质谱学报Journal of Chinese Mass Spectrometry SocietyVol. 34 No. 1Jan.2013第34卷第1期2013年1月 36第34卷质谱学报 热脱附-气相色谱/质谱联用法分析生、炙乳香挥发性成分 吴岳华,周 围²,张雅珩²,魏荣霞 (1.甘肃农业大学食品科学与工程学院,甘肃兰州 730070;2.甘肃出入境检验检疫局综合技术中心,甘肃兰州 730010;3.西北师范大学地理与环境科学学院,甘肃兰州 730070) 摘要:为了研究天然乳香的挥发性成分及生、炙乳香挥发性成分的异同,为乳香挥发油的工艺优化和品质评估提供科学的依据,同时为固体挥发性成分分析提供新思路,采用热脱附气相色谱/质谱联用技术直接对自然状态下乳香颗粒的挥发性成分进行分析。结合NIST 08 标准谱库检索和 Mass WorksTM质谱解析软件的分析结果,在分离出的40余种挥发性成分中,最终确定出20种化学成分。结果表明:生、炙乳香中的挥发性成分主要由单萜、醇及酯类物质构成,其中以醋酸辛酯含量最高,约占挥发性成分的50%;其次为1-辛醇、芳樟醇、乙酸龙脑酯,在生乳香中的含量分别为19.44%、2.27%、2.64%,在炙乳香中的含量分别为9.12%、2.61%、1.33%。 关键词:热脱附(TD);气相色谱-质谱(GC/MS);乳香;挥发性成分 中图分类号:O657.63 文献标志码:A 文章编号:1004-2997(2013)01-0035-05 doi:10.7538/zpxb.2013.34.01.0035 Analysis of Volatile Components of Freshand Cooked Frankincense by Thermal Desorption and GC/MS WU Yue-hua, ZHOU Wei, ZHANG Ya-heng, WEI Rong-xia (1. College of Food Science and Engineering, Gansu Agriculatural University, Lanzhou 730070, China; 2. Central Laboratory of Technical Center, Gansu Entry-Exit Inspectionand Quarantine Bureau, Lanzhou 730010, China; 3. College of Geography and Environment Science, Northwest Normal University, Lanzhou 730070, China) Abstract: In order to make clear the natural volatile composition of frankincense and thedifferences between fresh frankincense and cooked frankincense, to provide a scientific basison improving techniques and evaluating qualities of frankincense volatile oil, and to offer anew method to analyse volatile composition from solid for reference, the volatile compo-nents of natural fresh and cooked frankincense were extracted and determined directly bythermal desorption and gas chromatography-mass spectrometry (GC/MS). More than 40components are separated and 20 components are identified by comparing their mass spectrawith those contained in the NIST mass spectral database and Mass WorksTM software. The ( 收稿日期:2012-08-23;修回日期:2012-11-29 ) ( 作者简介:吴岳华(1986~),女(汉族),硕士研究生,食品营养与卫生专业。E-mail: 3 58843684@q q . com ) ( 通信作者:周 围(1953 ~ ),男(汉族),研究员,从事食品营养及食品安全分析研究。