食用植物油与地沟油中区分鉴定检测方案(感官智能分析)
检测样品 食用植物油
检测项目 理化分析
关联设备 共1种 下载方案
方案详情
利用电子鼻采集各样品的气味信息,通过数据主成分分析(PCA)和线性判别分析(LDA)2种方法进行分析和判定。结果电子鼻可以相互区分食用植物油、餐厨废弃油脂和精炼地沟油。
中国卫生检验杂志 2015年7月第25卷第14期 Chin J Health Lab Tec, Jul. 2015, Vol. 25, No. 14·2280· 电子鼻法鉴别食用植物油与地沟油的研究 李浩,杨冬燕,杨永存,张倩,耿艺介,邓平建 深圳市疾病预防控制中心,广东深圳518055 摘要:目的 尝试利用电子鼻技术建立一种简便、快速的鉴别食用植物油与地沟油的筛查方法。方法 样品包括采集自各超市的9个品种共103个正常植物油,采集自多家餐饮企业的24个煎炸废弃油脂,采集自餐厨垃圾集中处置定点公司的36个餐厨废弃油脂,以及本课题组自主制备的25个精炼地沟油。利用电子鼻采集各样品的气味信息,通过数据主成分分析(PCA)和线性判别分析(LDA)2种方法进行分析和判定。结果 电子鼻可以相互区分食用植物油、餐厨废弃油脂和精炼地沟油,无法区分食用植物油和煎炸废弃油脂。结论 本实验结果表明,经过系列的氧化及劣变过程,地沟油中的气味分子成分与正常植物油相比已经发生了剧烈的变化。电子鼻技术作为鉴别地沟油的一种新兴手段,值得更深入的探索和研究。 关键词:电子鼻;精炼地沟油;煎炸废弃油脂;餐厨废弃油脂;食用植物油 中图分类号:R155.5 文献标识码:A 文章编号:1004-8685(2015)14-2280-04 Research on the distinguishing of bio - waste oil and edible vegetableoil with electronic nose LI Hao, YANG Dong-yan, YANG Yong-cun, ZHANG Qian, GENG Yi -jie, DENG Ping -jian Shenzhen Center for Disease Control and Prevention, Shenzhen, Guangdong 518055, China Abstract: Objective To develop a simple and quick screening method to distinguish bio - waste oil from edible vegetable oilwith electronic nose. Methods The samples included 103 edible vegetable oils of 9 classes from various supermarkets, 24 friedwaste oils from various catering enterprises, 36 kitchen waste oils from kitchen waste disposal designated companies and 25 re-fined bio - waste oils prepared by ourselves. The electronic nose data were collected and interpreted by principal component a-nalysis (PCA) and linear discriminant analysis (LDA) for analysis and identification. Results The electronic nose can distin-guish edible vegetable oil, kitchen waste oil and refined bio- waste oil, while can not distinguish edible vegetable oil and friedwaste oil. Conclusion The results showed that the odor molecules in bio - waste oil are significantly different from those in ed-ible vegetable oil after the oxidation