溶剂和己烷异构体中最佳分离检测方案(气质联用仪)
检测样品
其他
检测项目
最佳分离
关联设备
共0种
下载方案
The Agilent J&W CP-Select 624 Hexane GC column, with an optimized G43 stationary phase, separates dichloromethane (DCM) from hexane isomers. This application note shows the separation as applied by pharmaceutical and food processing industries in India. Each column is tested with a special test mix that guarantees good column-to-column reproducibility. As with the specific separation of DCM, the USP <467> specification for the separation of acetonitrile and dichloromethane is in compliance, and tested for in every batch of stationary phase. Column selectivity is compared for two series using a multicomponent mix against two columns from another vendor.
安捷伦科技(中国)有限公司为您提供《溶剂和己烷异构体中最佳分离检测方案(气质联用仪)》,该方案主要用于其他中最佳分离检测,参考标准《暂无》,《溶剂和己烷异构体中最佳分离检测方案(气质联用仪)》用到的仪器有null。
我要纠错
