中国卫生检验杂志 2014年1月第24卷第2期 Chin J Health Lab Tec, Jan 2014, Vol 24, No 2·177· ·化学测定方法· 吹扫捕集-气相色谱-质谱法测定水中苦味酸 李逸,张荧,魏立菲,刘昕宇,刘胜玉 广州市珠江流域水环境监测中心,广东广州510611 摘要:目的 建立水中苦味酸的吹扫捕集-气相色谱-质谱检测方法。方法 水中苦味酸与衍生剂次氯酸钠反应生成挥发性的氯化苦(三氯硝基甲烷),经ENCON Evolution 吹扫捕集仪取样、加氟苯内标、吹扫、捕集和热解析后,进入气相色谱-质谱联用仪进行分离和检测,全扫描监测,内标法定量。结果 苦味酸的衍生化产物分离良好,衍生化后72h内测试稳定,在1.0 pg/L~40.0 ug/L范围内,苦味酸的浓度与氯化苦/氟苯内标峰面积比呈现良好的线性关系,相关系数>0.999。方法检出限为0.5 pg/L。实际水样加标10.0 pg/L 7 次平行测定 RSD 为2.8%。不同浓度加标回收率在90%~106%之间。结论:该方法简化了样品的前处理程序,避免了有毒萃取溶剂的使用,具有简便、环保、准确、灵敏的优点,适用于水中苦味酸的常规监测。 关键词:苦味酸;氯化苦;吹扫捕集;气相色谱-质谱 中图分类号:0657.7*1 文献标识码:A 文章编号:1004-8685(2014)02-177-03 Determination of picric acid in water by GC -MS with purge and trap LI Yi, ZHANG Ying, WEI Li -fei, LIU Xin -yu, LIU Sheng -yu The Pearl River Water Enwironment Monitoring Center, Guangzhou 510611, China Abstract: Objective To develop an analytical method for picric acid in water by GC -MS with purge and trap concentrator. Methods Picric acid in water reacted with derivatizing agent sodium hypochlorite to produce volatile chloropicrin( nitrotrichlo-romethane). With fluorobenzene as internal standard, the sample solution containing chloropicrin was purged, trapped and ther-mally desorbed by ENCON Evolution purge and trap concentrator, then separated and detected by GC -MS, finally quantifiedby internal standard method. Results The derivative product of picric acid was separated well and tested stably within 72hours. In the concentration range of 1.0 pg/L~40.0 ug/L, picric acid showed good linearity with peak area ratio of chloropic-rin / fluorobenzene(r>0.999). The detection limit of the method was 0.5 ug/L. The recoveries of picric acid at different lev-els were between 90%~106%, and the RSD was 2.8% with standard addition concentration of 10.0 ug/L in practical watersample(n=7). Conclusion This method has simplified the sample pre - treatment procedures and avoided the use of toxicsolvent, it was convenient, environmental friendly, accurate and sensitive for routine monitoring of picric acid in water. Key Words: Picric acid; Chloropicrin; Purge and trap; GC -MS 苦味酸,学名2,4,6-三硝基苯酚,俗称黄色炸药,主要用于制造炸药、农业上的杀菌剂及除霉剂、医疗上的杀菌剂及收敛剂等。可对眼睛、皮肤、呼吸道和消化道产生危害,长期接触苦味酸可引起头痛、头晕、恶心、呕吐食欲减退、腹泻和发热等症状。工农业的发展,废水的排放导致水源苦味酸的污染。《地表水环境质量标准》( GB 3838-2002)中规定集中式生活饮用水地表水源地标准限值为0.5 mg/L。 