and deterioration processes. As a new method for identification of bio - waste oil, the elec-tronic nose technology is worth further study. Key Words: Electronic nose; Refined bio - waste oil; Fried waste oil; Kitchen waste oil; Edible vegetable oil 电子鼻问世于20世纪90年代,是由多个性能彼此重叠的气敏传感器和模式识别方法组成的具有识别单一和复杂气味的装置。其工作原理是进入电子鼻的气体样品与传感器发生可逆的物理反应、化学反应,产生电信号,电信号通过放大、数字转换进入信号处理系统和模式识别系统,完成对气体样品的检测、分析和判定。电子鼻与色谱仪、光谱仪、毛细管电泳仪等仪器不同,得到的不是被测样品中某种或某几种成分的定性与定量结果,而是样品中挥发成分的整体 ( 基金项目: 深 圳市技术研究开发计划技 术攻 关 项 目(JS G G 20120-615087379 35);深圳市科技计 划 重点项目(2 01201008) ) ( 作者简介: 李 浩(1 981 -), 男 ,博士,副主任技师,主要从 事 食品卫生检验工作。 ) ( 通讯作 者 : 邓 平 建 , E - m a i l : szdp j 2002@16 3 . c o m ) 信息”。电子鼻技术凭借其样品无损、检测速度快、操作简单、灵敏度高、重现性好等优点,目前已广泛应用于食品质量控制领域。近年国内外基于电子鼻技术对食用油质量控制、掺假、货架寿命及储藏性等方面的研究也有不少报道2-3. 从2009年起,我国破获的一系列地沟油案件揭示了我国不仅确实存在,而且已经形成了利用地沟油制售“食用油”的黑色产业链和网络④。地沟油,学名废弃食用油脂,包括餐厨废弃油脂、煎炸废弃油脂、动物废弃油脂等。在我国,无论是从绝对量,还是普遍性而言,餐厨废弃油脂无疑都是地沟油最为主要和固定的来源。更为重要的是,餐厨废弃油脂是目前犯罪团伙用于制售“食用油”最常用和最易得的原料。利用地沟油制售“食用油”的主要模式是:大量收购餐厨 废弃油脂作为原料油,经加热过滤分离得到地沟油毛油,毛油经脱臭、脱酸、脱色制成精炼地沟油(也可统归为地沟油)。这些精炼地沟油因为难以与食用油有效区分开来,所以被批量销往食用油加工企业,或者掺入食用植物油中销往食用油市场及制药企业业。卫生部组织全国相关领域的专家、学者和技术人员开展了大规模的地沟油检测技术的联合攻关研究,先后征集和验证的地沟油检测方法达到350多种,但由于各种检测方法原理不同,检测效果各异,各具优缺点,至今尚未出现被大家普遍认可的地沟油鉴别方法。 本课题组从深圳市多家餐饮企业回收煎炸废弃油脂,从两家深圳市餐厨垃圾集中处置公司收集多个批次餐厨油脂,并经脱臭、脱酸、脱色制成精炼地沟油,同时收集市场常见的不同油料来源、不同品牌的多种食用植物油,采用主成分分析(PCA)和线性判别分析(LDA)对数据分析处理,建立基于电子鼻的地沟油筛查方法。 材料与方法 1.1 样品 1.1.1 食用植物油 共103份,其中包括大豆油8份、葵花籽油6份、玉米油8份、茶籽油6份、花生油32份、芥花籽油5份、橄榄油14份、芝麻油9份、调和油15份,购自深圳各大超市。 1.1.2 煎炸废弃油脂 共24份,采集自深圳市多家餐饮企业。 1.1.3 餐厨废弃油脂 共36份,分季节采集自深圳市腾浪再生资源发展有限公司和深圳瑞赛尔环保股份有限公司,均为深圳市餐厨垃圾集中处置定点公司。 1.1.4 精炼地沟油 共25份,本课题组参考犯罪团 伙供述,确定了地沟油精炼工艺,采用餐厨废弃油脂为原料,经过蒸馏脱臭、吸附脱色、碱炼脱酸,制备而成。 1.2 仪器 实验采用德国 AIRSENSE公司的 PEN3便携式电子鼻系统,该电子鼻包含10个金属氧化物传感器阵列。 1.3 方法去50 ml锥形离心管中,每管装20ml样品,用保鲜膜封紧管口,静置1h,使其顶部气体成分稳定后,采用顶空采样,进行测量。气体的进样速率为400 ml/min, 载气的速率为400 ml/min, 清洗时间为100 s, 准备进样时间为10 s, 进样扫描时间为50 s.取40s~42s处的信号作为分析的时间点,提取数据,用主成分分析(PCA)和线性判别分析(LDA)方法对样品进行分析。 