HPLC DATA SHEET 匕才外夕少少墟酸墟锭Pioglitazone hydrochloride tablets U100927B A)Assay: Sample solution (0.05 mg/mL Pioglitazone HCI, 0.013 mg/mL Benzophenone) mAU 140, 1 120 1 100 80 60 2 HyC 40 ·HCi 20 0 Pioglitazone hydrochloride 0 2 6 10 U100916C !有技B) Organic Impurities: Sample solution*科斯 com (0.18 mg/mL Pioglitazone HCI) 2 0 Benzophenone * Sample solutions were prepared from Pioglitazone HCl tablets. Column : YMC-Triart C18 (5 um, 12 nm) 150X4.6mml.D. Eluent :acetonitrile/100 mM CHgCOONHa/acetic acid (25/25/1) Flow rate :0.8 mL/min Temperature :25℃ Detection : UV at 269 nm Injection :A) 20 pL B) 40 pL 息网 at. comr.cn 色谱条件见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《盐酸吡格列酮片中含量/有关物质检测方案(液相色谱柱)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《盐酸吡格列酮片中含量/有关物质检测方案(液相色谱柱)》用到的仪器有null。
