溴苯乙烯中三重检测方案(液相色谱仪)
检测样品
其他
检测项目
三重
关联设备
共1种
The structure of many common types of polymer may be modified by either postpolymerization reaction or by the use of modified monomers, producing materials with new and novel properties. Understanding and assessing the effect of these modified structures on the behavior of polymers in various applications is crucial to developing novel uses for such materials. Polystyrene is one of the most commonly seen polymers, used primarily for the manufacture of packing materials. Modified forms of polystyrene may be produced by the use of novel styrene monomers. Gel permeation chromatography (GPC) is a well-known technique for assessing the molecular weight distribution of polymers, a property that influences many physical characteristics. Importantly, increasing the sophistication of the GPC experiment by the use of additional detectors allows the structure and solution properties of polymers to be assessed, of interest when studying the affect of structural modifications on a polymer. Triple detection employing a light scattering detector and a viscometer in combination with a refractive index detector may be used to determine accurate molecular weights for polymers for which narrow standards are not available, and to assess their solvation properties. This application note describes the analysis of a sample of polystyrene and a modified polybromostyrene material by triple detection.
安捷伦科技(中国)有限公司为您提供《溴苯乙烯中三重检测方案(液相色谱仪)》,该方案主要用于其他中三重检测,参考标准《暂无》,《溴苯乙烯中三重检测方案(液相色谱仪)》用到的仪器有Agilent 1260 Infinity II 液相色谱系统。
我要纠错