E-mail : zhouwei845@163.com ) results show that the main components includ terpenes, alcohol and esters et al, n-octyl ac-etate is the most important volatile components to frankincense.The normalized peak areasexceed 50% both in fresh frankincense and cooked frankincense,followed by 1-octanol, lina-lool and bornyl acetate, the normalized peak areas in fresh frankincense are 19. 44%,2.27% and 2.64%, in cooked frankincense are 9.12%, 2.61% and 1.33%, respectively. Key words: thermal desorption;GC/MS; frankincense; volatile components 孚香(Boswellia carteri)为橄榄科植物卡氏乳香树 Boswellia carterii Birdw.及同属植物鱼达乳香树 B. bhawdajiana Birdw. 和野乳香树 B. neglecta Moore.树皮渗出的树脂。主产于索马里和埃塞俄比亚,多呈小形乳头状颗粒,淡黄色、质坚脆、性温和、气芳香、味微苦,具有活血止痛、消肿生肌等功效,是一种常用的中药材,其化学成分由树脂(60%~70%)、树胶(27%~35%)和挥发油(3%~8%)3部分成成。关于乳香的研究,前期学者多集中在乳香挥发油的提取纯化、成分分析和医疗功效等方面,但在提取挥发油的过程中,不可避免的引入了有机溶剂,并伴随一些化合物的降解、异构化等副反应,使乳香挥发油的挥发性成分与天然乳香颗粒的挥发性成分有所不同。刘洪玲21使用挥发油提取器按常规回流10h从乳香中提取出挥发油,利用GC/MS联用技术从提取出的挥发油中分离并鉴定出其中的47种化学成分;赵金凤等3采用中国药典2010年版一部附录 XD甲法从3批次乳香中提取出挥发油,利用GC/MS联用技术从提取出的挥发油中共鉴定出100种化学成分;国外学者 Sandrine等5采用固相微萃取气相色谱/质谱(SPME-GC/MS)联用技术,从乳香中分离并鉴定了其中的66种化学成分。目前尚未发现采用热脱附和气相色谱-质谱联用技术直接对天然乳香挥发性成分进行研究的报道。 热脱附技术是集集样、富集、浓缩、进样于一体的样品预处理技术,灵敏度高、重现性好、样品无需前处理,充分保留样品的原状,挥发性组分在高温下从吸附剂或样品本身中释放出来直接进入气质联用系统进行分离分析。该技术与GC/MS 联用为多种无法进行液体萃取的基质提供了分析解决方案,已在环境测试、食品分析、医疗卫生等领域有相关的应用报道16-7。本实验采用热解吸法将自然状态下的乳香颗粒经研磨后直接装入采样管进行热解吸,通过合理地设置解吸温度,充分释放挥发性物质,并结合标准质 谱库(NIST 08s)检索和 Mass WorksTM质谱解析软件等分析手段,对生、炙乳香的挥发性成分进行分析。 实验部分 1.1 样品来源 市售生乳香、炙乳香。 1.2 样品的制备 生乳香样品:取2~3颗生乳香颗粒置于研钵中快速研成粉末,混匀后过60目筛,准确称取10 mg 置于内径为 2 mm的空心玻璃管中,两头用玻璃棉封堵,装入不锈钢采样管中备用。 炙乳香样品:炙乳香样品的制备同1.2.1。 1.3 主要仪器 Agilent 7890A/5975C气相色谱-质谱联用仪:美国Agilent 公司产品;AutoTD 自动热脱附解吸仪、不锈钢采样管(90mm×6.4 mm):中国成都科林仪器公司产品;Mass WorksM质谱解析软件:美国Cerno Bioscience 公司产品。 1.4 实验条件 1.4.1 热脱附条件 载气:高纯氦气(纯度≥99.999%);载气压力:140 kPa;一级解吸时间:5 min,一级解吸温度:180℃;二级解吸时间:5 min,二级解吸温度:200℃;冷阱吸附温度:一30℃;进样时间:60)s;传输线/阀温度:220℃. 1.4.2 气相色谱条件 色谱柱:DB-1701毛细管色谱柱(60m×0.25 mm×0.25pm);载气:高纯氦气(纯度≥99.999%);程序升温:初始温度50℃,保持2min,以5℃/min 的速率升至260℃,保持10 min;进样口温度:250℃;分流比:1:1. 1.4.3 质谱条件 EI 源能量:70eV;MS接口温度:250℃;离子源温度:230℃;四极杆温度:150℃;采样模式:全扫描;EM电压:1576V;质量扫描范围:m/z30~600。