超星期北京豫维科技有限公司联系人:水先生电话:18911849923中国药物应用与监测2017年6月第14卷第3期 Chinese Journal of Drug Application and Monitoring, Vol.14, No.3, June 2017 沙棘籽油中维生素E含量的CGC法测定 沈 琪,王 梅(新疆医科大学药学院,新疆乌鲁木齐830011) [摘要] 目的:研究沙棘籽油中脂肪酸成分,定量分析并建立毛细管气相色谱法(CGC)测定沙棘籽油中维生素E( Vit E)含量的方法。方法:采用溶剂回流提取法提取沙棘油中挥发油成分,并用气相色谱-质谱联用法(GC-MS)对其进行定性、定量分析。采用岛津GC-2010 plus气相色谱仪,以正三十二烷为内标物对 Vit E进行测定,并对该方法进行方法学考察。结果:从沙棘籽油中分离鉴定出28个化合物;采用Rtx-5毛细管色谱柱(30m×0.25 mm, 0.25 um);柱温为程序升温:150℃保持13 min,以10 ℃·min的升温速率升至300℃,保持8 min; FID检测器温度为300℃;进样口温度为310℃;无分流进样。在此条件下, Vit E和内标物分离良好,在0.02~0.43 mg*mL 浓度范围内呈良好线性关系, r=0.9996。结论:建立以CGC测定沙棘籽油中维生素E含量的方法,灵敏、准确、重复性好,可作为沙棘籽油中Vit E的含量测定方法。 [关键词] 沙棘油;维生素E;毛细管气相色谱法 [中图分类号]R917 [文献标识码] A [文章编号] 1672-8157(2017)03-0154-03 Determination of vitamin E content in the oil from seed of Hippophae rhamnoides by CGC SHEN Qi, WANG Mei(College ofPharmacy, Xinjiang Medical University, Urumqi 830011, China) IABSTRACT]| Objective: To analyze the fatty acids composition in the oil from seed of Hippophae rhamnoides, and establisha capillary gas chromatography (CGC) method to determine the content of vitamin E in the seed oil of Hippophae rhamnoides.Methods: Oil was extracted from Hippophae rhamnoides seed by heated reflux solvent. GC-MS was adopted to determine itschemical constituents. The quantification of the vitamin E (Vit E) content was conducted by GC-2010 plus. Dotriacontane was actedas the internal standard. Results: Totally 28 chemical constituents were extracted. The GC system consisted of a Rtx-5 capillarycolumn (30 mx 0.25 mm, 0.25 um). Column temperature was temperature programming including 150 ℃ for 13 min, rose to 300℃by the rate of 10℃minand maintained 300 ℃ for 8 min. The temperature of FID detector and the injection was 300 C and 310 ℃respectively. The splitless injection was adopted, Vitamin E was separated satisfactorily from dotriacontane. The calibration curve forVitamin E was linear in the range of 0.02 -0.43 mgmL(r=0.9996). Conclusion: The capillary GC method was sensitive andreliable. It could be used to determine the content of vitamin E in the Seed oil of Hippophae rhamnoides. [KEY WORDSIHHippophae rhamnoides oil; Vitamin E; Capillary gas chromatography (CGC) 沙棘(Hippophae rhamnoides Linn.)