2 结 果 2.1 食用植物油各品种之间的鉴别 食用植物油各品种之间的 PCA 分析的区分强度显示,其中第一主成分贡献率为94.8%,第二主成分贡献率为4.6%。区分强度以0.500为分界线,<0.500表示无法区分,>0.500表示可以区分,强度越大,区分度越好。从表1中可以看出,大豆油、茶籽油、芥花籽油、葵花籽油、玉米油和调和油等油种两两之间均无法区分;橄榄油和除芥花籽油以外的油种区分度良好;芝麻油和除花生油以外的油种区分度良好;花生油和除茶籽油、芥花籽油、芝麻油以外的油种区分度良好。图1为食用植物油各品种之间的 LDA 分析,其中除芝麻油和大部分橄榄油可以和其他油种区分以外,其他油种之间区分度均很差,2个主要成分的贡献率为54.5%。事实上,电子鼻作为一种简便快速的技术手段在鉴别橄榄油和芝麻油等高价油种品质的研究中得到越来越多的关注主。 表1 食用植物油各品种之间的 PCA 分析的区分强度 样品 大豆油 茶籽油 花生油 橄榄油 芥花籽油 葵花籽油 玉米油 调和油 大豆油 茶籽油 0.404 花生油 0.576 0.447 橄榄油 0.771 0.534 0.536 芥花籽油 0.126 0.000 0.343 0.353 葵花籽油 0.304 0.284 0.570 0.758 0.018 玉米油 0.165 0.379 0.617 0.809 0.000 0.098 调和油 0.038 0.170 0.587 0.757 0.000 0.220 0.202 芝麻油 0.774 0.723 0.418 0.553 0.709 0.760 0.770 0.732 图1 食用植物油各品种之间的 LDA分析 2.2 食用植物油和地沟油数据的 PCA 分析 表2为食用植物油和地沟油的 PCA分析的区分强度,其中第一主成分贡献率为91.5%,第二主成分贡献率为4.9%。从表2可见,在食用植物油、煎炸废弃油脂、餐厨废弃油脂和精炼地沟油等4种样本中,除食用植物油和煎炸废弃油脂完全无法区分外,其他相互之间区分度均>0.5,即可以区分。事实上也符合本文的判断,因为煎炸废弃油脂直接取自各餐饮企业的厨房灶台,均为当天煎炸使用后的剩余油脂,常规理化指标未改变或变化不大。本课题组曾分别检验各样品的透明度、气滋味、色泽、酸价、过氧化值、碘值、折光率、极性物和相对密度等常规指标,除气滋味指标外,基于其他常规指标难以鉴别煎炸废弃油脂与食用植物油。本实验结果表明,至少在 PEN3 便携式电子鼻系统的10个金属氧化物传感器阵列的条件下,食用植物油和煎炸废弃油脂的区分强度为0. 表2 食用植物油和地沟油的 PCA 分析的区分强度 名称 食用植物油 煎炸废弃油脂 餐厨废弃油脂 煎炸废弃油脂 0.000 餐厨废弃油脂 0.548 0.623 精炼地沟油 0.659 0.693 0.504 2.3 食用植物油和地沟油数据的LDA分析 分别以食用植物油和餐厨废弃油脂(图2)、精炼地沟油(图3)、煎炸废弃油脂(图4)形成的整体配对建立模式进行LDA分析。结果显示食用植物油与餐厨废弃油脂、精炼地沟油都能形成完全不重合的2个集合,2个主要成分的总贡献率分别为75.3%和55.5%。而食用植物油和煎炸废弃油脂的2个集合有较大的重合度,第一主要成分的贡献率仅为37.3%。事实上,将4种成分同时进行 LDA分析(图5)时,可以发现,食用植物油和餐厨废弃油脂、精炼地沟油均可以相互区别,而煎炸废弃油脂和食用植物油无法区分,2个主要成分的总贡献率为66.2%。 图2 餐厨废弃油脂(左)和食用植物油(右)的 LDA分析 图3 食用植物油(左)和精炼地沟油(右)的LDA分析 图4 食用植物油(左)和餐厨废废油脂(右)的 LDA分析 图5 食用植物油和地沟油的 LDA分析 3 讨 论 近年来,国内已有多种方法鉴别地沟油的文献报道,但大多数研究所采集的正常食用植物油样品种类不全、数量有限。本研究在深圳多个超市,收集9个植物油品种分不同品牌共103份样品。此外,可能是基于获得地沟油的困难,以往大部分研究的地沟油样 品数量较少。部分来自于废油处理公司或工商部门收没,其炼制工艺及初始来源不清楚,甚至不能完全确认其地沟油身份,而来源清楚的地沟油一般是从食堂消水粗加工后获得,未进行进一步的精炼。本课题组模仿地沟油犯罪团伙利用地沟油制售“食用油”的模式,研究精炼地沟油适用的制备工艺路线及条件,采用收集自深圳政府指定的餐厨废弃物回收公司的餐厨废弃油脂为原料,通过蒸馏脱臭-碱炼脱酸-吸附脱色获得多批次的精炼地沟油样品。