检测样品 小麦粉
检测项目 营养成分
Easy-to-use measurement procedure:ISO 9001:2008Reg.Ne: Q-04.04.18 MILLING PROCESS CONTROL RAPID QUALITY CONTOL OF FLOUR DETERMINATION OF MOISTURE,ASH,GLUTEN,WHITENESS, AND PROTEIN INFLOUR AND BY-PRODUCTS DETERMINATION OF MOISTURE.PROTEIN, ASH, GLASSINESS, ANDGLUTEN IN WHOLE GRAIN WITHINAMINUTE WIHTOUTANY REAGENTS NIR-analyzerInfraLUM@ FT-12is used for quality control of flour and by-products atall milling stages For grain grading: Rapid control of grain quality: glassiness, gluten andother parameters During grain conditioning: Rapid control of moisture content in grain allows theconditioning process to be adjusted During breaking, sieving, and other stages of flourproduction: Rapid control of ash content allows exact and fastevaluation of the operating efficiency of millingequipment Quality control after mixing: Rapid control of ash, whiteness, moisture, and glutenensures the production of flour of specified quality Total control throughout the intermediate stagesof flour milling and production makes it possibleto optimize the process. InfraLUM FT-12 provides ·Simultaneous determination of all the parametersof interest in 90 seconds · Analyses to an accuracy according to internationalstandards Operation under dedicated SpectraLUM/Prosoftware that enables simple control anddevelopment of customized calibration modelsto ensure highest accuracy of analysis Reagent-free"as is" sample analysis that makesoperation with the instrument easy even foruntrained personnel. Supply and calibration of the analyzer With InfraLUM@ FT-12 analyzer it is possible tocreate, localize, and update calibration models.Installation and calibration using Customer'ssamples are made at the Customer's lab. Fill the sample cell, choose the analyzedproduct in the menu, and start themeasurement. TECHNICAL SPECIFICATIONS Measuring time App.90 seconds Sample volume in the cell 50 ml Spectral range 13200-8700cm-1 [760-1150nm] Dimensions and weight 520x450x370 mm, 32 kg [70 lbs.] Power requirements 110/220 VAC,60/50Hz, 110 W Warranty: All LUMEX instruments are covered by a twelve-month warranty. Installation and commissioning of LUMEX instruments can be carried out at Customer's site by ourservice engineers. User training specific to the Customer needs can be also provided. The technical specifications in this publication are subject to change without notice NIR分析仪InfraLUM® FT–12用于面粉生产过程中,产品和副产品的质量控制。粮食分级:谷物分级:谷物品质的快速控制;玻璃质、谷蛋白和其他参数粮食状况方面:实现谷物含水量的迅速控制并有效调节控制条件在破碎,服务,和其他面粉生产阶段:对灰分的快速控制,可以准确、快速地评估磨粉设备的工作效率。混合之后的质量控制:实现对灰分、白度、水分和谷蛋白的连续控制并确定面粉的产品质量和一些特定参数。通过内置所有磨粉步骤的控制实现工艺过程的优化InfraLUM® FT–12提供:在90秒内同时测定所有需要测定的参数;根据国际标准实现样品的精准分析:使用SpectraLUM/Pro软件,操作简单易用,界面友好,实现高精度分析。
关闭产品配置单
LUMEX INSTRUMENTS (鲁美科思分析仪器)为您提供《面粉质量控制中水分 灰分 蛋白质 淀粉检测方案(近红外光谱仪)》,该方案主要用于小麦粉中营养成分检测,参考标准《暂无》,《面粉质量控制中水分 灰分 蛋白质 淀粉检测方案(近红外光谱仪)》用到的仪器有LUMEX傅立叶近红外光谱仪 FT-12、LUMEX傅立叶红外光谱仪FT-08、LUMEX实时荧光定量芯片qPCR仪- AriaDNA®、LUMEX高效毛细管电泳仪Capel 205。