为胡颓子科(Elaeagnaceae)沙棘属植物,是蒙药、藏药习用药材。从沙棘中提取分离得到的沙棘油,富含大量营养活性物质,近年来逐渐引起医药界的重视,并在其资源、药理、制剂、临床等方面进行了系统研究,证实沙棘油是一个药理活性强、高效、安全的药物-21。现代研究表明,沙棘油具有防治胃溃疡、保护化学性肝损伤、促进创面修复等作用。维生素E(Vitamin E, Vit E) ( [基金项目]新疆维吾尔自治区优秀青年科技创新人才培养工程项目(qn2015yx018);沙棘油纳米乳的制备研究(CXCY096) ) ( [通信作者]王梅,女,副教授,研究方向:药物新剂型和药物传 输系统。E-ma i l: wm630@163.com ) ( [作者简介] 沈琪,女,硕士研究生,研究方向:药物新剂型。 E-mail: 2529110682@qq.com ) 是沙棘油中天然抗氧化剂,含量越高,油越稳定,作为沙棘油中的重要有效成分,具有多种功效。本文以VitE为沙棘油质量控制的主要指标,通过加热回流法提取沙棘籽油,用GC-MS对其进行成分分析,并建立以CGC测定沙棘油中 Vit E含量的方法,旨为沙棘油的开发利用提供理论参考。 仪器与试药 Perkin-Elemer Autosystem XL-Turbemass型气质联用色谱仪(美国PE公司); GC-2010 plus型气相色谱仪(日本岛津公司); AB135-S型万分之一天平(瑞士Mettler公司)。 沙棘籽油(实验室自制,沙棘药材购自阿勒泰地区,纯度99.9%); Vit E对照品(中国食品药品检定研究院,纯度98%,批号:G3D7-DS8F);正三十二烷 (美国Sigma 公司,纯度97%);正己烷、甲醇(色谱纯,天津市福晨化学试剂厂);氢氧化钾(分析纯,天津市光复科技发展有限公司)。 2 方法与结果 2.1 沙棘籽油提取 通过溶剂回流提取法,将沙棘籽中的沙棘籽油溶于石油醚,回收石油醚后得到沙棘籽油。得油率为8.9%。 2.2 沙棘籽油中脂肪酸成分分析及结果 色谱条件:采用PE-5MS柱(60 m×0.25 mm,0.25 pm);柱温为程序升温:50℃保持3 min, 以3℃·min 的升温速率升至200℃,5℃min 升至280℃,保持30 min; 进样口温度为300℃;分流比为50:1;载气为 He (99.99%);进样量为0.8 pL。通过GC-MS全分析共鉴定出沙棘籽油中28种化合物。 2.3 沙棘籽油中 Vit E含量定定 23.1 色谱条件采用Rtx-5毛细管色谱柱(30m×0.25mm,0.25 um);柱温为程序升温:150℃保持13 min, 以10℃.min的升温速率升至300℃,保持8 min; 进样口温度为310℃;FID检测器温度为300℃;载气为N,流速1mL.min ;无分流进样;进样体积为1uL。 2.3.2溶液的制备 内标物溶液:精密称取正三十二烷适量,加正己烷溶解并稀释成1 mgmL的溶液,摇匀,即得。 对照品溶液:精密称取Vit E对照品适量,加正己烷溶解并稀释成含1mg*mL的溶液,摇匀,即得。 供试品溶液9-10:称取沙棘籽油0.5 g, 置25 mL棕色量瓶中,精密加入乙醚-正己烷(2:1)2.5mL,甲醇2.5 mL, 静置2h,再精密加入2 molL氢氧化钾甲醇溶液1mL,于60℃水浴中摇匀,静置5 min, 加蒸馏水至刻度。吸取上层溶液置10 mL试管中,精密加入内标溶液3mL,摇匀,滤过,取续滤液,即得。 2.3.3 系统适用性实验 将上上3种溶液各1.0 uL,按“2.3.1”项下方法分别进样分析,色谱图结果显示,Vit E与正三十二烷色谱峰的分离度大于2.6, Vit E理论塔板数大于5000,色谱峰形对称,见图1。 