安徽农业科学,Joumal of AnhuiAgri Sci 2010,38(9):4792-4793,4822责任编辑 朱新秀 责任校对 卢瑶 479338卷9期陈利梅等 不同生产日期山楂罐头的电子鼻检测研究 不同生产日期山楂罐头的电子鼻检测研究 陈利梅,李德茂,:,马淑凤2.3 (1.城城大学食品科学与工程系,山东聊城252059;2.食品科学与技术国家重点实验室,江南大学,江苏无锡214122;3.江南大学食品学院,江苏无锡214122) 摘要 [目的]探索电子鼻对不同生产日期山楂罐头风味变化的响应情况。[方法]采用电子鼻技术对不同生产日期的山楂罐头进行识别,并对所获得数据进行了主成分分析(PCA)线性判别法(LDA)和 Loading法分析。[结果]随着山楂罐头货架期的延长,山楂罐头的气味发生变化,电子鼻能够识别这种变化,并能将不同生产日期的山楂罐头区分开来,而且气味的变化与时间呈一定的线性关系。电子鼻2号传感器对第1主成分贡献率最大,4、6号传感器对第2主成分贡献率大大。研究还选取了3种不同生产日期的山楂罐头进行区分,发现电子鼻能够识别未知的样品。[结论]可以将电子鼻用于山楂罐头新鲜度的检测中。 关键词 电子鼻;山楂罐头;主成分分析法;线性判别法;Loading分析 中图分类号 TS295.6 文献标识码 A 文章编号 0517-6611(2010)09-04792-02 Research on the Detection of the Hawthorn Can with D ifferent Production Date w ith Electron ic Nose CHENLimei etal (Department of Food Science, Liaocheng University, Liaocheng, Shandong 252059) Abstract[[(Objective] The response of the electronic nose to the flavor change of the Haw thom Can product with different production datewas investigated through the experment [Method] The products of Haw thom Can were characterized and classified by means of the detectionof an electronic nose (PEN3). And the testing data was analyzed with the method of principal component analysis(PCA), linear discriminationanalysis(LDA) and Loading analysis[Result] The results indicated that electronic nose was able to identify the flavor change of the Haw-thom Can product because of the shelf life-extending and to distinguish them. There was a linear relation between the time and flavor The sec-ond sensor of the electronic nose played a main role in the first ma in component and the forth and sixth sensor of the electronic nose played amain role in the second main component It was showed that the electronic nose could identify unknown Haw thom Can [Conclusion] The e-lectronic nose could be used in the detection of the fre shness of Haw tho rn Can Key words Electronic nose; Haw thorn Can; Principal component analysis; Linear discrim ination analysis; Loading analysis 食品的气味是食品新鲜度的重要指标之一。常采用的气味感官鉴定方法主观性强,重复性差,受个体差异的影响较大,无统一的标准,而且容易出现嗅觉疲劳。而利用一些常规仪器进行气味检测,例如利用气相色谱、气质联用、电化学等检测方法,存在费时、检测费用高、无法与人的嗅觉系统进行比较等缺点。