湍流边界层,聚合物,拖曳减阻中速度矢量场,浓度场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度矢量场,浓度场
关联设备
共3种
下载方案
Much progress has been made in the understanding of the phenomenon of drag reduction by dilute solutions of polymers since its discovery in 1948. While the use of advanced techniques in experiments and computational simulations have dramatically advanced
our understanding of the phenomenon, a complete and conclusive explanation of the physics associated with the phenomenon is still lacking. In particular, drag reduction in boundary layers with injection has not been studied extensively to understand the processes and physics that govern the spread and mixing of the injected polymer in the flow. To overcome this limitation, in the present work, drag reduction due to polymer injection in a turbulent boundary layer is studied using simultaneous Particle Imaging
Velocimetry (PIV) and Planar Laser Induced Fluorescence (PLIF). PIV is used to measure the velocity of the flow in the boundary layer and to calculate higher order velocity statistics. PLIF
is used to study the distribution and spread of the injected polymer in the boundary layer by tracking a fluorescent dye mixed in with it. The polymer of choice, polyethylene oxide, is injected as a dilute solution into a fully turbulent Newtonian boundary layer and measurements of velocity and concentration are made at different downstream locations on the flat plate to study the effect of the polymer on the flow and the evolution of drag reduction. The data from the two measurement techniques are combined to calculate turbulent fluxes and to estimate the turbulent Schmidt number in polymer drag reduced flows.
北京欧兰科技发展有限公司为您提供《湍流边界层,聚合物,拖曳减阻中速度矢量场,浓度场检测方案(粒子图像测速)》,该方案主要用于其他中速度矢量场,浓度场检测,参考标准《暂无》,《湍流边界层,聚合物,拖曳减阻中速度矢量场,浓度场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、PLIF平面激光诱导荧光火焰燃烧检测系统、Imager sCMOS PIV相机。
我要纠错
