检测样品 饮用水
检测项目 有机污染物
参考标准 GB/T 5750 生活饮用水标准检验方法
银牌会员 474 篇解决方案
北京豫维科技有限公司联系人:水先生电话:18911849923《环境卫生学杂志》2016年4月第6卷第2期Journal of Environmental Hygiene Apr. 2016, Vol.6 No.2 检验技术与方法研究】 吹扫捕集气质联用法测定饮水中挥发性有机物 朱芸 雒婉霞 赵清荣 杨雪丽 王庆国 杨勤德 摘要:目的 建立吹扫捕集气质联用(P&T-GC/MS)方法测定《生活饮用水卫生标准》(GB 5749-2006)中规定的12种挥发性有机物( VOCs)。方法 饮用水中的微量有机物经吹扫捕集提取后,HP-VOC 毛细管色谱柱进行程序升温分离,质谱选择离子监测方式分析检测饮用水中12种挥发性有机物,外外法定量。结果 12种挥发性有机物的线性范围为0.4 pg/L~100.0 ug/L,浓度范围内的线性相关系数为0.998 ~0.999,检出限为0.011 pg/L~0.196 ug/L,相对标准偏差( RSD) 2.37% ~6.29%(n=11),加标回收率为78.0%~119.5%。结论 该方法适用于饮水中12种挥发性有机物的同时测定。 关键词:生活饮用水;气质联用;吹扫捕集;挥发性有机物 DOI: 10. 13421/j. cnki. hjwsxzz. 2016.02.012 Volatile Organic Compounds Determination in Drinking Water byGC/MS Spectrometry with Puffing and Trapping Samples ZHU Yun, LUO Wanxia, ZHAO Qingrong,YANG Xueli, WANG Qingguo, YANG Qinde Abstract: Objective To establish a method for the determination of 12 kinds of volatile organic compounds(VOCs)in drinking water simultaneously by gas chromatography-mass spectrometry with puffing and trapping sam-ples ( P&T-GC/MS). Methods Twelve kinds of volatile organic compounds ( VOCs) in drinking water based onthe Standards for Drinking Water Quality ( GB 5749-2006) were separated by HP-VOC capillary column with tem-perature programming, detected by gas chromatography- mass spectrometry with puffing and trapping samples, andquantified by using external standards. ResultsThe linear range for VOCs was 0.4 ug/L~100.0 pg /L (r=0.998~0.999); the detection limits were 0.011 pg/L~0.196 ug /L; the relative standard deviation was 2.37%~6.29%(n=11); and the spiked recovery were 78.0%~119.5%. Conclusions This method were suitable forsimultaneous determination of 12 kinds of volatile organic compounds in drinking water based on the regulation inthe Standards for Drinking Water Quality. Keywords: drinking water; GC/MS; puffing and trapping, volatile organic compounds (VOCs) 挥发性有机物(VOCs) 是一类沸点小于200℃,相对分子质量在16~250的有机化合物的统称,是水中重要的一类污染物。