Mix Ratio Identification inIndustrially Significant Two-PartCoating Systems Using the Agilent4300 Handheld FTIR Introduction Protective coatings are commonly applied to automobiles, aircrafts, ships,railways,furniture,bridges, concretes, architectural constituents, industrial installations, andmany other products that we encounter on a daily basis. Coating application inmany of these products is primarily implemented to provide protection against harshenvironments such as UV light, extreme temperatures, acid, alkali, salt, water, andso forth, and to improve the aesthetic appearance of finished products. A wide variety of coating formulations exist in the market; their use depends on theperformance requirement of the final product. Coatings may be applied to the productsas a primer basecoat, a mid-coat, or as the topcoat. For example, polyurethanecoating is applied on top of epoxy primer coating to prevent the discoloration ofepoxy from UV and to provide the specified color and sheen. Agilent Technologies
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《工业上重要的双涂层系统中混合比例检测方案(红外光谱仪)》,该方案主要用于其他中混合比例检测,参考标准《暂无》,《工业上重要的双涂层系统中混合比例检测方案(红外光谱仪)》用到的仪器有Agilent 4300 手持式 FTIR 光谱仪。
