<< Titration result >> Sample No. 08-06 Date 2017/09/13 11:36:13 Model MKC-710(MCU-710) Time 00:01:07 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 22 mg Catholyte Reagent Name Catholyte Catholyte Life Value 22 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge -一s Cell purge s Sample purge - S Calc.No. 2 Sample name Xylene Sample ID 20170913 Size(Size) * 0.9077 g Size(Wt1)* 0.9077 g Size(Wt2) * 0.0000 g Blank (Blank ) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. (Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume (V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment L Samp.Gas Temp.(Temp.) --Deg.C [Result] Conc. 218.9049ppm Moisture 198.7ug Drift 0.06 ug/s Detection temp. Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) << Titration result >> Sample No. 08-07 Date 2017/09/1311:39:58 Model MKC-710(MCU-710) Time 00:01:04 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 22 mg Catholyte Reagent Name Catholyte Catholyte Life Value 22 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge -一 Cell purge s Sample purge -S Calc.No. 2 Sample name Xylene Sample ID 20170913 Size(Size) * 0.7764g Size(Wt1) * 0.7764 g Size(Wt2)* 0.0000 g Blank (Blank) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. (Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume (V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment L Samp.Gas Temp.(Temp.) --Deg.C [Result] Conc. 218.4441ppm Moisture 169.6ug Drift 0.07 ug/s Detection temp. Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) << Titration result >> Sample No. Model MKC-710(MCU-710) Time 00:01:07 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 22 mg Catholyte Reagent Name Catholyte Catholyte Life Value 22 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge -一s Cell purge s Sample purge . S Calc.No. 2 Sample name Xylene Sample ID 20170913 Size(Size) * 0.8775 g Size(Wt1)* 0.8775 g Size(Wt2) * 0.0000 g Blank (Blank ) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. (Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume (V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment L Samp.Gas Temp.(Temp.) --Deg.C [Result] Conc. 218.1197ppm Moisture 191.4ug Drift 0.07 ug/s Moisture 191.4 Drift 0.07 ug/s Detection temp. ---Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) <
还剩3页未读,是否继续阅读?
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《二甲苯中水分检测方案(卡氏水分测定)》,该方案主要用于苯及其衍生物中水分检测,参考标准《暂无》,《二甲苯中水分检测方案(卡氏水分测定)》用到的仪器有MKC-710S豪华型库仑法卡尔费休水分仪、库仑法卡尔费休试剂。
