MFE 上的溶出伏安特性 在最佳实验条件下,配制铅的标准溶液为4.82×10-5mol/L,在-0.1~-1.0V电位区间内,以50mV/s的扫描速度,进行不同浓度的 Pb²+的容出峰电流测定,如图8所示.以峰电流峰面积对 Pb的浓度作图,绘制工作曲线,如图9.结果表明,Pb²+的溶出峰面积与其浓度在4.82×10-~4.82×10-mol/L 范围内有良好的线性关系,线性回归方程为: Ia =0.843 2C+4×10-8,其相关系数r=0.995 5.以1.93×10-7mol/L Pb+为探针离子,对新制备的 GC/La-PB/MFE上的阳极溶出峰电流进行了10次平行测定,按3 倍信噪比计算方法的检出限为9.06×10-10 mol/L,RSD 值为2.6%,加标回收率为97%~102%. 图8 La-PB/MFE上铅的示差脉冲溶出伏安图 2.5.2 Pb标准溶液在 Co -PB/MFE 上的溶出伏安特性 在最佳实验条件下,配制铅的标准溶液为4.82×10-5mol/L,在-0.1~-1.0V电位区间内,以50 mV/s 的扫描速度,进行不同浓度的 Pb的溶出峰电流测定,如下图10所示.以峰电流面积对Pb²+的不同浓度作图,绘制工作曲线,如下图11.结果表明,Pb+的溶出峰电流峰面积与其浓度有良好 图9 La-PB/MFE上铅的溶出峰面积与Pb2+浓度的线性关系 的线性关系,线性回归方程为:Ia=0.0803C-4×10-10,其相关系数r=0.993 2. 图10(Co-PB/MFE上铅的示差脉冲溶出伏安图 图111Co-PB/MFE上铅的溶出峰面积与Pb2+浓度的线性关系 对比结果表明:在最佳的实验条件下,Pb²*在La-PB/MFE上的溶出峰电流在4.82×10-9~4.82×10-mol/L范围内比在Co -PB/MFE 上有更好的线性关系,且峰形更加对称.说明Pb标准溶液在La-PB/MFE 上有更好的溶出伏安特性. 2.6 不同工作电极制备的汞膜对 Pb*响应的灵敏度比较 以制备的 GC/La -PB/MFE(a),GC/Co -PB/MFE( b) 和GC/MFE(c)为工作电极,在选定的实验 条件下,对1.93×10- mol/L Pb进行阳极溶出伏安测定,并对比测定的峰电电(如图12),测出结果为Ia=4.52 pA,Ib=1.31 pA,Ic=1.33 uA. 说明在相同条件下,Pb²*在 GC/La-PB/MFE 电极上峰形尖锐,峰电流较大,灵敏最高,铅在电极上汞膜中的溶出扩散作用均匀.选定以GC/La-PB/MFE 为工作电极. 图12Pb2+分别在GC/La-PB/MFE(a), GC/Co-PB/MFE(b)和GC/MFE(c)上的示差脉冲阳极溶出伏安图 2.7 干扰实验 参照文献[11]设计实验条件,优化实验,测定2.00×10-mol/L 的 Pb²+受不同物质的干扰情况下,1000倍的 NaCl,Na,SO4,NH,Cl,NHNO,,(NH),SO4,KCl,K,SO,K,HPO,NaH,PO4,葡萄糖,蔗糖,十二烷基硫酸钠,β-环糊精不干扰测定;100倍的 CuSO,ZnSO不干扰测定.100倍的抗坏血酸有干扰. 2.8 实际样品中Pb的测定 分别取100.0 mL水样1(昆明盘龙江水)水样2(昆明滇池水)、水样3(昆明自来水)于200mL 石英烧杯中,参照文献[]方法处理样品,加入1.00mL 1 mol/L 硝酸和0.50 mL 0.010 mol/L 高锰酸钾溶液,置于电热板上加热至干,冷却,以0.10mol/L的 NH,Cl 溶液为底液稀释并定容于10.00 mL比色管,再按实验方法将其转移至电解杯中,通氮除氧,并保持氮气氛围,溶出伏安的测定以标准浓度测定相同的条件进行,标准加入法计算水样中 Pb+的质量浓度,结果见表1,结果为5次测定的平均值,RSD 为2.52%,并进行样品分析及回收实验.该方法应用于实际水水样 Pb+测定时,其它成分不干扰,干扰物质的质量浓度基本在干扰限以下,平均加标回收率为102.2%.实验测定结果与不同方法(原子吸收法)检测结果一致,适用于实际水样的测定. 表1 水样品中 Pb²+的测定结果 测定结果 加入量 加标回收率 RSD 原子吸收法 编号 测定结果 /(ug·L-l)/(ug·L-1) R/% /% /(pg·L-) 12.5 5.0 102.5 2.30 12.0 2 15.2 5.0 100.5 2.52 15.5 3 2.0 5.0 103.3 2.32 1.8 3 结语 本研究先修饰镧离子掺杂类普鲁士蓝底膜,经封尾液处理后晾干镀汞,即制得具有一定厚度且表面呈银色金属光泽的复合汞膜.