HPLC DATA'SHEETU110215A 八口丰乜千沙锭 Paroxetine tablets A) Standard solution* (0.1 mg/mL Paroxetine hydrochloride) B)Assay solution* (0.1 mg/mL Paroxetine hydrochloride) mAU Paroxetine 35.0- 30.0- 25.0- 20.0 15.0- 10.0- Paroxetine hydrochloride 5.0 0.0 U110210C 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 min Column :YMC-Pack Pro C8 (3 um, 12 nm) *Standard solution was prepared from Paroxetine HCI supplied as a reagent for laboratory use.Assay solution was prepared from Paroxetine HCI tablets. 色谱条件见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《盐酸帕罗西汀片中主要物质含量分析检测方案(液相色谱柱)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《盐酸帕罗西汀片中主要物质含量分析检测方案(液相色谱柱)》用到的仪器有null。