因此,需要一种能模仿人的嗅觉系统,并能够采用科学的方法进行数据采集和数据处理的仪器来检测气味物质,以保证检测快速、有效和客观。 电子鼻最早是在1982年由英国 Wawick大学的 Persaud和Dodd模哺乳动物嗅觉系统的结构和机理提出的。它的工作原理类似人的鼻子,是由一定选择性的电化学传感器阵列和适当的模式识别系统组成,能够识别简单和复杂气味,故称之为“电子鼻”。电子鼻技术具有检测速度快、操作简单、灵敏度高、重现性好等优点,为食品行业颇具开发潜力的检测仪器。目前电子鼻在果蔬成熟度检测、肉品检测21酒类鉴别3、茶叶审评4、香精识别、谷物储藏害虫的检测16饮料识别、乳制品检测等食品领域得到了应用。 笔者采用电子鼻技术对不同生产日期的山楂罐头进行辨别,探索电子鼻对不同生产日期山楂罐头的风味变化响应情况,为山楂罐头的检测提供参考。 1 材料与方法 1.11试验材料 1.1.1材料。某品牌不同生产日期的瓶装山楂罐头,采购自聊城某超市,产品净含量为460 g,固形物不低于40%。配 ( 作者简介 陈利梅(1977-),女,河北唐山人,硕士,讲师,从事农产品贮藏与加工方面的教研工作。*通讯作者,博士,讲师, Email: d emaoli@ g mail c om。 ) ( 收稿日期 2009-12-22 ) 料为:山楂、饮用水、白砂糖、柠檬酸、D异抗坏血酸、阿斯巴甜(含苯丙氨酸)、胭脂红。其生产日期分别为2009年的1月10日、4月25日、5月25日、7月10日和8月2日,试验编号为 G1、G2、G3、G4、G5。每一生产日期产品设3个重复。 l.1.2 仪器。德国 ARSENSE公司 PEN3型便携式电子鼻系统,由北京盈盛恒泰科技有限责任公司提供。 1.2试验方法 PEN3便携式电子鼻系统含有10个不同的传感器,置于一个小的传感器舱中。试验时,将体积约为250ml的罐头瓶与系统联用,样品置于罐头瓶中,用保鲜膜密封,然后用一个带扣的针头连接在特氟纶管上(3mm直径)直接插入到罐头瓶中,用第2个针连接背面的木炭过滤器,通过特氟纶管将零气吸入电子鼻。该试验中电子鼻信号的采集时间定为60 s. 1.3 数据分析 笔者采用的主要分析方法有:主成分分析法(PCA)、线性判别法(LDA)和负荷加载分析法 (Loadings)。 2 结果与分析 21 电子鼻对山楂罐头气味的响应 对每个生产日期的3个山楂罐头进行电子鼻检测分析。测量山楂罐头的气味获得了电子鼻10个传感器的响应图(图1)。图1中,每一个曲线代表一个传感器,曲线上的点代表着山楂罐头的气味物质通过传感器通道时,相对电阻率(G/G)随进样时间的变化情况。由图1可看出,从进样初到最后样品气体的平稳过程中,相对电阻率快速增加,然后趋于平缓。由图1还可知,电子鼻对山楂罐头的气味有明显的响应,每一个响应值各不相同,而且传感器2、6、8比其他传感器有更高的相对响应值(电阻率值)。这表明利用电子鼻 PEN3系统测量不同生产日期的山楂罐头是可行的。 22 PCA法分析不同生产日期的山楂罐头 图2是用PCA方法分析电子鼻与山楂罐头的关系图(总贡献率为 图1 电子鼻检测山楂罐头的信号 Fig1 The respon se graph of the sen sors to the flavors of haw- thorn can 98.25%)。图2中,沿着横坐标(主轴1)看,不同生产日期的山楂罐头分布呈一定变化趋势;而沿沿纵标(主轴2)看,编号为 G4的山楂罐头区别了其他编号的山楂头。综合两坐标,不同生产日期的山楂罐头基本上可以在 PCA分析图上定出相应的位置。即采用 PCA分析,经软件分级优化后,能够完全区分不同生产日期的5组山楂罐头。 Main shaft 1(contribution rate: 96. 37%) 图2不同生产日期的山楂罐头与电子鼻响应信号关系的PCA分析 Fig 2 The PCA analysis of the rela tion sh ip between differentshelf time and the sen sors respon se 233用LDA方法分析不同生产日期的山楂罐头 图3为 不同生产日期山楂罐头的LDA分析图。从图3的分析可以看出,两判别式的总贡献率为79.04%,判别式LD和判别式LD,的贡献率分别为40.86%和38.17%。用 LDA (L inearDiscrim inant method线性判别法)能够区分出这5组样品具有一定差异,并能看出不同生产日期的山楂罐头的气味存在一定趋势。随着生产日期的变化,第1主成分递增,第2主成分上下波动,形成一个类似余弦曲线的分布。由图4可以看出,随着不同生产日期的变化,第1主成分存在一定线性关系。 24 Loadings分析 图5为山楂罐头的 Loading传感器贡献率分析(总贡献率为98.24%)如果传感器的响应值接近于零,则该传感器的识别力可以忽略;而如果某一传感器的响应值较高,则说明该传感器的识别力比较强,是识别传感器。