检测样品 土壤
检测项目 无机阴离子
Analytical Equipment一、www.lumexinstruments.com series DETERMINATION OF WATER-SOLUBLE FORMS OF INORGANICAND ORGANIC ANIONS IN SOILS,CLAYS,PEATS, WASTEWATER SILTS, ACTIVATED SLUDGES, AND BOTTOM SEDIMENTS Lumex Method M 03-06 (2010) INTRODUCTION The method allows determination of water-soluble forms of inorganic (chlorides, sulfates, nitrates, fluorides,and phosphates) and organic (acetates, formates, and oxalates) anions in soils, clays, peats, wastewatersilts, activated sludges, and bottom sediments by capillary electrophoresis method. MEASUREMENTMETHOD The measurement method is based on the extraction of water-soluble forms of inorganic anions by distilledwater from a soil sample to the 1:5 ratio and subsequent separation, identification, and determination ofanalyzed components by the capillary electrophoresis method with indirect anion detection at wavelengths of254 nm or 374 nm. MEASUREMENT RANGE The measurable anion weight fraction ranges are listed below. Anions Measurement ranges*, mg/kg Anions Measurement ranges*,mg/kg Acetate 3.0-1000 Formate 1.0-500 Nitrate 3.0-10000 Phosphate 3.0-5000 Oxalate 3.0-100 Fluoride 1.0-100 Sulfate 3.0-20000 Chloride 3.0-20000 *- For the sample/distilled water weight ratio 1:5. Other inorganic and organic anions do not interfere with determination of the analyzed anions. EQUIPMENT AND REAGENTS The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection,processing and output are performed using a personal computer running under WINDOWSXP/7/8operating system with installed dedicated software package ELFORUN. All reagents must be of analyticalgrade or better. EXAMPLE OF A REAL ANALYSIS BGE: chromate, with DEA and CTA-OH Capillary: -efi/ Ltot 50/60 cm, ID 75 um The information in this leaflet is supplemental. To get more specific, please contact the manufacturer of CAPEL CE systems LUMEXINSTRUMENTS Group. NORTH AMERICA EUROPE RUSSIA CHINA Lumex Instruments Canada 0890278B.C. Ltd. Lumex Analytics GmbH Lumex-Marketing LLC E-mail: info@lumexanalytics.de E-mail: sales@lumex.ru E-mail: eaa@lumexinstruments.comwww.lumexinstruments.com www.lumexanalytics.de www.lumexinstruments.com Beijing Lumex AnalyticalEquipment Co. Ltd.E-mail:lumex@lumex.com.cnwww.lumexcn.com LUMEX成功的将毛细管电泳发展成为实验室的常规分析手段,并一直占据该领域的市场领导地位。成熟的仪器、优化的配置、大量的应用方法包集于一体,被用户称为目前性价比最优的分析仪器。CE法、与离子色谱法与常见的湿化学法对饮用水、地表水、工业废水及土壤渗析液中的阴离子分析结果一致性极佳,几种方法可以相互验证。符合标准美国EPA 6500,ASTM D 6508-00;ASTM D7881、ASTM D7882等国际方法。广泛用于解决:常规阴离子检测、高氯酸盐、常规阳离子、金属价态、氯化物、消毒剂及其副产物分析。分析优势特点:1.高效分离效率(百万级理论塔板数);2.样品试剂和样品量消耗低;3.极低的分析成本,毛细管柱一般无需更换;4.操作简单便捷,实现快速分析 (5-10分钟)。
关闭产品配置单
LUMEX INSTRUMENTS (鲁美科思分析仪器)为您提供《土壤、废水淤泥、活性污泥和底泥中无机和有机阴离子检测方案(毛细管电泳仪)》,该方案主要用于土壤中无机阴离子检测,参考标准《暂无》,《土壤、废水淤泥、活性污泥和底泥中无机和有机阴离子检测方案(毛细管电泳仪)》用到的仪器有LUMEX高效毛细管电泳仪Capel 205、LUMEX多参数水质分析仪Fluorat、LUMEX紫外/荧光测油仪Fluorat、LUMEX石墨炉原子吸收MGA-1000。
