HPLCDATASHEET 匕卜口牛沙夕口口牛少硫酸墟锭(米国薬局方記記条件) Hydroxychloroquine Sulfate Tablets (The United States Pharmacopeia) F140519B (A) Standard preparation (50 ug/mL Hydroxychloroquine sulfate) mAU 0 2 4 6 8 10 12 14 16 18 min (B)Resolution solution (50 pg/mL Hydroxychloroquine sulfate,50 pg/mL Chloroquine phosphate) mAU 3 System suitabilityrequirement Result Resolution (1,2) 21.8 5.3 min (The United States Pharmacopeia 37th; Assay) 色谱条件及系统适应性试验结果见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《硫酸羟氯喹片中含量检测方案(液相色谱柱)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《硫酸羟氯喹片中含量检测方案(液相色谱柱)》用到的仪器有null。
