抗体药物偶联物中成分分析检测方案(液相色谱仪)
检测样品
治疗类生物药品
检测项目
成分分析
关联设备
共1种
下载方案
Recombinant monoclonal antibodies (mAbs) have emerged as important therapeutic agents for the treatment of different diseases. This technology has been extended by the development of antibody drug conjugates (ADCs). ADCs are mAbs to which cytotoxic payloads are covalently attached, enabling the delivery of potent drugs to a specific target. This Application Note describes the analysis of an mAb (trastuzumab) and an ADC (trastuzumab emtansine) by size exclusion chromatography with online mass spectrometry (SEC-MS) using the Agilent 1290 Infinity II LC system with an Agilent 6530 Accurate Mass Q-TOF LC/MS system. We demonstrate that SEC is a straightforward way to introduce mAbs and ADCs into the LC/MS system, requiring little method optimization. From the MS data collected for the ADC, it was possible to calculate a drug-to-antibody ratio (DAR) of 3:2.
安捷伦科技(中国)有限公司为您提供《抗体药物偶联物中成分分析检测方案(液相色谱仪)》,该方案主要用于治疗类生物药品中成分分析检测,参考标准《暂无》,《抗体药物偶联物中成分分析检测方案(液相色谱仪)》用到的仪器有Agilent 1290 Infinity II 液相色谱系统。
我要纠错