这类化合物性质稳定,不易分解,具有强致癌性、致生殖系统毒害性及致突变 2007年7月实施的《生活饮用水卫生标准》(GB5749-2006)将原来毒理指标中的有机化合物由5项增至53项,其中包括多种挥发性有机物。 对于 VOCs 的检测方法在《生活饮用水标准检验方法》( GB/T5750-2006)3中常采用溶剂萃取、静态顶空等方法,不利于多组分同时测定,且灵敏度和精密度较差。吹扫捕集气相色谱一质谱联用技术因其定性程度高,定量准确的优点,被广泛用于水中 VOCs的分析,为此采用吹扫捕集气相色谱一质谱联用法同时测定消毒副产物(其中二氯甲烷项目 北京豫维科技有限公司联系人:水先生电话:18911849923 在《生活饮用水用准检标方法》( GB/T 5750 -2006)中为消毒副产物指标,但是均在《水质指标补充检验方法手册》中的挥发性有机物的方法中)和有机物类别中 12种 VOCs,提高了分析效率。 材料与方法 1.1 仪器设备 Agilent 7890A -5975C气质联用仪(美国安捷伦公司)、Tekmar 全自动吹扫捕集进样装置、HP-VOC毛细管柱(60m× 0.32 mm ×1.80 pm)Milli-Q超纯水机(美国密理博公司)、带聚四氟乙烯( PTFE) 内衬螺旋盖40 mL棕色玻璃样品瓶(美国Tekmar公司)、Eppendorf移液器。 1.2 试剂 超纯水(经检测无本试验中的12种 VOCs);12种VOCs 单标储备液,除氯苯购自环境保护部标准样品研究所、六氯丁二烯购自农业部环境保护科研检测所外,其他标准品均购自中国计量科学研究院。将12种挥发性有机物单标储备液用甲醇(购自赛默飞世尔公司)稀释成混合标准中间液(表1)。 表1 甲醇中 VOCs 单标储备液和混合标准中间液质量浓度 序号 化合物 单标标准储备液/ 混标标准中间液/ (mg/mL) (ug/mL) 1 二氯甲烷 1.19 11.9 2 1,1-二氯乙烷 1.02 10.2 3 四氯化碳 1.00 10.0 4 苯 0.96 9.60 5 甲苯 0.99 9.90 6 氯苯 1.00 10.0 7 乙苯 1.00 10.0 8 间二甲苯 1.01 10.1 9 对二甲苯 1.00 10.0 10 苯乙烯 1.00 10.0 11 邻二甲苯 1.00 10.0 12 六氯丁二烯 0.50 10.0 1.3 样品前处理 将居民家中的末梢水放水15 min 后,用预先加入0.5g抗坏血酸的玻璃1L采样瓶中采样,密封立即带回实验室4℃冷藏。测定时将样品倒入带聚四氟乙烯内衬螺旋盖的40 mL 棕色玻璃样品瓶中,立即旋紧瓶盖后顶部不能留有空气,12h内检测,按1.4的条件进行测定。 1.4 测定条件 1.4.1 色谱柱 HP-VOC(60 m x 0.32 mm ×1.80 um)弹性石英毛细管柱;进样口温度:180℃; 柱温:初始温度35℃,保持5 min,再以6℃/min 升温至150℃,保持4 min,再以 20℃/min 升温至235℃,保持2min;载气:高纯氦气;离子源温度:230℃;传输线温度:280℃;四级杆:150℃;离子化方式(电压):EI(70eV);柱流量:1.0 mL/min;分流比20:1;扫描方式:SIM。 1.4.2 Tekmar 吹扫捕集条件 吹扫气体:高纯氮气;吹扫温度:22℃;吹扫气体的流速:40 mL/min;吹扫时间:11 min;解吸温度:225℃;解吸反吹气体流速:15 mL/min;解吸时间:3 min;烘烤温度:260℃;烘烤时间:4 min。 1.5 标准曲线的绘制 1.5.1 混合标准中间液的配制 准确吸取各单标储备液1mL,其中六氯丁二烯为2 mL,置于100 mL容量瓶中用超纯水定容至刻度,混合标准中间液浓度见表1。 