当前位置: 其他 > 方案详情
量子信息中量子计算检测方案(低温恒温器)
检测样品 其他
检测项目 量子计算
关联设备 共1种 下载方案
方案详情
量子计算是未来信息技术的基础。目前主流量子计算的方法都需要极低温环境,牛津仪器作为全球主要的极低温恒温器厂商,将致力于量子计算领域的发展。
The Business ofScience" The Business ofScience" TritonTM The new generationCryofree@ dilution refrigerator NEW design features for easiestoperation and highest reliability ●Single person operation Software control ●Easy access to cold stage NEW cooling power and competitive basetemperature ●r 500 uW at 100 mK, 20 uW at 20 mK<10 mK base temperature Complete magnet integration Fully designed, built, tested andguaranteed by Oxford Instruments Easily demountable current lead connections Fast sample exchange and maximum sample size Unique bottom-loading sample puck designfor wiring capability and sample change NEW large experimental space Patented, unique top and bottom-loadingsample puck Four line-of-sight ports for wiring and servicesinto large experimental volume ●Large space between cold plates giving increasedcapacity for wiring, filtering, attenuators and othersignal chain components, plus easier access intothese spaces Why choose Triton? With even more experimental space and enhanced cooling power,Triton is easier to use than ever before. The Triton family of cryogen free dilution refrigerators has ledthe way in ultra-low temperature experiment-readiness with itsleading-edge superconducting magnet integration, sample loadingmechanisms and sample wiring options. With over 300 systems installed worldwide, Triton is used in world-leading science across quantum technology, spintronics, optics andmany other cutting-edge applications of condensed matter physics. Unique superconducting magnetintegration Oxford Instruments offers in-house design, manufacturing andsupport for both the dilution refrigerator and the superconductingmagnet. This enables you to have access to our unique service andsupport capabilities for all aspects of your system. A wide range of Cryofree solenoid magnets from0.3 T to 14 T Multi-axis vector magnets including our industry standard6/1/1 T, 90 mm bore design Split pairs and multi-axis vector magnets with optical access Active shielding options to reduce magnetic footprint, andcancellation coils to minimise eddy current heatingin swept-field experiments Demountable magnet current leads (no soldering necessary) Easy field setting with Magnet Field Control software, evenwith vector magnets in three dimensions All Triton systemscome with 3 yearscomprehensive warrantyincluding all supplied thirdparty components, suchas the pulse-tube cooler,pumps and electronics -all backed by our expertregional service teams. New extra wiring capability gives even more signal access in and outof the sample or device. ●FFour line-of-sight ports for direct access from the top plate to thesample plate, giving capacity for 32 typical RF coax lines (such asUT85) with SMA Our superior, patented, bottom-loading mechanism comes with a choice of 42 mm or 72 mm sample space. Proven 10 mK sample temperatures with multiple semi-rigid coaxes Supports a wide range of sample wiring configurations: 14 RFconnections (40 GHz SMP) plus 50 DC connections supplied asstandard, and up to 28 RF plus 100 DC available on request Compatible with piezo nanopositioning stages Specialised low eddy-current designs Fast cool down times pSSample protected from ESD (make-before-break) via samplegrounding or biasing before puck docks with mixing chamber plate Top-loading sample exchange is also available, allowing integrationwith optical table and other site-specific requirements. Low vibration To ensure low vibration, the PTR coldhead is isolated at the systemtop plate and at intermediate and 4 K stages. The new, more rigid support structure reduces the amplitude of lowfrequency modes, resulting in low vibration within the sample space. Optics Demonstrated capability for multiple optical window configurations. ·Customised optical magnet solutions such as 2/2/2 T optical 3-axisvector rotate magnet Special optical access sample pucks Visit www.oxinst.com/triton or email nanoscience@oxinst.com Main service locations: UK, USA, Germany, China, Japan and India o Oxford Instruments Nanotechnology Tools Ltd, 2018. All rights reserved. 量子计算是未来信息技术的基础。目前主流量子计算的实验手段包括利用超导电路,硅量子点,拓扑量子比特来实现量子操纵。这些都需要极低温环境,其中还不有不少需要将极低温环境和高磁场结合。牛津仪器作为全球主要的极低温恒温器厂商,同时也是第一个商用超导磁体的厂商,能够切实满足量子计算相关的实验需求。
关闭
  • 1/2
  • 2/2
产品配置单
牛津仪器科技(上海)有限公司为您提供《量子信息中量子计算检测方案(低温恒温器)》,该方案主要用于其他中量子计算检测,参考标准《暂无》,《量子信息中量子计算检测方案(低温恒温器)》用到的仪器有牛津仪器Triton无液氦稀释制冷机系统。
我要纠错
推荐专场
相关方案
