The results are in good agreement with the expected values. Some care must be taken with the sample preparation, especially with soil extracts. To reduce matrix effects, radial viewing is preferred to axial. Furthermore, the standards were prepared with the same amount of acid or ammonium acetate used with the real samples, to have the same nebulization efficiency between standards and samples. Background correction was used to nearly remove spectral matrix effects. Two different sets of standards were used; one for major and the other for minor elements in order to be as accurate as possible. Sample throughput with simultaneous ICP spectrometers, such as the PANORAMA is very high, up to 60 samples in an hour.
关闭产品配置单
HORIBA(中国)为您提供《土壤浸提液中矿物/地质检测方案(ICP-AES)》,该方案主要用于土壤中矿物/地质检测,参考标准《暂无》,《土壤浸提液中矿物/地质检测方案(ICP-AES)》用到的仪器有HORIBA Ultima Expert高性能ICP光谱仪。
