深圳市高比科技有限公司联系人:水先生 电话:13810737909邮箱:water1102@163.com 网址:: www.globetechchina.com·277· 2 ( 期妇女使用该药抗感染时应暂停哺乳。 ) ( 参考文献 ) ( 1 Dai Zi-ying(戴自英). Cl i nical Antimicrobial Drugs(临床抗菌药物学). Beijing(北京 ) : People ’ s Medical Publ i shing House(人民卫生出版社),1985. 37 ( in Chinese) ) ( 2 YANG Yang(杨 阳 ). Tin i dazole ( 替 硝唑). Chin Pharmacol Bull ) ( (中国药理学通报),1994, 1 0 (5): 386 ( in Chinese) ) ( 3 Jager RE. Ph a rmacokinetics and tissus distribution of m et r onidazole in the newborn infant. Obstet Gynecol Suru , 1983, 38 ( 3): 155 ) ( 4 Erickson SH, Oppenheim GL, Smith GH. Metronidazole in b re a st milk. Obstet Gynecol, 1981, 57(1):48 ) ( (本文于2001年9月3日收到) ) 毛细管气相色谱法测定萘哌地尔中的残留溶剂 王岩 朱维华 俞如英 (中国药品生物制品检定所 北京京100050) 摘要 目的:建立气相色谱法分离测定萘哌地尔中的残留溶剂:乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷。方法:以RX-5弹性石英毛细管柱为色谱柱(25 mx0.32mm), 载气为氮气,采用氢离子火焰检测器,进样口温度为220℃, 检测器为280℃,柱温采用程序升温,(60℃,保持4 min, 以10℃·min升至100℃,并保持1 min, 再以25℃·min'升至220℃保持6 min), 以二甲基亚砜为溶剂,进样量1pL。结果:乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷的的进样量分别在25~400 ng, 其峰面积与浓度呈良好的线性关系,加样回收率(n=5)分别为99.47% (RSD <0.76%), 99.03%(RSD <1.4%), 97.91% (RSD<1.4%), 97.90% (RSD <1.4%), 98.02 (RSD<1.4%), 精密度良好。结论:本文气相色谱条件可用于同时测定萘哌地尔中乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷的含量,方法简单准确。 关键词 气相色谱法 乙醇 乙酸乙酯 氯仿 正丁醇 环氧氯丙烷萘哌地尔 GC Determination of Residual Solvents in Nafetoil WANG Yan, ZHU Wei -hua and YU Ru -ying (National Institute for the Control of Pharmaceutical and Biological Products, Beijing 100050) AbstractObjective: This paper reports a GC method for determination of ethanol, ethyl acetate, chloroform, n- butanol and epichlorohydrin in nafetoil by GC. Method: Using a column RX -5, the column length was 25 mx0.32 mm. The injector temperature is 210℃. The detector temperature is 280 ℃. The column temperature is10℃·min 25℃·minprogrammed raiced [60℃ (4 min) -100℃(1min) -→220℃ (6 min)]. The carri-er gas is nitrogen. The solvent was dimethyl sulfoxide. Results: The standard curves are linear for ethanol, ethylacetate, chloroform, n-butanol, epichlorohydrin in the range of 25 ~ 400 ng. The average recoveries (n=5)are 99.5%(RSD<0.76%) for ethanol, 99.0%(RSD <1.4%) for ethyl acetate, 97.9%(RSD<1.4%)for chloroform, 97.9% (RSD<1.4%) for n -butanol, 98.0% (RSD<1.4%) for epichlorohydrin, respec-tively. Conclusion: This method is simple, rapid and precision. Key wordsGC, nafetoil, ethanol, ethyl acetate, chloroform, n-butanol, epichlorohydrin 萘哌地尔,是抗高血压药。生产需进行残留溶剂氯仿、正丁醇、环氧氯丙烷的测定。