流体中速度场,湍流检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场,湍流
关联设备
共2种
下载方案
Turbulent dispersed two-phase flows are abundant in both industry and nature. The ability to
predict the behaviour of this type of flow - either using numerical or theoretical models - will
be benificial to a wide range of disciplines. However, a lack of consistent experimental data
currently makes validation of both numerical and theoretical results difficult. The main aim
of this thesis is to generate experimental data that could fill this void. In order to do so, a
facility is built to generate isotropic, homogeneous turbulence. This is done using a grid in a
vertical water channel. This new facility is validated and documented for the particle-free case
using Laser Doppler Anemometry (LDA) and Particle Image Velocimetry (PIV). The results
of both measurement techniques are in good quantitative agreement, and the flow is a close
approximation of decaying homogeneous, isotropic turbulence.
北京欧兰科技发展有限公司为您提供《流体中速度场,湍流检测方案(粒子图像测速)》,该方案主要用于其他中速度场,湍流检测,参考标准《暂无》,《流体中速度场,湍流检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
我要纠错