这些精炼样品外观、气滋味、色泽、水分及挥发物、酸价等各项质量控制指标量值比较一致,并且具有较好多样性和代表性的内源性成分和外源性成分17-8. 电子鼻作为一种新兴的检测技术尚不十分成熟。首先,传感器具有选择性和限制性,不可能适应所有检测对象,即没有通用的电子鼻。但大力研究、制作有针对性专用的电子鼻,则能提高检测精度和使用寿命。这也意味着需要加强研制并发展合适的传感器结构和材料。其次,在模式识别系统上亦应多样化。采用某一种模式识别方式可能不能识别或结果不很理想,或许采用另外一种模式识别方式或改进模式识别方法以后,则可能获得理想的结果。食品的种类很多,其芳香成分不一样,要求采用多种模式识别与比较,以提高检测精度。此外,检测环境的温湿度变化会使传感器响应特性有所不同。这就要求对电子鼻的传感器周围温湿度严格控制。 本研究结果可以看出,电子鼻可以区分食用植物油和餐厨废弃油脂、食用植物油和精炼地沟油,无法区分食用植物油和煎炸废弃油脂。从原理来看,无论电子鼻的灵敏度有多高,其原理是基于气味来给油脂归类。在食用植物油的种类区分中可以看到,在目前PEN3 便携式电子鼻系统的10个金属氧化物传感器阵列的条件下,也只能做到区分出芝麻油和橄榄油,其他油种的重叠度很高而无法区分。煎炸废弃油脂虽然经过一次或数次煎炸,但毕竟是在煎炸当天进行采样,正常油脂中的气味分子不可能完全损失或改 (上接第2279页) 3 结 论 本方法用乙腈和0.1%磷酸组成流动相,实现对5种水果中4-氯苯氧乙酸、氯吡脲、2,4-二氯苯氧乙酸的检测,结果表明本方法操作简单、准确、快速,能够完全满足日常水果检测的需要。 ( 参考文献 ) ( [] 张德文 . 水 果 及 果 汁中植物生 长 调节节丁 酰 肼和1 ,1 - 二 甲基肼的气相色谱测定门.国外 医学: 卫生学分 册 ,1991(3 ):183 , 153. ) ( [ 2 ] 刘宏程, 林 涛,邵金良,等.高效液相色谱测定 水 果中外源植物激素的快速前处理 方 法研究[].分 析科 学学报,2014 ,30(4 ): 497 -5 00. ) 变,因此电子鼻无法区分食用植物油和煎炸废弃油脂。而作为地沟油主要来源的餐厨废弃油脂,根据其产生过程、贮存条件和理化性状推测,酸败、发酵、酶解、微生物和洗涤剂等因素存在着对废弃油脂的再次破坏作用。大量接触氧气、光、热、微生物、促氧化物质及劣变环境,往往自动氧化、光氧化、酶促氧化等交错并行,使得油脂进入加速氧化阶段,导致油脂发生去氢、环化、加成、裂解、聚合等复杂反应产生大量的氧化产物,其中就包含可以产生刺激性气味的醛、酮等。此时油脂中的气味分子已经发生了电子鼻可以进行区别的根本性变化。而精炼地沟油经蒸馏脱臭-碱炼脱酸-吸附脱色等一系列除杂步骤之后,其中产生刺激性气味的物质已经绝大部分被除去,其气味分子的分布既不同于餐厨废弃油脂,也不同于食用植物油。因此,食用植物油、餐厨废弃油脂和精炼地沟油可以通过电子鼻进行相互区别。 本研究结果表明电子鼻技术在地沟油鉴别领域的应用值得更深入的探索和研究。 ( 参考文献 ) ( [ ] M igu e l P , L a u ra EG . A 2 1 s t century te c hn ique f o r f oo d c ontrol : E - l e ct r on i c n ose s [ . Anal Chi m A cta, 200 9 , 6 3 8 (1 ):1- 1 5. ) ( [2 ] 中 华人民共 和 国最高人 民 法院,最高人民检察院,公安部.关于 依法严惩“地沟油”犯 罪 活动的通知[Z].2 012-02- 24 . ) ( [ 3 ] F rank R , N i colae B , U d o W. E l e c t r oni c no s e: cu r rent st a t u s a n d f utur e tren ds [ ] . Chem R e v , 2008 , 108 ( 2 ) : 7 05-72 5 . ) ( [ 4] L erma - G arcia M J, S im6- A l f onso E F , Be n d i ni A, et al. R a p ideva l uat i on o f o xi d ized f a tty a c i d c o n cent r at io n in vi r gi n olive o i ls u- si ng m eta l o x ide se mico n ductor s e n sors an d mul t iple li ne ar r e g r es-si o n [ ] . J Agr i c Food Chem, 2009, 57 (2 0 ):9365 -9 369. ) ( [5 ] 邓平建,李浩 , 杨冬燕,等.