苦味酸已报道的测定方法有气相色谱法-71分光光度法[8]、浮选光度法91、极谱法10等,其中气相色谱法最常用。 《生活饮用水标准检验方法》中规定 ( 作者简介: 李 逸(1978-),男,硕士,工程师,主要从事水环境中有机污染物监测工作。 ) 先用次氯酸钠与水中的苦味酸反应生成氯化苦(三氯硝基甲烷,CCl,NO,),再以苯萃取,用带有电子捕获检测器的气相色谱仪分离和测定。高毒性的苯对健康和环境有害,电子捕获检测器容易出现假阳性。考虑到氯化苦的挥发性,本文尝试用吹扫捕集-气相色谱-质谱法改进水中苦味酸的测定方法,不仅避免了有毒萃取溶剂的使用和假阳性,还简化了样品的前处理程序。新方法简便、准确、灵敏,适用于水中苦味酸的常规监测。 实验部分 1.1 仪器和试剂 TSQ Quantum XLS 三重四级杆气质联用仪; ENCON Evolution 吹扫捕集浓缩仪。 苦味酸(分析纯,广州化学试剂厂);次氯酸钠溶 液(分分纯,有效氯4.00%~4.99%, Sigma -Aldrich);氟苯内标储备液(2000 mg/L,Supelco);超纯水(电阻率18.2 MQ· cm, Millipore);甲醇(色谱纯,Tedia);高纯氦气。 1.2 标准样品制备 称取0.1000 g苦味酸,用超纯水溶解后,定容于1000 ml棕色容量瓶中,混匀,得100 mg/L 标准储备液。临用时,用超纯水稀释成1.0 pg/L,2.0ug/L,5.0pg/L,10.0pg/L,15.0pg/L,20.0 ug/L,30.0 ug/L,40.0 pg/L标准工作溶液。氟苯内标储备液用甲醇稀释成5 mg/L 内标工作溶液,装入吹扫捕集仪的内标瓶中。 1.3 水样的测定 依次取5 ml 次氯酸钠溶液和25 ml水样于40 ml 棕色螺纹口吹扫样品瓶中,旋紧瓶盖,混匀,放入吹扫捕集浓缩仪自动进样器盘架,室温反应30min 后按仪器工作条件进行分析。内标法定量。 1.4 仪器工作条件 吹扫捕集条件:仪器自动进样,样品取样量25 ml,自动添加25 pl内标工作溶液。吹扫温度35℃,捕集阱吸附温度38℃,除湿阱温度38℃,吹扫时间11 min,吹扫流速 40 ml/min;解析温度180℃,解析压力10 psi,解析时间4.0 min; 捕集阱烘焙温度230℃,除湿阱烘焙温度230℃,烘焙流速85 ml/min,烘焙时间15 min。传输管线温度150℃,阀箱温度150℃。 气相色谱条件: Rtx -624 毛细管色谱柱(60m×0.25 mm,1.4 pm),进样口温度180℃,载气流量1.00 ml/min,分流进样,分流比为50∶1。柱程序升温:初始温度35℃,保持3 min,以4℃/min 速率升至180℃,保持3 min。 质谱条件:EI 源,70 eV,离子源温度200℃,四级杆温度150℃,传输线温度200℃。全扫描监测模式,质荷比范围35 amu ~350 amu,扫描周期0.2 s.氯化苦定量离子117,定性离子119,82。氟苯内标定量离子70,定性离子96,50。 2 结果与讨论 2.1 氯化苦的定性 苦味酸与次氯酸钠反应生成沸点为112℃的挥发性有机化合物氯化苦,氯化苦可通过吹扫捕集浓缩,再以气质联用仪进行定性定量分析。图1为20 ug/L 苦味酸衍生化吹扫捕集测试总离子流色谱图,图2为氯化苦质谱图。测试时总能在总离子流色谱图上发现较强的三氯甲烷和四氯化碳峰,估计源于次氯酸钠对水中其他有机物的氯化,如甲醇(氟苯内标的溶剂)。四氯化碳和氯化苦的质谱图非常相近,定性时容易混淆,但两者保留时间不同,氯化苦(20.45 min) 在四氯化碳(13.73 min) 后出峰, 在图1上能明显区分。 注:1-三氯甲烷(13.07 min) ,2-四氯化碳(13.73 min) ,3-氟苯(15.11 min),4-氯化苦(20.45 min)。 图1 20 pg/L 苦味酸衍生物总离子流色谱图 图2 氯化苦质谱图 2.2 次氯酸钠加入量 分别向25 ml含有2.0 pg/L,10.0 pg/L,40.0 ug/L 苦味酸的水样中加入不同体积的次氯酸钠,室温下反应 30 min 后测试,以氯化苦m/z117离子峰面积和氟苯 m/z70 离子峰面积比值为纵坐标,次氯酸钠加入量为横坐标绘图。如图3所示,次氯酸钠加入量对2.0 pg/L水样的影响不明显;10.0 pg/L水样次氯酸钠加入量≥3 ml响应值无明显增大;40.0pg/L水样次氯酸钠加入量≥4ml响应值无明显增大,表明反应进行完全。考虑到环境样品中可能会有较高浓度的苦味酸,选择加入5 ml次氯酸钠较为合适。 图3 次氯酸钠加入量对反应的影响 2.3 氯化苦的稳定时间 为考察衍生化产生的氯化苦在样品溶液中的稳定时间,配制了6个40.0 ug/L苦味酸平行样,加5 ml次氯酸钠溶液后分别于0.5 h,1 h,8 h,24 h,48 h, 72 h 进行测定,测试值分别为39.2 pg/L,38.4 ug/L,40.5 ug/L,39.3 pg/L,41.3 pg/L。结果表明,衍生化之后72 h 内进行测定结果基本稳定。 