2.3.4 线性关系 分别精密吸取对双品储备液0.05、0.10、0.50、0.70、0.90、1.10、1.30 mL置25 mL棕色量瓶中,前处理后吸取上层脂肪酸甲酯,置10 mL试管中,精密加内标溶液3mL,摇匀。分别自动进样lpL, 以进样量(X, ug)为横坐标,峰面积比值(Y,对照品/正三十二烷)为纵坐标,绘制标准曲线,线性回归方程为:Y=0.7057X+0.002, r=0.999 6。结果表明: Vit E在0.02~0.43 mgmL"范围内,线性关 图1GC图谱 A-对照品,B-供试品;1-正己烷,2-VitE,3-正三十二烷 Fig 1 GC chromatograms A- reference substance, B - sample; 1-n-hexane, 2-Vit E,3-n-dotriacontane 系良好。 2.3.5 精密度实验 精密吸取对照品溶液(0.43 mg*mL'),连续进样5次,计算 Vit E与内标峰面积比值 的RSD为0.47%(n=5),结果表明仪器的精密度良好。 2.3.6 重复性实验 取沙棘籽油0.05 g, 共6份,按“2.3.2”项下方法制备,按“2.3.1”项下色谱条件进行测定,计算 Vit E与内标峰面积比值的RSD为0.48%(n=6),表明方法重复性良好。 2.3.7 稳定性实验 称取沙棘籽油0.05 g,按“供试品溶液制备”项下方法制备,分别于配制后0、2、4、6、8h进样测定,计算 Vit E与内标峰面积比值的RSD为1.40%,结果表明样品在8h内稳定。 2.3.8 加样回收率实验 精密称取已知准确Vit E(0.047mg*mL )含量的沙棘籽油共9份,每份0.05 g,置25 mL量瓶中,分别精密加入 Vit E对照品溶液储备液(1 mgmL)0.5 mL、0.7 mL、1.1mL,每个浓度制备3份,按“2.3.2”项下方法制备,按“2.3.1”项下色谱条件进行测定,结果显示 Vit E的平均回收率为96.83%, RSD为0.54%,详见表1。 2.3.9 样品含量测定 取自提沙棘籽油3批,按“2.3.2”项下方法制备,按“2.3.1”项下色谱条件进行测定,详见表2。 3 讨论 GC-MS 测得沙棘籽油中脂肪酸的总离子流图,经与标准谱库的质谱数据检索核对,共鉴定出28种化合物,将峰面积进行归一化法处理后,沙棘籽油中亚油酸(44.5%)和油酸(37.52%)的相对含量高于沙 表1 加样回收率实验结果.n=9 Tab 1 Result of sample recovery rate test. n=9 取样量/g 供试品 加入量 峰面积 测得量 回收率/% 含量/mg /mg 比值 /mg 0.050 0 0.053 9 0.166 7 0.1109 0.215 4 96.90 0.0500 0.0539 0.166 7 0.111 1 0.215 7 97.10 0.0500 0.053 9 0.1667 0.112 0 0.2156 97.00 0.0500 0.053 9 0.2333 0.150 1 0.281 2 97.43 0.0500 0.053 9 0.233 3 0.149 5 0.2804 97.07 0.050 0 0.053 9 0.233 3 0.1500 0.2812 97.43 0.050 0 0.053 9 0.3667 0.2242 0.406 2 96.08 0.0500 0.0539 0.3667 0.2245 0.4067 96.22 0.0500 0.053 9 0.3667 0.224 5 0.4067 96.22 表2 沙棘籽油中 Vit E的含量. n=3 Tab 2 Determination of contents of Vit E in Hippophaerhamnoides oil. n=3 批次 Vit E的含量/mgg RSD/% 2.944 2 3.000 1.08 2.944 棘油标准(SL 493-2010沙棘籽油)中脂肪酸组成指标。亚麻酸成分略低,这可能是干燥恒重时亚麻酸因氧化损失。 《中国药典》中采用CGC内标法测 Vit E的含量,选择的毛细管柱为100%二甲基聚硅氧烷固定液填。参考文献[2使用Rtx-5型毛细管色谱柱,经实验确定检测器温度为300℃,进样口温度为310℃, 柱温使用程序升温:150℃保持13 min,以10℃min 的升温速率升至300℃,保持8 min,沙棘油中指标性成分能与内标物达到很好的分离并均能被检测出。因沙棘油中化学成分复杂,杂照文献19-101将加入甲醇和氢 氧化钾甲醇溶液后的静置时间分别定为2h和5 min,Vit E与内标物的分离效果更好。