当前位置: 其他 > 方案详情
蛋白质中DSC测试阶段含量检测方案(差示扫描量热)
检测样品 其他
检测项目 DSC测试阶段含量
关联设备 共1种 下载方案
方案详情
通过差示扫描量热仪(DSC)使用CSC Nano-DSC III测定蛋白质的热力学参数,需要大量相同的蛋白质做表面等离子体共振或荧光研究。由于Nano-DSC III 高度的敏感性和基线重复性,以及样品池的小体积(300 μL)和毛细管配置(能够延迟不可逆的蛋白质聚合和沉淀),一个完整的、可判断的、准确的扫描可以得到基本上所有的想要测试的蛋白质。?
M144 How Much Protein is Required for a DSC Scan? Christin T. Choma TA Instruments, 109 Lukens Drive, New Castle, DE 19720,USA etermining the thermodynamic parameters ofDa protein by differential scanning calorimetry(DSC) using the CSC Nano-DSC III requiresabout the same amount of protein as surfaceplasmon resonance or fluorescence studies. Becauseof the Nano-DSC III's extreme sensitivity and baselinereproducibility, and the sample cell's small volume(300 pL) and capillary configuration (which delaysthe onset of irreversible protein aggregation andprecipitation), a complete, interpretable, accuratescan can be obtained on essentially any protein ofinterest. The sensitivity and accuracy of the Nano-DSCIll is demonstrated by the following data set. Henegg white lysozyme (in pH 4.0 glycine buffer) wasprepared at various concentrations (concentrations (400 pg-2 pg per scan.) established by A2go followed by serial dilutions) andscanned at 2 C/min. A single unsmoothed scan ateach concentration is shown in Figure 1. Each data set was analyzed for calorimetricenthalpy (AH)and entropy(AS),and the van’t HoffT and AH: Lysozyme incell (pg) Calorimetric van’t Hoff AH (kJ mol') AS (kJK'mol') T(℃) AH (kJ mol') 400 512 1.46 78.0 515 100 512 1.46 78.0 509 50 517 1.47 77.9 513 25 513 1.46 77.8 513 10 515 1.47 78.0 515 5 490 1.40 78.1 510 2 503 1.43 77.8 499 Even 2 pg of lysozyme in the capillary cell is sufficientto provide quality data yielding accurate values of allfour thermodynamic parameters. Using the CSC Nano-DSCIII, precise and completethermodynamic analysis of proteins available inonly very limited quantities is now possible. Determining the thermodynamic parameters of a protein by differential scanning calorimetry (DSC) using the CSC Nano-DSC III requires about the same amount of protein as surface plasmon resonance or fluorescence studies. Because of the Nano-DSC III’s extreme sensitivity and baseline reproducibility, and the sample cell’s small volume (300 μL) and capillary configuration (which delays the onset of irreversible protein aggregation and precipitation), a complete, interpretable, accurate scan can be obtained on essentially any protein of interest.
关闭
  • 1/1
产品配置单
TA仪器为您提供《蛋白质中DSC测试阶段含量检测方案(差示扫描量热)》,该方案主要用于其他中DSC测试阶段含量检测,参考标准《暂无》,《蛋白质中DSC测试阶段含量检测方案(差示扫描量热)》用到的仪器有NANO等温差示扫描量热仪。
我要纠错
推荐专场
相关方案