以全氟三丁胺(PFTBA)标准品为外标对质谱进行校正。 2 结果与讨论 2.1 实验结果 按照1.4中的实验条件对乳香中的挥发性成分进行分析,得到生乳香、炙乳香的挥发性成分总离子流图,示于图1。 质谱解析软件对质谱图进行校正,模拟计算出组分的精确分子质量,并得到组分的元素组成,综合两种分析方法的结果,最终得到生乳香、炙乳香的挥发性成分质谱解析结果,并按照峰面积归化法计算出各组分的相对百分含量,详细信息列于表1。 利用NIST 08标准谱库检索对乳香中的挥发性成分进行初步定性,然后用Mass WorksM 图1 生乳香(a)和炙乳香(b)挥发性成分的总离子流图 Fig.1 Total ionic current chromatogram of the volatile components of fresh frankincense(a) and cooked frankincense(b) 2.2 乳香的挥发性成分组成 生乳香、炙乳香中的挥发性成分种类相同,主要由单萜、萜烯醇、醇及酯类物质构成,但含量有所不同。单萜类物质主要有α-水芹烯、α蒎烯、烯、香会烯、蒎烯、罗勒烯、松油烯等,在生乳香、炙乳香中分别约占2.1%、5.3%;萜烯醇类物质主要有芳樟醇、α-松油醇等,在生乳香、炙乳香中分别约占2.6%、3.6%;高级醇类物质主要有1-辛醇、月桂醇等,在生乳香、炙乳香中分别约占20.1%、9.7%;酯类物质主要有醋酸辛酯、乙酸龙脑酯、辛酸己酯,在生乳香、炙乳香中分别约占59.3%、54.9%,其中以醋酸辛酯含量最高,约占生、炙乳香挥发性成分的50%。因此认为,醋酸辛酯、1-辛醇、芳樟醇、乙酸龙脑酯等是乳香中最主要的特征挥发性成分。 2.3 热脱附方法的评价 目前芳香植物的挥发性成分分析主要以顶 空、固相微萃取等与气相色谱-质谱联用分析为主81。热解吸法是一种较为新颖的预处理方法,该法将天然乳香颗粒研磨后直接装入样品管在高温下进行解吸,使挥发性成分充分释放,再经冷阱短时聚焦,直接进入气相色谱-质谱体系进行分离分析,不使用吸附剂作为挥发性成分的载体,避免了固相微萃取技术由于不同极性的萃取头对样品中挥发性成分的选择吸附性,且特有的冷阱聚焦功能弥补了顶空-气相色谱法对挥发性成分进行富集的不足,大大提高了灵敏度,改善了谱带展宽的问题,同时克服了蒸馏法、萃取法等传统挥发性成分分离技术,使组分损失多、易造成挥发性成分变化的缺点,并杜绝了溶剂带来的污染19-13]。所得挥发性成分接近人体嗅觉所感觉到的气味,真实地反映了样品挥发性成分的构成。 表1 生、炙乳香主要挥发性成分分析 Table I1dentification of main volatile compositions in fresh frankincense and cooked frankincense 峰 化合物名称 NIST 08 谱库检索 分子式 匹配度检索离子精 (排序)确分子质量 Mass WorkTM 相对百分含量 号 光谱匹配度 CLIPs 中文名 英文名 (排序) 检索离子 生乳香 炙乳香 1 α-水芹烯 a-Phellandrene CioH16 93(1) 136.1252 99.8091(1) M+.1 0.25 0.33 2 a-蒎烯 -Pinene C1o H16 92(1) 136.1261 98.750 3(1) 「M+· 0.28 0.43 3 莰烯 Camphene C10H16 95(1) 136.1259 99.704 4(1) [M+·] 0.45 0.26 4 香桧烯 Sabinene C10 H16 90(1) 136.127 3 98.514 6(3) [M+·] 0.18 0.36 5 β蒎烯 B-Pinene C1o H16 90(1) 136.1252 96.1530(2) [M+·] 0.13 0.21 6 β-香叶烯 B-Myrcene C1oH16 91(1) 136.1264 98.5916(1) M+T 0.06 0.42 7 柠檬烯 Limonene C1oH16 97(2) 136.1252 98.169 0(1) [M+·] 0.15 0.17 8 对伞花烃 p-Cymene C1o H14 93(1) 134.1096 99.3408(1) 0.07 0.08 9 罗勒烯 Ocimene C1o H16 91(2) 136.129 7 99.1529(1) M+· 0.16 0.28 10 桉油精 Eucalypol C10 H18O 97(1) 154.1358 99.479 9(1) M+ 0.55 2.25 11 松油烯 Terpinene C1o H16 92(1) 136.1282 