利 用 “地沟油 ” 制售 “ 食用油”的成本 效益分析. 中 国公共卫生,2014, 30 ( 增 刊):15 -1 9 . ) ( [6 ] 沈雄,郑晓,何东平.餐饮业废弃油脂鉴别检测方法研究进展 [ ]. 中国油 脂 ,201 1,36(1 1 ) :4 9- 5 2. ) ( [ 7] 李浩,邓平建,杨冬燕,等 . “地沟油 ” 标准物质候选物研制 . 中 国 公共卫生,201 4,30(3) :3 61-3 6 3. ) ( [8 ] 曹维金,杨永 存 ,招辉,等.基于常规指标鉴别“地沟油”与食用 植物油的有 效 性评估 [ .卫 生研究, 2014,4 3(2):33 0 -332. ) ( 收稿日期 : 2014-11-27 ) ( [ 3] 吴平谷,谭莹,张晶,等.分级 净 化结合气相色谱-质谱联用法测定豆芽中10 种 植物 生 长 调 节剂[.分析化学,2014, 42 ( 6) : 866-871. ) ( [4 ] 牟艳莉,郭德华, 丁 卓平,等.高效液相色谱 - 串联质谱法测定瓜果中1 1 种植物生长调节剂的残留量Q.分 析化 学,201 3,41 ( 11 ): 1640-1646. ) ( [5 ] 谢寒冰,周明莹,赵海峰,等.高效液相色谱-四 极 杆飞行时间质谱法同时检测豆芽 中 的 3 种外源植物激素残留[ .色 谱, 201 4 , 3 2 ( 5 ) : 4 93 -4 98. ) ( [6 ] 钟冬莲,丁明,汤富彬,等.高效液相色谱 - 串联质谱同时测定毛竹笋中 4 种 内 源性植物激素[].分析 化学 ,20 1 3 ,41(1 1 ) : 1739 -1 743. ) ( 收稿日期:2 014- 1 1 -2 7 ) 样品:    1.食用植物油 共103份,其中包括大豆油8份、葵花籽油6份、玉米油8份、茶籽油6份、花生油32份、芥花籽油5份、橄榄油14份、芝麻油9份、调和油15份,购自深圳各大超市。    2. 煎炸废弃油脂共24份,采集自深圳市多家餐饮企业。    3. 餐厨废弃油脂共36份,分季节采集自深圳市腾浪再生资源发展有限公司和深圳瑞赛尔环保股份有限公司,均为深圳市餐厨垃圾集中处置定点公司。    4.精炼地沟油共25份,本课题组参考犯罪团伙供述,确定了地沟油精炼工艺,采用餐厨废弃油脂为原料,经过蒸馏脱臭、吸附脱色、碱炼脱酸,制备而成”。仪器:    德国AIRSENSE公司的PEN3便携式电子鼻系统,该电子鼻包含10个金属氧化物传感器阵  列。检测指标:    各样品的气味信息实验过程:    50ml锥形离心管中,每管装20 ml样品,用保鲜膜封紧管口,静置1 h,使其顶部气体成分稳定后,采用顶空采样,进行测量。气体的进样速率为400 ml/min,载气的速率为400 ml/min,清洗时间为100s,准备进样时间为10s,进样扫描时间为50 s。取40s~42 s处的信号作为分析的时间点,提取数据,用主成分分析(PCA)和线性判别分析(LDA)方法对样品进行分析。实验结果:    利用电子鼻采集各样品的气味信息,通过数据主成分分析(PCA)和线性判别分析(LDA)2种方法进行分析和判定。结果电子鼻可以相互区分食用植物油、餐厨废弃油脂和精炼地沟油,无法区分食用植物油和煎炸废弃油脂。结论本实验结果表明,经过系列的氧化及劣变过程,地沟油中的气味分子成分与正常楠物油相比已经发生了剧烈的变化。结论:    尝试利用电子鼻技术建立-种简便快速的鉴别食用植物油与地沟油的筛查方法,电子鼻技术作为鉴别地沟油的一种新兴手段,值得更深入的探索和研究。
关闭
  • 1/4
  • 2/4
还剩2页未读,是否继续阅读?
继续免费阅读全文
产品配置单
北京盈盛恒泰科技有限责任公司为您提供《食用植物油与地沟油中区分鉴定检测方案(感官智能分析)》,该方案主要用于食用植物油中理化分析检测,参考标准《暂无》,《食用植物油与地沟油中区分鉴定检测方案(感官智能分析)》用到的仪器有德国AIRSENSE品牌PEN3电子鼻。
我要纠错
推荐专场
相关方案
