水中氯贝酸检测方案(液质联用仪)
检测样品 环境水(除海水)
检测项目 有机污染物
关联设备 共1种 下载方案
方案详情
The Agilent 1290 Infinity Flexible Cube module has enabled a fully automated online SPE extraction LC/MS/MS method for ng/L level detection and quantitation of 34 trace organic compounds (pharmaceuticals, personal-care products, pesticides, perfluorinated compounds and so forth) in a wide variety of water sources. It requires only 1.7 mL of sample and provides a cycle time less than 15 minutes, enabled in part by the simultaneous positive and negative ionization feature of the Agilent 6460 Triple Quadrupole LC/MS. The automated online sample preparation embodied in this method provides unparalleled throughput and reproducibility, as well as time, labor, and solvent savings.
Automated Online SPE forLC/MS/MS Analysis of TraceOrganic Contaminants in WaterUsing the Agilent 1290 InfinityFlexible Cube Module Abstract: The Agilent 1290 Infinity Flexible Cube module has enabled a fully automated online SPE extractionLC/MS/MS method for ng/L level detection and quantitation of 34 trace organic compounds(pharmaceuticals, personal-care products, pesticides, perfluorinated compounds and so forth) in awide variety of water sources. It requires only 1.7 mL of sample and provides a cycle time less than15 minutes, enabled in part by the simultaneous positive and negative ionization feature of theAgilent 6460 Triple Quadrupole LC/MS. The automated online sample preparation embodied in thismethod provides unparalleled throughput and reproducibility, as well as time, labor, and solventsavings. Agils Agilent Technologies
关闭
  • 1/1
产品配置单
安捷伦科技(中国)有限公司为您提供《水中氯贝酸检测方案(液质联用仪)》,该方案主要用于环境水(除海水)中有机污染物检测,参考标准《暂无》,《水中氯贝酸检测方案(液质联用仪)》用到的仪器有Agilent 1200 系列液相色谱-芯片/质谱系统。
我要纠错
推荐专场
相关方案
