边界层,流体,漩涡发声器中速度场,相位锁定测量检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场,相位锁定测量
关联设备
共2种
下载方案
Vortex generator jets (VGJs) have been found to be an effective method of active separation control on the suction side of a low pressure turbine (LPT) blade at low Reynolds numbers. The flow mechanisms responsible for this control were studied and documented in order to provide a basis for future improvements in LPT design. Data were collected using a stereo PIV system that enabled all three components of velocity to be measured.
北京欧兰科技发展有限公司为您提供《边界层,流体,漩涡发声器中速度场,相位锁定测量检测方案(粒子图像测速)》,该方案主要用于其他中速度场,相位锁定测量检测,参考标准《暂无》,《边界层,流体,漩涡发声器中速度场,相位锁定测量检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
我要纠错
