检测样品 饲料
检测项目 营养成分
重Analytical Equipment一、寸曾www.lumexinstruments.ccm series DETERMINATION OF LYSINE AND ITS SALTSIN FODDER ADDITIVES Lumex Method M 04-87-2016 INTRODUCTION The method is used for the determination of the mass fraction of free lysine and its salts (including lysinehydrochloride and lysine sulfate) in fodder additives. For the determination of free methionine, threonine and tryptophan in fodder additives use the methodM 04-63-2016 (Lumex Instruments set, order No 0300002780). For the determination of the mass fraction of lysine in feedstuffs, compound feeds, fodders, premixes, and alltypes of feed raw materials use the method M 04-38-2009 (Lumex Instruments kit, order No 0300002027). MEASUREMENT METHOD The measurement method is based on capillary zone electrophoresis with indirect UV detection at thewavelength of 267 nm. MEASUREMENT RANGE The measurement range for lysine is 30-100%. EQUIPMENT AND REAGENTS The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection,processing and output are performed using a personal computer running under WINDOWS@XP/7/8/10operating system with installed dedicated software package ELFORUN. Lumex Instruments set, order No 0300002726. EXAMPLES OF REAL ANALYSES BGE: benzimidazole, with tartaric acid Capillary: Lefi/ Ltot 50/60 cm, ID 75 um The contents on this paper are subject to change without notice.To get more specific information, please contact the representative by sales@lumexinstruments.com LUMEX成功的将毛细管电泳发展成为实验室的常规分析手段,并一直占据该领域的市场领导地位。成熟的仪器、优化的配置、大量的应用方法包集于一体,被用户称为目前性价比最优的毛细管电泳仪。高效毛细管电泳可用于饲料生产加工以及畜牧养殖等环节的全过程控制。自2017年4月1日批准实施国家农业行业标准NY/T 3001-2016 《饲料中氨基酸的测定 毛细管电泳法》采用毛细管电泳法分析氨基酸。相对传统氨基酸分析仪和液相色谱法,高效毛细管电泳法分离效率高、时间段、重现性好、分离模式多,分析成本低经济环保,同时实现饲料多指标分析测定。分析优势特点:1.高效分离效率(百万级理论塔板数);2.样品试剂和样品量消耗低;3.极低的分析成本,毛细管柱一般无需更换;4.操作简单便捷,实现快速分析 (5-10分钟)。
关闭产品配置单
LUMEX INSTRUMENTS (鲁美科思分析仪器)为您提供《饲料添加剂中赖氨酸及其盐类检测方案(毛细管电泳仪)》,该方案主要用于饲料中营养成分检测,参考标准《暂无》,《饲料添加剂中赖氨酸及其盐类检测方案(毛细管电泳仪)》用到的仪器有LUMEX高效毛细管电泳仪Capel 205、LUMEX石墨炉原子吸收MGA-1000、LUMEX傅立叶近红外光谱仪 FT-12。