98.169 0(1) [M+·T 0.03 1.09 12 1-辛醇 1-Octanol CgHiO 88(1) 112.1258 98.1560(1) [1 M+-H20] 19.44 9.12 13 芳樟醇 Linalool C10H18O 90(1) 136.1252 97.7530(1) [M+-H20] 2.27 2.61 14 6-甲基-3,5- 戊二烯-2-酮 6-Methylhepta-3,5- dien-2-one Cg H12O 93(1) 124.0888 99.029 1(2) [M+·] 0.05 0.14 15 醋酸辛酯 n-Octylacetate C10 H2002 90(1) 56.56 53.55 16 α-松油醇 Terpineol C1o H1g O 91(1) 136.1252 99.0116(1) [M+·-H20] 0.37 0.98 17 乙酸龙脑酯 Bornyl acetate C12 H2002 97(2) 196.1463 96.798 7(1) [M+·] 2.64 1.33 18 丙酸香茅酯 Citronellol propionate C13 H24O2 89(1) 0.36 0.30 19 月桂醇 l-Dodecanol C12 H26 O 88(3) 168.2523 96.3119(1) M+.-H2O 0.63 0.58 20 辛酸已酯 Hexyloctanoate C14H2802 90(1) 0.09 0.06 2.4 定性方法的特点 GC/MS利用保留时间和 NIST 谱库检索对化合物进行定性是目前应用最为广泛的一种定性手段。但由于低分辨率的四极杆质谱只能给出化合物的整数质量,对未知物的定性分析往往依靠谱库检索结果匹配度的高低而定,谱库检索结果的匹配度又严重依赖于 GC 的分离效果,色谱分离不佳会使匹配结果不准或难以匹配,尤其是含量较低和未得到彻底分离的组分,其定性分析易受干扰。此外,异构体、同系物和结构特征相似的化合物谱图往往非常相似,谱库检索会给出几个匹配度相近的候选物,给未知物的准确鉴定带来很大困难14]。因此,仅靠谱库检索给未知化合物定性存在很大的不确定性。Mass WorksTM质谱解析软件利用同位素峰形校正检索技术(calibrated lineshape isotope pro-file,CLIPs),通过建立元素组成已知的一个或多个离子生成的校准函数,对样品质谱峰的精确质量数(质量准确度)和同位素峰形(谱图准确 度)同时进行校正匹配15-16],实现对未知化合物分子式的识别,大大提高了低分辨质谱定性的准确度17-21]。在使用 Mass WorksTM质谱解析软件时,根据从重原则和氮规则,对质谱图最右侧的质荷比为偶数的碎片离子进行 CLIPs 检索,若该碎片是分子离子,则直接得到该化合物的元素组成和精确分子质量,并借助 NIST 谱库的反检索功能获得该化合物的结构以及化合物名称,若该碎片不是分子离子,则无法直接推断该化合物的元素组成和精确分子质量,但结合不同物质的质谱裂解一般规律,可以对特征碎片进行 CLIPs检索,再反推分子离子。如伯醇类物质经EI 源电离后不产生分子离子,会产生稳定的 CH2=O+H(m/z31)碎片离子和[M+-H2O]奇电子离子[22]。观察峰号为12(1-辛醇)、13(芳樟醇)、16(a-松油醇)、19(月桂醇)的质谱图,均有明显的m/z31 特征碎片离子,经NIST 谱库检索,依次初步定性为1-辛醇、芳樟醇、α-松油醇和月桂醇,但匹配率均不高。利用 Mass WorksM软件 分别对该4种物质的质谱图靠右侧的碎片离子进行 CLIPs 检索,得到元素组成为CgH16、C1oH16、CioH16、Ci2 H24,依次在每个碎片的基础上加 HzO,得到元素组成为 Cg H18O、C1oH1gO、C1o H1gO和 C1o H26O的化合物,借助 NIST 谱库的反检索功能依次确定为l-辛醇、芳樟醇、松油醇、月桂醇,由此可见,经CLIPs 检索的碎片离子为[M+-HzO]离子,符合伯醇裂解的一般规律。经 NIST 谱库检索和 Mass WorksTM质谱解析软件双重定性,大大提高了定性的可靠性。 3 小结 热脱附技术采用固体样品直接进样,消除了萃取溶剂产生的干扰,通过两级解吸充分捕集挥发性成分,更真实和直接地反映了乳香挥发性成分的构成,并综合标准质谱库(NIST 08s)检索和Mass WorksM质谱解析软件的分析结果,在低分辨的四极杆质谱上实现了对精确质量数的测定,大大提高了低分辨质谱定性的可靠性,同时热脱附与 GC 和 GC/MS 的联用大大拓展了GC 和 GC/MS的分析范围,为固体挥发性成分分析提供了新思路。 ( 参考文献: ) ( [1 ] 江苏新医学院.