实验结果得到: Pb-*在该复合汞膜电极上的阳极溶出峰电流在4.82×10-~4.82×10-mol/L 范围有良好的线性关系(r=0.995 5,n=13),检出限为9.06×10- mol/L,RSD 值为2.6%,加标回收率为97%~102%;说明镧离子掺杂类普鲁士蓝复合汞膜电极具有良好的灵敏度和重现性,使用寿命长;该电极上的溶出氧化过程主要受扩散控制,峰间电位差值与常规悬汞电极上Pb+的循环伏安测定结果相近,表明制备的复合汞膜电极对对 Pb²+溶出伏安响应较好,汞膜的致密度较高,可用于实际水样中 Pb+的分析测定.其电极稳定性、测量精密度和准确度适宜,方法具有快速、灵敏的优点. ( [参考文献] ) ( [1]刘年丰,涂一名,夏虹,等.高效液相色谱法测定油脂中抗氧化剂 BHA、TBHQ[.分析科学学报,2003,19(6):549-551. ) ( []中国林业科学研究院分析中心.现代实用仪器分析方法[M].北京:中国林业出版社,1994:104-105. ) ( 3]董绍俊,车广礼,谢远武.化学修饰电极[M].北京:科学出版社, 1995:267-274. ) ( [4]朱明霞,马永钧,康敬万,等.稀土掺杂普鲁士蓝化学修饰电极上过氧化氢的伏安性质研究.西北师范大学学报:自然科学版, 1998,34(3):38-40. ) ( []宋青云,马永钧,周敏,等.销离子掺杂类普鲁士蓝复合汞膜电极的制备及溶出分析特性[J].分析测试学报,2009,28(5),555 -559. ) ( [6]宋青云.电化学修饰销离子掺杂类普鲁士蓝复合汞膜电极的制备及电分析应用研究[D].兰州:西北师范大学,2007. ) ( [7]杨海青.新型复合铋膜阳极溶出伏安法在环境、食品及药物分析中的应用研究[D].兰州:西北师范大学,2010. ) ( [8] MONTERROSO S C C,CARAPUCA H M ,SIMAO J E J, et al.Opti- mization of mercury f ilm deposition on glassv carbon electrodes: eval-uation of th e combine d effects of pH,thioc y anate i on a nd depositionpotential [. Anal Chim Acta,2004,503( 1 ):203-2l2. ) ( [] CARAPUCA H M , MONTERROSO S C C,LUCIANA S,et al. Simul- taneous d etermination of c opper and l e ad i n seawater u s ing optimised thin-mercury f i lm e l ectrodes in s i tu p l ated i n thiocyanate me d ia []. Talanta,2004,64:566-569. ) ( [10] STADEN JF V,MATOETOE M C. Simultaneous det e rmination o f t races of iron ( Ⅱ) and iron( Ⅲ ) u si ng differential p ulse anodic stripping voltammetry i n a flow-through co n figuration on a gla s sy carbon electrode [. Ana l Chim Acta,1998,376(3):325-330. ) ( [11]武云,段德良,周群,等.氯霉素在羧基化单壁碳纳米管修饰电极上的电催化还原[J].昆明学院学报,2011,33(3),111 -114. ) ◎China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩3页未读,是否继续阅读?
瑞士万通中国有限公司为您提供《镧离子掺杂类普鲁士蓝复合汞膜电极的制备及电分析测定铅》,该方案主要用于其他中null检测,参考标准《暂无》,《镧离子掺杂类普鲁士蓝复合汞膜电极的制备及电分析测定铅》用到的仪器有null。
