聚丁二烯中GPC三器检测方案(液相色谱仪)
检测样品
其他
检测项目
GPC三器
关联设备
共1种
Polybutadiene is an elastomer – a polymer that exhibits elasticity. Elasticity is the ability to deform under external stress but return to the original form after removal of the stress. Polybutadiene is a synthetic rubber manufactured from the monomer 1,3-butadiene. Polybutadiene exhibits 80% recovery after stress, one of the highest values of a synthetic material. It is commonly used to coat electronic assemblies due to its extremely high electrical resistivity. Polybutadiene displays a high wear resistance, low heat build-up after repeated flexing and a low rolling resistance, making it suitable for applications such as tires. It is often used in combination with other materials to produce rubber blends with differing properties. The 390-MDS offers triple detection GPC by employing a light scattering detector and a viscometer in combination with a differential refractive index detector, to determine accurate molecular weights for polymers for which narrow standards are not available, such as polybutadiene.
安捷伦科技(中国)有限公司为您提供《聚丁二烯中GPC三器检测方案(液相色谱仪)》,该方案主要用于其他中GPC三器检测,参考标准《暂无》,《聚丁二烯中GPC三器检测方案(液相色谱仪)》用到的仪器有Agilent 1260 Infinity II 液相色谱系统。
我要纠错