中药药辞典[M].上海:上海科技 出版社,1986. ) ( 21 刘洪玲.乳香挥发油化学成分的气相色谱-质谱分析[J].时珍国医国药,2009,20(2):370-371. ) ( [3] 赵金凤,周春兰,周凤琴,等.乳香发性成分 GC-MS分析[J].中国中药杂志,2001,36(8):1050- 1 0 53. ) ( [4] 夏华玲,赵新杰.乳香挥发油化学成分的GC-MS分析[J] . 中草药,2003,34(2):119. ) ( [5] HAMM S , BLETON J , CONNAN J, e t a l. A chemical investigation by headspace SPME and GC-M S of vo l atile and semi-vo l atile terpenes i n various olibanum s amples [J]. P h ytochemistry, 2005, 6 6:1 4 99-1 5 14. ) ( [6] 杜学伟,王 铠,杜光尧,等.热脱附/冷阱聚焦/气相色谱/质谱法卷烟香气分析[J].分析测试技术与仪器,2007,13(1):33-4 0 . ) ( [7] 谭培功,于彦彬.热脱附气相色谱-质谱联机定量分析气体中的亚磷酸三甲酯[J].分析化学,1996,24 ) ( (1):116. ) ( 8 杨 莉.不同顶空分析法对植物挥发物测定的影响[D] . 北京:北京林业大学,2007,9-23. ) ( [ 9 ] 虞伊林,王秋云,姚 雷.玫瑰自然香气成分及含量变化分析[J].上海交通大学学报,2012,29(2): 80-87 ) ( 1 0 7 程伟娜,郭景琦,黄映风,等.热解析-气相色谱-质谱法测定烟草中的低低点点分J].浙江大学学报,2009,36(2):186-190. ) ( 1 1 7 李德文,何兴元,史 奕.热解析-气相色谱法测定植物源挥发性有机物[J].分析化学,2008,36 (12):1690-1 6 94. ) ( 12 冯 青,高群英,张汝民,等.3种百合科植物挥发物成分分析[J].浙江农林大学学报,2011,28 (3):513- 5 18. ) ( [ 13] 陈云霞,梁 冰,王国俊.吸附浓缩/热脱附技术进展[J].分析测试技术与仪器,1999,5(1):9-14. ) ( 14 李 斌,周 围. MassworksM与气相色谱-质谱联用分析洋甘菊精油成分[J] . 质谱学报,2011, 32( 4 ):241-245. ) ( [ 15] WANGY D,GU M. Th e concept of spectral accu- racy for MS[J]. Anal Chem,2010,82(17):7055. ) ( [16] 钱建钦,胡昌勤.高效液相色谱-单四极杆质谱仪结合同位素峰形校正检索技术快速确定头孢呋辛水溶液降解杂质[J]. 药 物分析杂志,2012,32 (9):71- 7 9. ) ( [ 17 ] 周 围,李卫建. M ass Works 结合单位分辨质谱识别喹诺诺类药物分子式[J] . 质谱学报,2009,30(增刊):126-130. ) ( [ 18] 李卫健,袁有荣,欧阳伟民,等. Masswork s 分子式识别技术在质谱中的应用[J] . 现代仪器, 2010,16(5):11- 1 4. ) ( [19] ZHOU W, ZHANG Y H, XU H L, et al. De- termination of elemental composition o f v olatileorganic compounds from Chinese r o se oil by spec-tral accuracy and mass accuracy[J ] .Rapid Com-mun M ass Spectrom,2011,25(20):30 9 7-3102. ) ( [20] 李雪生,李子昂,王正全,等.精确质量数在单四级杆质谱定性分析农药中的应用[J].高等学校化学学报,2010,31(12):2383. ) ( 2 1] 刘 可,马 彬,王永东,等 . 一种新软件方法用于单位分辨质谱仪上药物相对分子量的准确测定[ J ] . 药学学报,2007,42(10):1112. ) ( 227 王光辉,熊少祥.有机质谱解析[ M ].北京:化学 工 业出版社,2004:84-89. )
关闭还剩3页未读,是否继续阅读?
成都科林分析技术有限公司为您提供《生炙乳香中乙酸龙脑酯检测方案(热解吸仪)》,该方案主要用于中药材和饮片中含量测定检测,参考标准《暂无》,《生炙乳香中乙酸龙脑酯检测方案(热解吸仪)》用到的仪器有AutoTD自动热脱附解吸仪。