1.5.2 混合标准使用液的配制 准确吸取1mL混合标准中间液,置于100 mL 容量瓶中用超纯水定容至刻度。将混合标准中间液按照表2稀释得到混合标准使用液。分别倒入带有聚四氟乙烯内衬螺旋盖的40 mL 棕色玻璃样品瓶装满,拧紧瓶盖后样品瓶内不得有气泡,按照1.4的条件上机测定待测。以系列标准溶液中目标化合物的质量浓度为横坐标,相对应的峰面积为纵坐标绘制标准曲线。标准系列质量浓度见表2。 1.6 样品测定 将待测水样于带聚四氟乙烯内衬螺旋盖的40 mL棕色玻璃样品瓶中装满,立即旋紧瓶盖后样品瓶内不得有气泡。使用1.4中的仪器方法进行测定,根据保留时间和离子丰度比定性,定量离子峰面积定量,外标法计算水样中有机物质量浓度。 2 结果 2.1 吹扫捕集条件的优化 2.1.1 优化吹扫温度 其他吹扫捕集条件不变,用10.0 pg/L标准溶液多次进样,将吹扫温度分别设定为18℃,20C,22℃,24℃和26℃,回收率指标评价,结果表明吹扫温度18℃~26℃回收率无显著性差异,所有目标化合物有满意的回收率,所以采用常年平均室温22℃作为吹扫温度。 2.1.2 吹扫时间 吹扫温度为22℃,其他条件不变,分别设定7 min,9 min,11 min,13 min 和 15 min 吹扫时间多次测定10.0 pg /L标准溶液。当11 min~ 表2 12种挥发性有机物混合标准系列的配制浓度 ug/L 序号 化合物 系列1 系列2 系列3 系列4 系列5 系列6 1 二氯甲烷 0.476 1.19 11.9 23.8 47.6 119 2 1,1-二氯乙烷 0.408 1.02 10.2 20.4 40.8 102 3 四氯化碳 0.400 1.00 10.0 20.0 40.0 100 4 苯 0.384 0.96 9.60 19.2 38.4 96.0 5 甲苯 0.396 0.99 9.90 19.8 39.6 99.0 6 氯苯 0.400 1.00 10.0 20.0 40.0 100 7 乙苯 0.400 1.00 10.0 20.0 40.0 100 8 间二甲苯 0.404 1.01 10.1 20.2 40.4 101 9 对二甲苯 0.400 1.00 10.0 20.0 40.0 100 10 苯乙烯 0.400 1.00 10.0 20.0 40.0 100 11 邻二甲苯 0.400 1.00 10.0 20.0 40.0 100 12 六氯丁二烯 0.400 1.00 10.0 20.0 40.0 100 15 min 吹扫时间时大部分部目标化合物的回收率都能在80%以上。为提高工作效率,选择11 min 作为吹扫时间。 2.1.3 吹扫流量 吹扫温度22℃,吹扫时间11 min,其他条件不变分别设定吹扫流量(30mL/min,40 mL/min和50 mL/min),多次测定10.0 ug /L标准溶液,回收率结果表明,40 mL /min 流量时,所有目标化合物回收率最大。 2. 1.4 解析温度 其他吹扫条件保持不变,吹扫温度22℃,吹扫时间11 min,分别设置205℃,215℃,225℃,235℃和245℃解吸温度下多次测定10.0 ug/L标准溶液。实验结果表明,225℃色谱峰分离较好、解吸效率较高。在优化过程中解吸温度关键点是,对方法的重复性和准确性影响很大。 2.1.5 解析时间 吹扫温度22℃,吹扫时间11min,解析温度225℃,其他吹扫条件不变,解析时间分别试验了2 min,3 min,4 min 和5 min,测定10.0 pg/L标准溶液,回收率结果表明3 min~5 min解吸时间,解吸效率较好,选择3 min 为解吸时间。 2.1.6 烘烤时间和烘烤温度 其设定目的在于去除前一针的污染和提高捕集阱的吸附活性。在烘烤温度260℃、烘烤时间4 min 的条件下测定10.0 ug /L标准溶液,之后用无 VOCs 空白纯水进样,均低于目标化合物检出限水平。 2.2 12种挥发性有机物的定性 为提高目标化合物的灵敏度、降低干扰,采用选择离子监测方式(SIM),每种化合物选择了1~3个特征离子进行监测,1个定量离子,1~2个定性离子。