因此,从图5可以看出,2号传感器对第1主成分贡献率最大,4、6号传感器对第2主成分贡献率比较大。2号传感器对氮氧化物类物质最为灵敏,4号传感器对氢气最为灵敏,6号传感器对甲烷类物质最为灵敏。 PEN3电子鼻10个 Discriminant LD1 (contribution rate: 40.86 %) 图3 不同生产日期的山楂罐头与电子鼻响应信号关系的LDA分析 Fig 3 The LDA analysis of the relation ship between d ifferen tshelf tim e and the sen sors respon se 图44 不同生产日期的山楂罐头与电子鼻相应信号关系的第1主成分(LD1)分析 Fig 4 The LD1 analysis of the rela tion ship between differentshelf time and the sen sors respon se 传感器,基本上对所有挥发性物质都有响应,每个传感器对应某一类物质最为灵敏,据此,电子鼻作为一个方向性的指导,可与气相和质谱仪联用针对氮氧化物和烷烃类物质进行成分分析。 图5 山楂罐头的 Loading分析 Fig 5 The loading ana lysis of hawthorn can 25 电子鼻对未知样品的判别 取不同生产日期的3份山楂罐头样品,进行电子鼻系统测定,试验过程同方法。将所得数据预处理和特征提取后,用欧氏距离、相关性、马氏距离和DFA进行综合分析,发现电子鼻可以判定未知样品是哪 的耕地面积、农户的经济活动类型和区位条件呈显著性正向影响,其中耕地面积对农户的贷款意愿起着最重要的影响。具体表现在:①耕地面积越大,农户获取外源性融资的需求就越大。农户的自有资金只能满足小规模的农业生产,贷款资金用于农业生产的绝大部分是种田大户或流转大户,农户仅依靠内源融资不可能进行大面积生产,这与实际调查中的主观推测一致。②按农户所从事的不同职业来看,纯农户对贷款的需求弱于兼业农户,而兼业农户对借贷的需求又弱于从事非农产业的农户,这一特征在农户的主观融资愿望中表现尤为突出。这是由于从事非农产业的资金投人量较多,绝大多数农户依靠自身积累已不能满足需要,这同时也说明农村资金需求主体具有明显的行业特征。③从农户家庭所在的区位来看,离县城集镇比较近的,或是交通比较方便的农户融资需求比较强,这是因为在这些区位条件下从事非农产业与现代农业的农户比较多。 4结论与讨论 (1)由于农业生产效率低,抵御自然风险的能力弱,导致大量农村资金流向城市。同时,当前我国农业正在孕育新一轮改革,以家庭承包责任制为主体的个体经营模式已经不能满足当前农村的发展,急需向产业化、规模化转变,这就需要更多的资金投入。在目前农村金融生态环境中,农户一直处于弱势地位,农业的弱质性成为农村金融生态的重要障碍。因此,既要鼓励农村金融组织和金融产品创新,又要不断改善农村金融环境 (2)由于农户的耕地面积与农户类型是影响农户融资需求和抵押贷款意愿的最重要因素,因此,我国部分地区试点的农村土地抵押贷款应该重点考虑农村信用社等服务农业的金融机构,让其根据农户的耕地面积、经济活动类型和农 (上接第4793页) 一生产日期。DFA分析发现电子鼻对未知样品的识别率达到95.26%。 3 结论与讨论 采用电子鼻技术对不同生产日期的山楂罐头进行识别,并对所得数据进行了主成分分析(PCA)、线性判别法(LDA)分析,发现电子鼻可以区分所选不同生产日期的山楂楂头。研究发现,随着山楂罐头生产日期的延长,山楂罐头的气味发生变化,电子鼻能够识别这种变化,将所选的5种不同生产日期的山楂罐头区分开来,而且气味的变化还随时间呈一定的线性关系。研究选取了3种不同生产日期的山楂罐头用电子鼻进行区分,发现电子鼻能够识别未知的样品。山楂罐头的 Loading分析表明,2号传感器对第1主成分贡献率最大,4、6号传感器对第2主成分贡献率比较大。 电子鼻作为一个方向性的指导,可与气相和质谱仪联用针对氮氧化物和烷烃类物质进行成分分析。该研究为更好地利用电子鼻技术来判断山楂罐头的新鲜度提供了重要依据。另外,要真正实现电子鼻在山楂罐头工业上的应用还需 户区位条件,建立客户档案,培植重点客户。 (3)不断完善法律法规,制定完善的农村土地抵押制度81删掉集体所有的耕地、宅基地土地使用权不得抵押的规定,同时在农村土地承包法中明确规定“土地可以依法抵押”的内容,为农村土地抵押提供法律依据和法律保障,解决农户无抵押物难以筹集资金的现状,搞活农村资本市场,推动农村、农业发展,建设社会主义新农村。 (4)研究中由于样本总量较小等原因,研究结果可能与真实情况存在小范围的偏差,但运用Probit模型进行意愿分析与评测各影响因素影响度的方法值得推荐。由于制度创新本身就是一个内化因素与外在压力不断作用的过程,只有在实践中不断扎实理论知识、积累经验才能趋于完善。农村土地抵押的理论基础与运行机理还在不断完善中,因此运转中出现的程序合法性、合理性等内在问题还需要学者不断探索。 ( 参考文献 ) ( [1]颜志杰,张林秀,张兵.中国农户信贷特征及其影响因素分析[J].农业 技术经济,2005(4):2-8 ) ( [2]重庆市统计局.2009年重庆市统计年鉴[M].北京:中国统计出版社, 2009 ) ( [3]张祖民.农村非农产业发展与农村居民收入非农化问题研究[J].浙江 统计,1995(1):19-21. ) ( [4]汪小亚.关于农村土地经营权抵押贷款问题的研究[J].中国金融,2009 (9):53- 5 5. ) ( [5]熊学萍,阮红新,汪晓银.农户金融行为与融资需求的实证分析- —基 于湖北省天门市198个样本农户的调查[J].农业技术经济,2004(7): 85-95. ) ( [6]邱道持.论农村土地流转[M].重庆:西南师范大学出版社,2009 ) ( [7]兆耀.中国农村金融发展状况分析[J].财经研究,2006(4):103-1 0 8 ) ( [8]施晓琳.论以土地承包经营权抵押为特征的金融制度[J].南京农业大 学学报,2002(2):20-24 ) ( 要对传感器的优化和模式识别技术作进一步研究。 ) ( 参考文献 ) ( [1]OSH IT A S, S H MA K,HARUTA T, et al Discr i ination of o d ors emanatingfrom L a France’pe a r by sem i-conducting polymer sensors[J]. Comput E- l ectron A gric, 2000,26 : 209 - 2 1 6 ) ( [2]MAHDIGV,MOHTASEBIS S,SADATM, et al Meat q uality assessment by electronic n ose ( Machine Olfaction Te c hnology) [J]. Sens o rs, 2009, 9:6058-6083. ) ( [3] CHM IEL E W SKI J, SIKORSKA E , GORECKI T, e t al Ev a luation of thebeer aging using an electioni c nose[ J ] . Polish Joumal of Food and Nutri t ion Sciences.2007,57:91- 9 3. ) ( [4] DUTTA R,KASHWAN K R,BHUYAN M, et al Electionic nose b a sed teaquality standardization[ J ]. Neur a lNetworks,2003,16(5/6):847-853. ) ( [5]陈晓明,马明辉,李景明,等.电子鼻在天然苹果香精检测中的应用 [J].食品科学,2007,28(3):261-265. ) ( [6]MAGANN, EVANS P. Volatiles as an indicator of fungal activity and dif f erentiation between s p ecies, and the potential us e of electronic nose tech-nolgy f o r early detection of grain s poilage [J ]. Joumal of Stored ProductsResearch, 2000, 36:319-340 ) ( [7] FARNWORTH E R ,MCKELLAR R C,CHABOT D, et al Use of an elec-tronic nose t o study the contribution of volatiles to orange juice flavor[ J ] Joumal of Food Quality,2007,25(6):569-576 ) ( [8] BRUDZEW SKIK,OSOW SKI S,MARKIEW ICZ TClassification ofm ilk b y means of a n e l ectionic nose a n d SVM neu r al network [J ]. Sens ActuatorsB,2004,98:29 1 -298 ) ◎China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩1页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《蔬菜、水果及制品中营养成分检测方案 》,该方案主要用于罐头中营养成分检测,参考标准《暂无》,《蔬菜、水果及制品中营养成分检测方案 》用到的仪器有德国AIRSENSE品牌PEN3电子鼻、AIRSENSE-PEN3.5-电子鼻恶臭分析仪、AIESENSE-PEN3-meteo-电子鼻恶臭污染自动监测系统。
我要纠错
