Analysis of B-Alanine, Glucosamine and Galactosamine (L-8900) L-8900 Amino Acid Analyzer with the eluent for the special amino acid analysis, is shown. B-alanine is a structural isomer of alanine contained in protein. It is a free amino acid mainly found in muscle. The acetyl forms of glucosamine and galactosamine widely exist in biological sphere as the constituents of chitin of crustacean and insects, proteoglycans such as hyalron acid, and glycans on cell surfaces. Acetyll glucosamine and acetyl galactosamine mostly exist in the forms of glycans and areanalyzed by an amino acid analyzer after hydrolyzed to glucosamine and galactosamine. These amino acids are also used as the supplements for the improvement of athletic ability and prevention and improvement of arthritis. SAMPLE 20 uL of Std. Soln. (2 nmol/ 20 uL) PRESSURE PACKING MATERIAL #2620M [HITACHI] TEMPERATURE 65°C COLUMN SIZE for separation 4.6 mm l.D. ×80 mm[#2620M]for ammonia trap4.6 mm l.D.×40mm [#2650L] SEPARATION METHOD Ion Exchange DETECTOR VIS 570 nm, 440 nm ELUENT L-8500 PS-Buffer INSTRUMENTS L-8900 (Amino Acid Analyzer) FLOW RATE 0.19 mL/min NOTE Reaction reagent = Ninhydrin coloring solution kit for L-8900 R1/R2=50/50, Reaction reagent flow rate= 0.175mL/min, Reaction unit temperature=135℃ The L-8900 special amino acid analysis method was used for this analysis.For the eluent composition and method information, please contact our sales department, or our website separatelyby providing the instrument model name currently used KEY WORDS Bio/Medical Science/Food/Pharmaceutical, Medicine/Pharmaceutical,Food, Medical Science/Pharmaceutical Science, Supplement, Amino Acid,B-Alanine, Glucosamine, Galactosamine, Ninhydrin Method, UV-VIS Spectrometry, Health, L-8900, Ion Exchange High Performance LiquidChromatograph (HPLC) Sheet No. LC090052-01A Hitachi High-Technologies Corporation
关闭产品配置单
日立科学仪器(北京)有限公司为您提供《功能补充剂中有效成分检测方案(氨基酸分析仪)》,该方案主要用于保健食品中有效成分检测,参考标准《暂无》,《功能补充剂中有效成分检测方案(氨基酸分析仪)》用到的仪器有null。
