Hitachi High-Technologies Corporation Direct Fluorescence Analysis of The Skin Using Optical Fiber Accessory INTRODUCTION Collagen, which is also drawing attention as a health food, is found in the dermis of the skin and its fluorescenceemission has been reported. The fluorescence spectrum and intensity change depending on the type and cross-linkingcondition of collagen and thus, the study is being focused on the application of the fluorescence measurement tounderstand skin conditions. By using the optical fiber accessory (custom made) with the F-7000 fluorophotometer, a sample of a size that cannotbe placed in the sample chamber can be directly analyzed. In addition, the ultrahigh-speed scan speed, one feature ofthe F-7000 fluorophotometer allows a rapid measurement of the 3D fluorescence spectrum. This time, an example inwhich 3D fluorescence spectra of salmon skin-derived collagen and human skin were measured by using the opticalfiber accessory is introduced here. SAMPLE Sample: Salmon skin-derived collagenHuman skin ANALYSIS CONDITIONS Instrument : F-7000 Excitation wavelength range : 240-350 nm Fluorescence wavelength range : 240-500nm Data interval : 5 nm Scan speed :60000 nm/min Detector : R3788 Photomultiplier voltage: 400 V ACCESSORY Fluorescence Excitation Light This accessory allows the non-destructive direct analysis of a sample whichcannot be placed in the sample chamber. This accessory is a custom made product. Please contact our salesrepresentatives separately for detailed information including the specification. Fluorescence Wavelength (nm) Fluorescence Wavelength (nm) Salmon Skin-derived Collagen Human Skin (Male Adult) Human Skin (Female Adult) Peak wavelength Peak wavelength Peak wavelength (Ex:280 nm, Em: 305 nm) (Ex :285 nm, Em : 320nm) (Ex:290 nm, Em: 330nm) The 3D fluorescence spectra indicated that the both excitation and fluorescence peaks of the human skin occur at longer wavelengths compared with the salmon skin-derived collagen. In addition, it was found that the skin of a female adult showed the peak at a longer wavelength compared with the skin of a male adult. It has been reported that the collagen cross-linking increases with age, resulting in the change in the fluorescence properties. The 3D spectrum measurement will support studies such as the one described above. KEY WORDS Fluorophotometer (FL) FL Bio/Medical Science/Food/Pharmaceutical, Other Bio/Medical Science/Food /Pharmaceutical Related, Salmon skin-derived Collagen, Skin, Optical Fiber, 3D Fluorescence Spectrum, 3D, FL, F-7000 Sheet No. FL110012-01 本文详细向您介绍如何使用日立荧光分光光度计F-7100分析检测皮肤中的胶原蛋白含量。通过测量不同生物样品(包括:三文鱼皮,男性皮肤和女性皮肤),利用三维立体的激发发射光谱,可以清晰辨别出各生物样品种类,并检测其中的胶原蛋白含量。F-7100拥有全球最快扫描、驱动速度和最高灵敏度,三维光谱分析更加方便、快捷,提供追踪监控化学反应过程。超高信噪比的优异功能,可以检测出低至1*10-12mol/L的荧光素,同时,更有利于痕量样品的测量。实验中,搭配主机使用的光纤附件使得样品种类与形状更具灵活性,将光源能量导出并无损伤直接检测肌肤变成可能。
关闭产品配置单
日立科学仪器(北京)有限公司为您提供《皮肤、鱼皮等样品中胶原蛋白、蛋白质检测方案(分子荧光光谱)》,该方案主要用于其他中胶原蛋白、蛋白质检测,参考标准《暂无》,《皮肤、鱼皮等样品中胶原蛋白、蛋白质检测方案(分子荧光光谱)》用到的仪器有日立F-7100荧光分光光度计。
