ASTM D7806-12 for Biodiesel inPetroleum-based Diesel Fuel Oil Agilent 4500,5500, and Cary 630 FTIR Introduction Biodiesel is usually an effective blending component for petroleum-based diesel fuel.However, biodiesel-mixed diesel fuel can be a problem in engines designed for onlypetroleum-based diesel. Also, blended biodiesel can promote biological growth andincrease instability of the diesel fuel resulting from the buildup of oxidationproducts. Thus, biodiesel-blended diesel fuel can cause issues in stationary standbydiesel engines, such as those used in nuclear plants.The ASTM D7806-12 test methodwas developed for the determination of biodiesel (FAME) content in diesel fuel oilsin the concentration range from 1 to 30% by volume. In this application note,,Wedemonstrate the applicability of any of the three Agilent FTIR spectrometers (s (4500,5500, and Cary 630) to this method. The Agilent systems can be used for: ·Quality control in the production and distribution of diesel fuel and biodieselblends containing FAME Routine checks of incoming blended diesel fuels from a distributor The Agilent FTIR spectrometers demonstrated excellent repeatability (X ± 0.02%),better than X ± 0.3% as defined in the ASTM D7806-12 method, where X is the biodieselconcentration. Whether the biodiesel content of a blended fuel needs to be tested inthe lab or in the field, the three Agilent spectrometers provide an easy, accurate,and portable means for measurement. This gives analysts the flexibility to choose thebest instrument based on their routine analysis requirements. Agiurt Techarlogin Agilent Technologies Biodiesel is usually an effective blending component for petroleum-based diesel fuel. However, biodiesel-mixed diesel fuel can be a problem in engines designed for only petroleum-based diesel. Also, blended biodiesel can promote biological growth and increase instability of the diesel fuel resulting from the buildup of oxidation products. Thus, biodiesel-blended diesel fuel can cause issues in stationary standby diesel engines, such as those used in nuclear plants. The ASTM D7806-12 test method was developed for the determination of biodiesel (FAME) content in diesel fuel oils in the concentration range from 1 to 30% by volume. In this application note, we demonstrate the applicability of any of the three Agilent FTIR spectrometers (4500, 5500, and Cary 630) to this method. The Agilent systems can be used for:
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《石油类柴油燃料油中生物柴油检测方案(红外光谱仪)》,该方案主要用于柴油中生物柴油检测,参考标准《暂无》,《石油类柴油燃料油中生物柴油检测方案(红外光谱仪)》用到的仪器有Agilent 4500 系列便携式 FTIR 。
