HPLCDATA :SHEET 毛少于儿力又卜十卜少儿锭(米国薬局方原案記載条件) Montelukast sodium tablets (The draft for The United States Pharmacopoeia) H150501B (A) Dissolution: Standard solution*1(5.4 ug/mL Montelukast) Systemsuitability requirement Result Tailing factor(Montelukast) ≤1.5 1.08 Relative standarddevition of peakarea (n=5)(Montelukast) ≤2.0% 0.05% (B)Uniformity of dosage units: Standard solution(0.039 mg/mL Montelukast) Systemsuitability requirement Result Tailing factor(Montelukast) ≤1.5 1.15 Relative standarddevition of peakarea (n=5)(Montelukast) ≤2.0% 0.06% (C) Uniformity of dosage units: Sample solution(0.04mg/mL Montelukast) Column : YMC-Pack Ph (5 um, 12 nm)100X3.0 mml.D.Eluent : acetonitrile/water/TFA (500/500/2)Flow rate : 0.9 mL/minTemperature : 50℃Detection : UV at 389 nmInjection :A) 20 pL, B),C) 10 pL (The draft for The United States Pharmacopoeia 40th; Dissolution, Uniformity of dosage units) All Standard solutions ware prepared from Montelukast sodium salt hydrate supplied as a reagent for laboratory use.Sample solution was prepared from Montelukast sodium tablets. 色谱条件见谱图。
关闭产品配置单
深圳凯米斯科技有限公司为您提供《孟鲁司特钠片中含量测定检测方案(液相色谱柱)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《孟鲁司特钠片中含量测定检测方案(液相色谱柱)》用到的仪器有null。
