当前位置: 杀菌剂 > 方案详情
杀菌剂IPBC中结构、成分检测方案(液质联用仪)
检测样品 杀菌剂
检测项目 结构、成分
关联设备 共0种 下载方案
方案详情
日立Chromaster5610质谱检测器具有液相常规检测器级别的操作性,不管是进样品进行定性分析,还是采用SIM模式进行定量分析,都能轻松进行。
HITACHIInspire the NextAS/MSD-006 Liquid Chromatograph@Hitachi High-Tech Science Corporationhttp://www.hitachi-hitec-science.comC2015 Hitachi High-Tech Science Corporation Analysis of Disinfectant (IPBC) by Mass Detector Chromaster 5610 MS Detector is a mass detector with new concept, designed for LC users, andit is different from conventional mass spectrometers. This time, the analysis example of 3-lodo-2-propynyl N-Butylcarbamate (IPBC) is introduced here. IPBC is said to have disinfectant effects on fungi such as mold and it is used as antiseptic andantifungal agents for wood and also as a termite controlling agent. The operability of 5610 MSDetector is as good as that of HPLC detectors. Therefore, it is easy to perform the operationfrom the direct sample solution introduction for the mass confirmation to the SIM-basedquantitative analysis with the connection to HPLC. 5610 MS Detector LC-MS Analysis of IPBC Table 2 Analytical Conditions for HPLC Column LaChromⅡ C18 (1.9 um)3.0 mm l.D. x 100 mm Mobilephase CH3OH Flow rate 0.3 mL/min(1:50 sprit) Columntemperature 40°C Detectionwavelength UV 225nm Injection vol. 10 uL Figure 1 Structural Formula of IPBC Figure 3 SIM Chromatogram of IPBC
关闭
  • 1/1
产品配置单
日立科学仪器(北京)有限公司为您提供《杀菌剂IPBC中结构、成分检测方案(液质联用仪)》,该方案主要用于杀菌剂中结构、成分检测,参考标准《暂无》,《杀菌剂IPBC中结构、成分检测方案(液质联用仪)》用到的仪器有null。
我要纠错
相关方案
