HPLC DATASHEET 卜木八沙儿墟酸墟(日本薬局方記载条件)Donepezil hydrochloride (The Japanese Pharmacopoeia) F140312A (A) Standard solution* (0.4 pg/mL Donepezil hydrochloride) Column :YMC-Pack ODS-A (5pm,30 nm) 150 X4.6 mml.D. Eluentit : acetonitrile/water/perchloric acid (350/650/1) containing 2.5 g of sodium 1-decansulfonate Flow rate : 0.9 mL/min (adjust the flow rate so that the retention time of donepezil is about 11 min) Temperature :35℃ Detection : UV at 271 nm Injection :20pL (The Japanese Pharmacopoeia 16th;Assay, Related substances) laboratory use. WW 色谱条件见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《盐酸多奈哌齐中含量/有关物质检测方案(液相色谱柱)》,该方案主要用于其他中含量/有关物质检测,参考标准《暂无》,《盐酸多奈哌齐中含量/有关物质检测方案(液相色谱柱)》用到的仪器有null。
