HPLC DATA :SHEET"Standard solution was prepared from Valsartan supplied as a reagent for laboratory use 八儿廿儿夕沙·八儿廿儿夕锭(日本薬局方収載原案記載条件)Valsartan· Valsartan tablets (The draft for the Japanese Pharmacopoeia) D120111A Standard solution" Column :YMC-Triart C18 (5 um, 12 nm) 125 X3.0 mml.D.Eluent : acetonitrile/water/acetic acid (50/50/0.1)Flow rate : 0.45 mL/min (adjust the flow rate so that the retention time of valsartan is about 5 min)Temperature : 25℃Detection : UV at 225 nmInjection : 10 uL (The draft for the Japanese Pharmacopoeia;Assay) 仪器信息网 色谱条件详见谱图说明。
关闭产品配置单
深圳凯米斯科技有限公司为您提供《缬沙坦,缬沙坦片中含量检测方案(液相色谱柱)》,该方案主要用于原料药中含量测定检测,参考标准《暂无》,《缬沙坦,缬沙坦片中含量检测方案(液相色谱柱)》用到的仪器有null。
