当前位置: 饲料 > 营养成分 > 方案详情
动物饲料中Ca元素检测方案(原子吸收光谱)
检测样品 饲料
检测项目 营养成分
关联设备 共0种 下载方案
方案详情
采用连续光源火焰原子吸收法对动物饲料中Ca进行测定,加入合适的镧盐和铯盐去除干扰,通过对标准物质的测量,验证了方法的准确性,得到了满意的测试结果,连续光源火焰原子吸收测试多种元素快捷方便,节省大量时间和消耗成本。
analytikjenaAGanalytical solutions 10/2003 AA_FI_08_03e Short Application Flame-AAS Determination of Na, K, Ca, and Mg in animal feed Experimental The samples were prepared according to the investigation instruction for animal feed(Ashing and dissolvation in HCI) and were measured with the novAA 400F. To minimize matrix effects, the samples and the calibration standards for thedetermination of all elements were added with 0.2 % CsCI/LaCle. Method parameter Element Wavelengthsnm Slitnml Flametype Gas flowburner [I/h] Burnerangle[] Burner heightmm Na*K*CaMg 589.0766.5422.7 0.20.21.2 C2H2/ Air 60 00 C2H2/ AirC2H2/ Air 6060 285.2 0.5 C2H2/Air 70 0 7 *Measurements of emission (AM by Na with 1.0 mg/l, AM by K with 1.5 mg/l) Calibration Na Standard calibration Conc. of the calibration standards 0.10/ 0.20/0.30/0.40/0.50 mg/I Nain 0.4 % HCI, 0.2 % CsCI/ LaCls 1 blind cycle/ 4 measurement cycles Repeating build of mean, non-linear calibration curve K Standard calibration Conc. of the calibration standards 0.30/0.60/ 0.90/1.20/ 1.50 mg/I K in 0.4%HCI, 0.2%CsCl/ LaCl3 1 blind cycle/ 4 measurement cycles Repeating build of mean, non-linear calibration curve 10/2003AA FI 08 03 e Ca Standard calibration Conc. of the calibration standards 1.0/ 2.0/ 4.0/8.0/ 12.0 mg/I Cain 0.4% HCI, 0.2 % CsCI/LaCls1 blind cycle/ 4 measurement cyclesRepeating build of mean, non-linear calibration curve Mg Standard calibration Conc. of the calibration standards 0.05/ 0.10/ 0.15/0.20/0.30 mg/I Mgin 0.4%HCI, 0.2%CsCI/ LaCls 1 blind cycle/ 4 measurement cycles Repeating build of mean, non-linear calibration curve Results Element Sample Dilution factor CertifiedConc.[g/kg] MeasuredConc.[g/kg] RSD %] Na K3 200 0.93(0.75-1.14) 1.02±0.03 0.3 K K3 200 7.09 (5.97-8.35) 7.40±0.04 0.6 Ca K3 20 6.29 (5.04-8.02) 6.21±0.04 0.2 Mg K3 200 1.58(1.40-1.77) 1.55±0.01 0.5 10/2003 AA FI 08 03 e Remark The determination of Na, K, Ca, and Mg in animal feed according to the dissolvationinstruction can be easily performed with flame AAS. During the determination the user should take care that the measurement solutionsmust contain lanthanum. In our experiments not containing lanthanum, lower findingscould be observed (e.g.: for Na and K) by special sample components like phosphateor others. For this investigation, no blind samples were delivered for the digestions. Therefore,and because of a small contamination of the used digestion solvent, the results couldbe improved, especially for Na and K. Stand
关闭
  • 1/3
  • 2/3
还剩1页未读,是否继续阅读?
继续免费阅读全文
产品配置单
耶拿分析仪器(北京)有限公司为您提供《动物饲料中Ca元素检测方案(原子吸收光谱)》,该方案主要用于饲料中营养成分检测,参考标准《暂无》,《动物饲料中Ca元素检测方案(原子吸收光谱)》用到的仪器有null。
我要纠错
相关方案