同时参考离子丰度比和保留时间,对样品中存在的 VOCs 进行定性定量分析。其中间二甲苯和对 二甲苯出峰位置重合且特征离子相同,由于《生活饮用水卫生标准》中只对二甲苯总量规定限值,所以两者重合不影响其监测。12种挥发性有机物的混合标准溶液 TIC 谱图见图1。 注:1一二氯甲烷;2一1,1-二氯乙烷;3一四氯化碳;4一苯; 5一甲苯;6一氯苯;7一乙苯;8一间二甲苯;9一对二甲苯;10一苯乙烯;11一邻二甲苯;12一六氯丁二烯 图1 12种挥发性有机物的混合标准溶液 TIC谱图 2.3 线性范围检出限及检测限 按照1.4中的仪器条件,根据标准系列浓度,以定量离子的峰面积定量,求得线性回归方程及相关系数。以仪器3倍噪声值表示方法的检出限,其对应的浓度即为最低检出浓度(表3)。 2.4 精密度和回收率试验 本实验中所采集的生活饮用水中,均检出了四氯化碳和二氯甲烷。取11份平行水样分别加入10.0 pg/L 的12种 VOCs 混合标准溶液,作为加标回收和精密度(表4)。 2.5 操作注意事项 样品的储存与输送过程中,可能会因 VOCs 的扩散而造成污染,因此用现场空白样检测污染干扰的程度,即在样品采集、储存、运输的过程中,携带 表3VOCs 保留时间、定量离子、定性离子、线性范围、标准曲线、相关系数、检出限 序号 化合物 保留 定量 定性 线性范围/ 标准曲线 相关系数 检测限/ 检出限/(ug/L) 时间/min 离子 离子 (ug/L) (pg/L) 外标 内标 1 二氯甲烷 10.096 84 86、490.476~119 Y=6619x+2 336 r=0.999 0.588 0.196 0.173 2 1,1-二氯乙烷 11.869 62 98 0.408~102 Y=343.0x-8.991 r=0.999 0.501 0.167 0.156 3 四氯化碳 14.777 117 1190.400~100 Y=2908x-867.4 r=0.998 0.294 0.098 0.130 4 苯 15.487 78 77 0.384~96.0 Y=7 210x-7665 r=0.999 0.051 0.017 0.078 5 甲苯 19.884 92 91 0.396~99.0 Y=4556x-10250 r=0.998 0.042 0.014 0.230 6 氯苯 23.076 112 77、114 0.400~100 Y=6951x-1187 r=0.999 0.054 0.018 0.125 7 乙苯 23.431 91 106 0.400~100 Y=8 993x-20 950 r=0.999 0.039 0.013 0.120 8 间二甲苯 23.715 106 910.404~101 Y=7 589x-10 870 r=0.999 0.039 0.013 0.100 9 对二甲苯 23.715 106 910.400~100 Y=7 589x-10 870 r=0.999 0.039 0.013 0.100 10 苯乙烯 24.566 104 78 0.400~100 Y=7 792x-19 740 r=0.998 0.033 0.011 0.125 11 邻二甲苯 24.637 106 910.400~100 Y=4 116x-3 900 r=0.999 0.036 0.012 0.066 12 六氯丁二烯 34.212 225 2600.400~100 Y=1985x-3354 r=0.998 0.252 0.084 0.121 表412种VOCs 加标回收和精密度(n=11) 序号 化合物 加标量/(ug/L) 平均回收率/% 精密度/(10.0 ug/L) 外标 内标 外标 内标 1 二氯甲烷 10.0 78.0 103 2.37 6.5 2 1,1-二氯乙烷 10.0 97.5 97 3.68 6.7 3 四氯化碳 10.0 119.5 95.8 6.29 5.3 4 苯 10.0 92.0 98.4 3.98 5.4 5 甲苯 10.0 94.0 101 4.43 6.5 6 氯苯 10.0 92.0 98.9 3.43 2.8 7 乙苯 10.0 98.0 95.0 5.30 5.7 8,9 间、对二甲苯 10.0 102 102 4.16 8.9 10 苯乙烯 10.0 89.5 96.3 3.74 4.7 11 邻二甲苯 10.0 99.5 104 3.34 6.5 12 六氯丁二烯 10.0 103 94.6 5.80 6.0 一个不含有机物高纯水伴随储存或者运输过程。 