当前位置: 柴油 > 方案详情
柴油和加热油中总硫含量检测方案
检测样品 柴油
检测项目 总硫含量
关联设备 共1种 下载方案
方案详情
multi EA 系列元素分析仪集多个模块于一身,可用来检测固体,液体,粘稠性物体、液化气和气体中的硫,氮,碳,氯含量,由于它的革新技术,multi EA系列仪器有广泛的应用领域,并且具有很强的适用性和灵活性,是各行业高效的检测工具。
analytikjena analytikjena Short Application multi EA SeriesDetermination of Sulfur in Diesel Oil / Heating Oil Introduction In order to ensure adherence with the statutory limit values (German ordinance relating to thesulphur content of certain liquid fuels - 3. BlmSchV), there must be stringent controls of dieselused for heating purposes. The upper limit value of 200 mg/kg stipulated for low sulphur and 50mg/kg for sulphur-free extra light heating oil must not be exceeded, as the sulphur leads todamage of the boiler as well as to a considerable burden on the environment (acid rain). Sample preparation and analysis An analyzer of the multi EA Series was used with multi matrix sampler for the tests in thehorizontal operation mode. The samples to be tested were diluted with a suitable nitrogen-freesolvent (e.g. iso octane) before the analysis due to their high viscosity. The dilutions so createdwere injected into quartz boats with the aid of the autosampler. Afterwards the boats were fed intothe combustion system by means of the automatic boat drive. Thereby the fed speed is controlledby the flame sensor. The quantitative thermal decomposition was done in a two-phase process.The nitrogen content of the samples was determined with the help of a UV fluorescence detector. Method Parameters The method TS_hori_liquid of the standard method library was used for analyzing. Prior to the actual determination of the sulfur content, the system was calibrated using standardsolutions (dibenzothiophene in iso octane). Results Sample Cs [mg/kg] SD [mg/kg] RSD [%] Sam_1 105 0.7 0.7 Sam_2 199 1.7 0.9 Sam_3 221 1.7 0.8 Sam_4 304 1.6 0.5 Sam_5 312 1.1 0.4 Summary The horizontal operation mode of the analyzers of the multi EA Series are outstandingly suited forthe determination of higher sulfur contents in petrochemical samples. The multi-matrix samplerallows an optimal adjustment of the sample introduction to the requirements of the matrix to beanalyzed. During parallel operation of a chemoluminescence detector the nitrogen content can bedetermined simultaneously. Moreover, the application spectrum can be expanded with additionalaccessory modules to include the parameters chlorine and carbon. Expression and further use with indication of source permit. C2005 Analytik Jena AG Publisher: Analytik Jena AG07745 JenaKonrad-Zuse-StraBe 1Germany Phone +49 (0) 3641/77-70Fax +49 (0)3641/77-92 79 Determination of Sulfur in Diesel Oil / Heating OilReference No.: EA S |GRO/
关闭
  • 1/3
  • 2/3
还剩1页未读,是否继续阅读?
继续免费阅读全文
产品配置单
耶拿分析仪器(北京)有限公司为您提供《柴油和加热油中总硫含量检测方案 》,该方案主要用于柴油中总硫含量检测,参考标准《暂无》,《柴油和加热油中总硫含量检测方案 》用到的仪器有multi EA® 5000碳、氮、硫、氯 元素分析仪 。
我要纠错
推荐专场
相关方案
