检测样品 饲料
检测项目 营养成分
Analytical EquipmentHIGHPERFORMANCECAPILLARY ELECTROPHORESISSYSTEMwww.lumexinstruments.ccm DETERMINATION OF SYNTHETIC AMINO ACIDS (METHIONINE, THREONINE, TRYPTOPHAN) IN FODDER ADDITIVES Lumex Method M 04-63-2016 INTRODUCTION The method is used for the determination of the mass fraction of free methionine, threonine, and tryptophanin fodder additives. For the determination of the mass fraction of methionine, threonine, and tryptophan in feedstuffs, compoundfeeds, fodders, premixes, and all types of feed raw materials use the method M 04-38-2009 (LumexInstruments kit, order No 0300002027). For the determination of free lysine in fodder additives use the method M 04-87-2016 (Lumex Instrumentsset, order No 0300002726). For the determination of methionine hydroxy analogue (HMTBa) in fodder additives use the methodM 04-83-2014 (Lumex Instruments set, order No 0300001888). MEASUREMENT METHOD The measurement method is based on capillary zone electrophoresis with direct UV detection at thewavelength of 200 nm. MEASUREMENT RANGE The measurement ranges for components are 80-100%. EQUIPMENT AND REAGENTS The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection,processing and output are performed using a personal computer running under WINDOWS@XP/7/8/10operating system with installed dedicated software package ELFORUN. Lumex Instruments set, order No 0300002780. EXAMPLES OF REAL ANALYSES BGE: borate Capillary: Leff/ Ltot 65/75 cm, ID 50 um Injection: 300 mbar x sec Voltage: +25kV Temperature:+30°c Detection: 200 nm The contents on this paper are subject to change withou+++ht notice.To get more specific information, please contact the representative by sales@lumexinstruments.com LUMEX成功的将毛细管电泳发展成为实验室的常规分析手段,并一直占据该领域的市场领导地位。成熟的仪器、优化的配置、大量的应用方法包集于一体,被用户称为目前性价比最优的毛细管电泳仪。高效毛细管电泳可用于饲料生产加工以及畜牧养殖等环节的全过程控制。 自2017年4月1日批准实施国家农业行业标准NY/T 3001-2016 《饲料中氨基酸的测定 毛细管电泳法》采用毛细管电泳法分析氨基酸。相对传统氨基酸分析仪和液相色谱法,高效毛细管电泳法分离效率高、时间段、重现性好、分离模式多,分析成本低经济环保,同时实现饲料多指标分析测定。 分析优势特点:1.高效分离效率(百万级理论塔板数);2.样品试剂和样品量消耗低;3.极低的分析成本,毛细管柱一般无需更换;4.操作简单便捷,实现快速分析 (5-10分钟) 。
关闭产品配置单
LUMEX INSTRUMENTS (鲁美科思分析仪器)为您提供《饲料、复合饲料、饲料原料中合成氨基酸检测方案(毛细管电泳仪)》,该方案主要用于饲料中营养成分检测,参考标准《暂无》,《饲料、复合饲料、饲料原料中合成氨基酸检测方案(毛细管电泳仪)》用到的仪器有LUMEX高效毛细管电泳仪Capel 205、LUMEX傅立叶近红外光谱仪 FT-12、LUMEX石墨炉原子吸收MGA-1000。