样品存放区域和仪器分析室不能有溶剂污染,如实验室常用的二氯甲烷、四氯化碳、三氯甲烷等。二氯甲烷会穿透聚四氟乙烯管进入样品,造成污染。 本底污染可能来自吹扫捕集系统的吹扫管、捕集阱、容剂、试剂、玻璃器皿等,在分析样品之前都要做试剂空白,确保没有污染。 3 结论 国内文献18-10多采用吹扫捕集气相质谱联用内标法测定地下水、地表水及饮用水中挥发性有机物。本方法采用外标法针对《生活饮用水卫生标准》GB5749-2006)中规定的12种 VOCs 指标建立方法,大部分 VOCs 检测结果表明检出限和精密度以及回收率指标等同于内标法相关检测结果。本法操作简便、灵敏、快速,分离效果好。从实验成本来看,标准溶液和所有待测样品的检测都需要加 入等量内标,在日常实验中内标使用量较大。而外标法避免了昂贵内标的使用而大大降低了实验成本,在实际工作中被广泛应用的价值较高。除此之外实验过程不需使用有机溶剂,减少了水和环境的二次污染。质谱选择离子扫描( SIM)可以消除与目标化合物保留时间相近的其他离子造成的干扰,对于同时检测多种目标化合物的样品可以得到较好的实验结果。本方法可基本满足《生活饮用水标准检验方法》( GB 5749-2006)中有机物指标和消毒副产物指标中检出限的要求,适用于实际样品的分析。为《生活饮用水卫生标准》中规定的12种VOCs检测提供吹扫捕集气相质谱联用外标法的可行性范例。 ( 参考文献 ) ( [1] 刘兰侠,张燕,倪蓉,等.自动顶空一毛细管气相色谱法测定饮用水中11种挥发性有机物[].上海预防医学,2014,26 (1):27-28. ) ( [2] 中华人民共和国卫生部,中国国家标准化管理委员会. GB ) ( 5749-2006生活饮用水卫生标准[S].北京:中国标准出版 社,2007. ) ( [3] 中华人民共和国卫生部,中国国家标准化管理委员会. GB/T5750-2006生活饮用水标准检验方法[S].北京:中国标准出版社,2007. ) ( [4] 张民.吹扫一捕集法在挥发性有机污染物分析中的应用.环境污染治理技术与设备,2002,3(11):31-37. ) ( [5] 钱志荣,陈祝军,吴建兵.吹扫捕集气相色谱-质谱联用测定饮用水中17种挥发性有机物[].上海预防医学,2014,26 (12):689-692. ) ( [6] 周华,张蕴,金莞尔,等.吹扫捕集-气质联用技术测定饮用水中55种挥发性有机物.中国卫生检验杂志,2014,24 (18):2604-2608. ) ( (上接第139页) ) ( [2] 杜克梅,雷芳,吴霓,等.我国东海和南海近岸海域麻痹性贝类毒素污染状况[暨南大学学报(自然科学版),2013,34 (3) : 343-346. ) ( [3] 林祥田,张明生,王志坚,等.连云港海州弯麻痹性贝类毒素中毒分析叨.中国食品卫生杂志,2005,17(3):243-246. ) ( [4] 刘用锦,林旭.一起麻痹性贝类毒素中毒的调查.海峡预 防医学杂志,2001,7( 3 ): 35. ) ( [5] 吴蕙岭,章荣华,宋燕华,等.两起疑似织纹螺中毒事件的实验室调查.中国卫生检验杂志,2010,20(12):3455-3456. ) ( [6] 刘智勇,计融.各国贝类水产品中麻痹性贝类毒素限量标准的比对[.中国热带医学,2006,6(1):176-178. ) ( [7] 中华人民共和国农业部. SC/T 3023 -2004无公害食品麻痹性贝类毒素的测定生物法[S].北京:中国农业出版 社,2004. ) ( [8] 中华人民共和国卫生部,中国标准标管理委员会. GB/T5009.213-2008贝类中麻痹性贝类毒素的测定[S]. 北 京:中国标准出版社,2009. ) ( [9] 吴蓓莉,钟惠英,邱结琼,等.