Dec 6,2016.LC Application Lab, Shiseido ChinaNo.31, BDA International Business Park,2 Jing Yuan Street, BeijingEconomic Technological Development Zone,Beijing, China 100176Phone 010-6785-6801, FAX 010-6785-6882 食品中前花青素的国标方法分析 本实验室严格按照国标 (GB/T 22244-2008)方法对客户提供前花青素标准品及蓝莓提取液样品进行分析。因国标方法中流动相条件为含有8%甲酸的强酸环境,选择资生堂耐酸色谱柱CAPCALL PAK C18 ACRS5;4.6mm i.d.×150mm (AGAB01096),分析结果如图1所示。 Minutes 图 1 ACR分析对照品结果 HPLC Conditions: 色谱柱::CAPCALL PAK C18 ACR S5;4.6mmi.d.×150mm 流动相: 水:甲醇:异丙醇:甲酸=73:13:6:8 流1.0mL/min温 检浓 35°C PDA 525nm 15mL 正丁醇与盐酸混合溶液(正丁醇:盐酸=95:5)加入0.5mL2%硫酸铁铵(2mol/L盐酸溶解)和0.1mg/mL对照溶液(甲醇溶解稀释)2mL,混匀,沸水浴回流40min,冰水中冷却,过滤后上样。 进样量: 10pL HPLC Conditions : Column:CAPCALL PAK C18 ACR S5;4.6mm i.d.×150mm Mobile phase:water: methanol: isopropanol: formic acid = 73: 13:6:8 Flow rate: 1.0mL/min Temp:35°C Detection:FPDA 525nm Sample:Add 0.5 mL of 2% ammonium ferric sulfate (dissoved in 2 mol/L HCL) and 2 mL of 0.1 mg/mLreference solution (dissoved in methanol) in 15 mL of n-butyl alcohol mixed with hydrochloric acidsolution (n-butyl alcohol: hydrochloric acid =95:5),And the solution was heated in boiling water bathand refluxed for 40 min, cooled down in ice water and filtered with 0.45pm. Inj.vol: 10pL 从结果中看出,氰定保留时间为 3.21min, 同主峰前杂质得到良好分离及分析峰形。多次重复进样,可以得到稳定保留时间。在相同流动相系统中,对客户提供蓝莓提取液样品按国标水解反应处理后,分析结果如图 2. 图2ACR分析样品结果 HPLC Conditions : 色谱柱:CAPCALL PAK C18 ACR S5;4.6mm i.d.×150mm 流动相: 才水:甲醇:异丙醇:甲酸=73:13:6:8 流1.0mL/min温 检浓 35°C PDA 525nm 15mL 正丁醇与盐酸混合溶液(正丁醇:盐酸=95:5)加入0.5mL2%硫酸铁铵 (2mol/L盐酸溶解)和蓝莓发酵液样品2mL,混匀,沸水浴回流 40min,冰水中冷却,过滤后上样。 进样量: 10pL HPLC Conditions: Column::CAPCALL PAK C18 ACR S5;4.6mmi.d.×150mm Mobile phase: water: methanol: isopropanol: formic acid = 73: 13:6:8 Flow rate: 1.0mL/min Temp:35°C Detection: PDA 525nm :Sample::AAdd 0.5 mL of 2% ammonium ferric sulfate (dissoved in 2 mol/L HCL) and 2mL of blueberries fermesample solution in 15 mL of n-butyl alcohol mixed with hydrochloric acid solution (n-butyl alcohol:hydrochloric acid =95:5),And the solution was heated in boiling water bath and refluxed for 40 min,cooled down in ice water and filtered with 0.45pm. Ini.vol: 10pL 从图2中看出,分析蓝莓提取液样品可得到氰定的良好检出结果,样品中未见对照品主峰前杂质峰。 综宗实验结果,使用资生堂 CAPCALL PAK C18 ACR S5;4.6mm i.d.×150mm 丁谱柱可以实现国标方法对蓝莓提取液中前花青素的检测。 (注:数据存储路径仪器2/D/zhanghu/data/前花青素/20161205) 张虎郭彦丽
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《前花青素中前花青素含量检测方案(液相色谱柱)》,该方案主要用于其他水果制品中营养成分检测,参考标准《暂无》,《前花青素中前花青素含量检测方案(液相色谱柱)》用到的仪器有null。