我们经过多次试验,采用RX-5弹性石英毛细管柱为色谱柱(25 m×0.32 mm), 进样口温度为220℃,检测器为280℃,柱温采取程序升温,载气为氮气,以二甲基亚砜为溶剂,可同时分离测定萘哌地尔中的残留溶剂:乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷。本文的测定方法符合中国药典2000年版中 “有机残留溶剂”测定的有关规定,各组分的分离度均符合要求,操作简便,结果准确可靠。 仪器与试药 GC-14A气相色谱仪,日本岛津公司生产。 乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷、:二甲基亚砜均为分析纯。 样品为萘哌地尔原料药(批号为990601,990701,990801)及其对照品,由贵州益康制药有 限公司提供。 标准储备液的制备:精密称取乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷适量,分别置于量瓶中,用二甲基亚砜配制成每1mL中约含乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷各 10 mg 的溶液,作为标准储备液。 2 试验方法与结果 2.1 色谱条件 色谱柱: HP RX-5性性石英毛细管柱(25mx0.32mm),载气为氮气,采用氢离子火焰检测器,进样口温度为220℃,检测器为280℃,柱温采取程序升温,即初始为60℃,保持4 min,以10℃·min升至100℃,并保持1min, 再以25℃·min升至220℃保持6 min, 进样量为1pL。 2.2 分离度试验 分别量取标准储备液置于同一量瓶中,用二甲基亚砜稀释制成成1mL约含乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷各0.1 mg的溶液,进样1pL,按上述色谱条件试验,记录色谱图,见图1-A,乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷的保留时间分别为1.3, 2.9,3. 1, 3.9, 5.3 min。其分离度均符合规定。 图1 残留溶剂对照品(A)及样品(B)色谱图 Fig 1 GC chromatograms of reference substance ofreaidual solvent in nafetoil (A) and sample (B) 1. 乙醇 (ethanol) 2.乙酸乙酯(ethyl acetate)3.氯仿(chioroform) 4.正丁醇(n-butanol)5.环氧氯丙烷 (epichlorohydrin)6.二甲基亚砜 (dimethyl sulfoxide) 2.3 线性范围及标准曲线 分别精密量取乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷的标准储备液0.25,0.5,1.0,2.0,4.0mL,分别置于100mL量瓶中,加二甲基亚砜稀释至刻度,摇匀。取上述溶液分别进样1pL,以残留溶剂的浓度C(mg·mL)对峰面积A线性回归。残留溶剂乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷在25~400 ng范围内,线性良好,回归方程分别为: A=-176.0+467.2C r=0.9999 A=-136.6+322.7Cr=0.999 9 2.4 精密度试验 用乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷浓度为0.1 mg·mL的溶液,重复进样5次,结果乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷的 RSD 分别为0.87%, 0.84%,0.32%,0.46%,1.1%,精密度良好。 2.5 回收率试验 称取同一批号原料药样品约0.5g共5份,精密加入乙醇1mL、乙酸乙酯0.8mL、氯仿0.6 mL、正丁醇0.4 mL、环氧氯丙烷0.2mL,各样品品依精密度试验项下测定方法,测定对照品含量,计算平均回收率(n=5)分别为99.47%,99.03%,97.91%,97.90%,98.02%;RSD 分别为0.76%,1.4%,1.4%,1.4%,1.4%。 2.6 样品测定 取乙醇、乙酸乙酯、氯仿、正丁醇、环氧氯丙烷标准储备液各1.0mL, 置于10 mL量瓶中,加二甲基亚砜稀释至刻度,摇匀,作为残留溶剂对照品溶液;称取萘哌地尔样品(原料药及其对照品)各约1.0 g,分别置 10 mL量瓶中,加二甲基亚砜溶解,并稀释至刻度,摇匀,作为样品溶液;分别量取上述溶液各1uL, 注入气相色谱仪,按上述色谱条件测定,以外标法按峰面积计算,990601,990701,990801号萘哌地尔原料药及其对照品中乙醇量分别为0.31%,0.46%,0.35%,0.32%;乙酸乙酯、氯仿、正丁醇、环氧氯丙烷量均小于0.01%, n=3。 3 讨论 本法与原厂方方法相比,方法更简便,条件普及,有利于对样品质量的控制。 原厂方标准采用甲醇和苯2种溶剂,分2个系统进行测定。样品本身易溶于氯仿,不溶于水,微溶于甲醇,极微溶于苯,由于苯为有毒溶剂,对人体危害较大,经对多种不同溶剂筛选,选定二甲基亚砜为溶剂,样品易溶于二甲基亚砜,同时样品中各组分的分离度符合定量分析的要求。 ( 参考文献 ) ( 1( ChP(中国药典). 2000. V ol (二部): Appendi x (附录)MP ) ( (本文于2002年4月12日修改回) )
关闭产品配置单
深圳市高比科技有限公司为您提供《化学药中主要物质含量分析检测方案 》,该方案主要用于化药制剂中限度检查检测,参考标准《暂无》,《化学药中主要物质含量分析检测方案 》用到的仪器有null。