麻痹性贝类毒素的生物法与酶联免疫法测定比较比.宁波农业科技2014,(3):14-17. ) ( [10] 中华人民共和国国家进出口商品检验局.SN/T1735-2006 ) ( [7] 芮振荣,盛英杰,卢大胜,等.吹扫捕集气相色谱分析水中挥发性卤代代类有机物研究勿.上海预防医学,2006,18(12): 619-620. ) ( [8] 冯丽,李诚,张彦,等.吹扫捕集/气相色谱一质谱法测定地下水 中30种挥发性有机物有.岩矿测试,2012,31(6):1037-1042. ) ( [9] 李国媛.吹扫捕集 一 气相色谱/质谱法测定水中27种挥发性有机物叨.环境科学导刊,2012,31(3):88-90,93. ) ( [10] 韩翠英,孟娟,程素敏,等.吹扫捕集 一 气相色谱/质谱法测定地下水中27种发性有机物[.微量元素与健康研究, 2011,28( 2):38-40. ) ( [11] 彭敏,周亚民,彭小兰.吹扫捕集一气相色谱一质谱联用测定水中挥发性芳烃化合物[.上海预防医学,2008,7(6):359- 360,362. ) ( 进出口贝类产品中麻痹性贝类毒素检验方法高效液相色谱法 [S].北京:中国标准化管理委员委,2006. ) ( [11] 中华人民共和国国家质量监督检验检疫总局,中国国家标准化管理委员会. GB/T23215-2008贝类中多种麻痹性贝类毒素含量的测定液液色谱-荧光检测法[S].北京:中国标准化管理委员会,2008. ) ( [12] 刘红河,刘桂华,毛丽莎.麻痹性贝类毒素的高效液相色谱-串联质谱测定方法研究[].实用预防医学,2008,15(4): 1024-1027. ) ( [13] 刘红河,杨俊,陈裕华,等.亲水作用液相色谱/串联质谱联用法测定海产品中麻痹性贝类毒素[.现代预防医学,2010, 37(7):1328-1332. ) ( [14] 于慧娟,蔡友琼,黄宣运,等.10种麻痹性贝类毒素的固相萃取及液相色谱-串联质谱测定法[.海洋渔业,2015,37 (4):364-371. ) ( [15] 母清林,方杰,王晓华,等.液相色谱-串联质谱法检测贝类产品中麻痹性贝类毒素叨.中国环境监测,2013,29(2):58-61. ) ( [16] M attarozzi M ,Milioli M , Bi a nchi F, e t al. Optimization of a rap i d QuEChERS sample treatment me t hod for HI L IC-MS’ analysis ofparalytic shellfish poisoning ( PSP) toxins in mussels [ J ]. F o od Control , 2016, 6 0 :138-145. ) ·?址:dewwwunyuweichinahircomsEmails:eswatercom 吹扫捕集气质联用法测定饮水中挥发性有机物目的建立吹扫捕集气质联用( P&T - GC /MS) 方法测定《生活饮用水卫生标准》( GB/T 5750 -2006) 中规定的12 种挥发性有机物( VOCs) 。方法饮用水中的微量有机物经吹扫捕集提取后,HP-VOC 毛细管色谱柱进行程序升温分离,质谱选择离子监测方式分析检测饮用水中12 种挥发性有机物,外标法定量。结果12 种挥发性有机物的线性范围为0. 4 μg /L ~ 100. 0 μg /L,浓度范围内的线性相关系数为0. 998 ~0. 999,检出限为0. 011 μg /L ~ 0. 196 μg /L,相对标准偏差( RSD) 2. 37% ~ 6. 29% ( n = 11) ,加标回收率为78. 0% ~ 119. 5%。结论该方法适用于饮水中12 种挥发性有机物的同时测定。
关闭还剩3页未读,是否继续阅读?
北京豫维科技有限公司为您提供《饮用水中挥发性有机物 1,1 - 二氯乙烷检测方案(专用色谱柱)》,该方案主要用于饮用水中有机污染物 检测,参考标准《GB/T 5750 生活饮用水标准检验方法》,《饮用水中挥发性有机物 1,1 - 二氯乙烷检测方案(专用色谱柱)》用到的仪器有null。