考查结果:供试品溶液中沙棘籽油浓度为 0.018gmL", 测得供试品溶液中Vit E浓度为 0.054 mg*mL,即1g油中含3 mg VitE。 ( [参考文献] ) ( [1] 车锡平,关晓红,郭峰,等.沙棘籽油的毒性实验研究[J].沙 棘,2007,20(4):31-33. ) ( [2] 臧茜茜,邓乾春,从仁怀,等.沙棘油功效成分及药理功能研 究进展[].中国油脂,2015,40(5):76-81. ) ( [3] S odergren E , Cederberg J, Vessby B, et al. V i tamin E r e d uces lipid peroxida t ion in experimental he p atotoxicity in r ats[J]. Eu r J Nutr, 2001,40(1 ) :10-16. ) ( [4] 范惠玲,白生文,张芬琴,等.河西走廊5种沙棘果 主 要活性成分及对 ROS清除作用比较分析[J].天然产物研究与开发, 2016, 2 8(1):107-111,163. ) ( [5] 谭晓琳,彭东红.维生素E与儿童哮喘关系的研究进展[].国 际儿科学杂志,2016,43(9):681-684. ) ( [ 6] 蔡乐,姚兰,白林.维A酸软膏中维A酸的含量测定及有关物质的检查[].中国药物应用与监测,2015,12(3 ) :144-146. ) ( [7 ] 张逸,黄凤洪,马方励,等.沙棘油提取工艺研究进展[].中国 油脂,2016,41(3):16-20. ) ( [8 ] 张凤,索有瑞,王洪伦,等.毛细管气相色谱内标法测定沙棘油中的脂肪酸[].中国粮油学报,2008,23(1):198-202. ) ( [9 ] 李娟,周震.超临界二氧化碳萃取沙棘籽油的化学成分分析[. 中国药学杂志,1996,31(1):19-20. ) ( [10]中华人民共和国药典委员会.中华人民共和国药典[S].二部.北京:化学工业出版社,2015:1242-1243. ) ( [11]李奇.大豆油脱臭馏出物中生育酚、甾醇和脂肪酸的提取工艺 研究[D].天津:天津大学,2008:11-16. ) ( [12]毛多斌,贾春晓,孙晓丽,等.几种功能性植物油中角鲨烯和维生素E分析[J].中国粮油学报,2007,22(2):79-82. ) ( (收稿稿期:2017-02-12 修回日期:2017-04-11) ) 临床药师园地栏目介绍 为了更好地积累与借鉴药师参与临床药物治疗经验,我刊特设临床药师园地栏目。 主要刊载内容:1)各科临床用药的典型病例讨论;2)合并多种疾病的患者,特别是存在肝肾功能不全的患者;妊娠、婴幼儿、器官移植等特殊人群的用药选择;3)疑难重症病例、死亡病例讨论;4)抗菌药物的合理选择相关病例;5)在临床实践过程中遇到的具有借鉴意义的典型病例。 文章应包括患者主要病情概况、药物治疗过程、治疗的结论和评估、临床药师的药学监护点等内容。全文4000~5000字左右,药学监护点3~5个,且具有一定的代表性或借鉴意义,分析及讨论应有深度。 ·网址: www.yuweichina.com E邮箱watercom 研究沙棘籽油中脂肪酸成分,定量分析并建立毛细管气相色谱法(CGC)测定沙棘籽油中维生素E(Vit E)含量的方法。方法:采用溶剂回流提取法提取沙棘油中挥发油成分,并用气相色谱-质谱联用法(GC-MS)对其进行定性、定量分析。采用岛津GC-2010 plus气相色谱仪,以正三十二烷为内标物对Vit E进行测定,并对该方法进行方法学考察。结果:从沙棘籽油中分离鉴定出28个化合物;采用Rtx-5毛细管色谱柱(30 m×0.25 mm,0.25μm);柱温为程序升温:150℃保持13 min,以10℃·min(-1)的升温速率升至300℃,保持8 min;FID检测器温度为300℃;进样口温度为310℃;无分流进样。在此条件下,Vit E和内标物分离良好,在0.02~0.43 mg·m L(-1)浓度范围内呈良好线性关系,r=0.999 6。结论:建立以CGC测定沙棘籽油中维生素E含量的方法,灵敏、准确、重复性好,可作为沙棘籽油中Vit E的含量测定方法。
关闭还剩1页未读,是否继续阅读?
北京豫维科技有限公司为您提供《沙棘籽油中维生素E检测方案(毛细管柱)》,该方案主要用于植物油脂和提取物中含量测定检测,参考标准《暂无》,《沙棘籽油中维生素E检测方案(毛细管柱)》用到的仪器有null。