2.4 标准曲线 用超纯水稀释标准储备液,配制1.0 pg/L,2.0 pg/L,5.0 ug/L,10.0 ug/L,15.0 pg/L,20.0 pg/L,30.0 pg/L,40.0 pg/L 苦味酸标准溶液系列,用甲醇稀释氟苯内标储备液至5.0 mg/L,按实验方法进行测定。定量分析用内标法,以氯化苦 m/z117 离子峰面积和氟苯m/z70离子峰面积比值为纵坐标,苦味酸浓度为横坐标绘制标准曲线,得到线性方程为y =0.03066x+0.01357,相关系数0.9995(图4)。 图4苦味酸标准曲线 2.5方法检出限 以超纯水为空白,按照样品分析的全部步骤重复7次空白试验,标准偏差S为0.16 pg/L。按照 MDL=t(n-1,0.99) ×S确定方法检出限11,当n=7、置信度99%时,t值取3.143,苦味酸的方法检出限为0.5 ug/L。 2.6 精密度和回收率 如表1所示,平岗水源地水样7份平行加标10.0 ug/L测试,相对标准偏差为2.78%;实际样品不同浓度加标回收率在90.2%~106.3%之间。 2.7 实际样品测定 对珠江三角洲平岗、布洲、潼湖、桥头四个重要饮用水源地和两条污染严重的河涌进行测定,结果见表1,四个饮用水源地均未检出苦味酸,石井河、布吉河分别为6.85 ug/L和15.61 ug/L. 表11精密度与回收率实验结果 样品 水样浓度 加标浓度 实测浓度 回收率 (ug/L) (pg/L) (pg/L) (%) 平岗水源地-1 ND 10.0 9.74 97.4 平岗水源地-2 ND 10.0 9.46 94.6 续表 样品 水样浓度 加标浓度 实测浓度 回收率 (ug/L) (ug/L) (pg/L) (%) 平岗水源地-3 ND 10.0 9.51 95.1 平岗水源地-4 ND 10.0 10,23 102.3 平岗水源地-5 10.0 9.67 96.7 平岗水源地-6 10.0 9.48 94.8 平岗水源地-7 10.0 9.81 98.1 布洲水源地 ND 5.0 4.51 90.2 潼湖水源地 20.0 19.21 96.1 桥头水源地 40.0 38.26 95.7 石井河 6.85 20.0 28.11 106.3 布吉河 15.61 20.0 33.84 91.2 注“ND”代表“未检出”。 3结论 建立了吹扫捕集-气相色谱-质谱法测定地表水中苦味酸的新方法,该方法稳定可靠、定性准确、精密度好、回收率高。整个分析过程不使用有机溶剂萃取,操作简便,安全环保。其方法检出限优于生活饮用水标准检验方法,满足《地表水环境质量标准》0.5mg/L限值要求,适用于水中苦味酸的常规监测。 ( 参考文献 ) ( [1 ] 刘辉利,鲜啟鸣,邹惠仙,等.水中苦味酸的测定[.环境污染 与防治,2005,27(2):145-147. ) ( [2] 吴文辉.毛细管气相色谱法检测水中的苦味酸[.净水技术, 1999,18(3):35-37. ) ( 3] 管丽凤.水中苦味酸的测定[.环境科学与管理,2008,33(2): 123-125. ) ( [4] 李爱强,陈军,程滢.气相色谱法测定水中的苦味酸[.环境科 学导刊,2007,26(4):89-90. ) ( [5] 倪刘建,杨文武,等.气相色谱法测定水中的苦味酸叨.中国环 境监测,2009,25(5):47-49. ) ( [6] 周亚茹,申红梅,赵方然.气相色谱法测定水源水中的苦味酸[.中国卫生检验杂志,1995,5(6):380-381. ) ( [7] 中华人民共和国卫生部. GB/T5750.8-2006生活饮用水标准检验方法有机物指标[S].北京:中国标准出版社,2007. ) ( [8] 谢祖芳,陈渊,晏全,等.树脂相分光光度法测定水中痕量苦味 酸叨.化工环保,2005,25(2):140-142. ) ( [9] 谢复青,何星存,蒋毅民.浮选分光光度法测定水中痕量苦味酸 [].广西科学,1994,1(4):23-25. ) ( [10] 刘念辉,张宝华.水中苦味酸的极谱法测定[.上海环境科 学,1993,12(10):32-34. ) ( [11] 中华人民共和国环境保护部. HJ168-2010环境监测分析方法标准制修订技术导则[S].北京:中国环境科学出版社,2010. ) ( 收稿日期:2013-08-23 ) 建立水中苦味酸的吹扫捕集 - 气相色谱 - 质谱检测方法。方法 水中苦味酸与衍生剂次氯酸钠反应生成挥发性的氯化苦( 三氯硝基甲烷) ,经 Evolution 吹扫捕集仪取样、加氟苯内标、吹扫、捕集和热解析后,进入气相色谱 - 质谱联用仪进行分离和检测,全扫描监测,内标法定量。结果 苦味酸的衍生化产物分离良好,衍生化后 72 h内测试稳定,在 1.0 μg /L ~ 40.0 μg /L 范围内,苦味酸的浓度与氯化苦/氟苯内标峰面积比呈现良好的线性关系,相关系数 > 0.999。方法检出限为 0.5 μg /L。实际水样加标 10.0 μg /L 7 次平行测定 RSD 为 2.8% 。不同浓度加标回收率在 90% ~ 106% 之间。结论: 该方法简化了样品的前处理程序,避免了有毒萃取溶剂的使用,具有简便、环保、准确、灵敏的优点,适用于水中苦味酸的常规监测
关闭还剩1页未读,是否继续阅读?
仪真分析仪器有限公司为您提供《水中苦味酸检测方案(吹扫捕集)》,该方案主要用于环境水(除海水)中有机污染物检测,参考标准《暂无》,《水中苦味酸检测方案(吹扫捕集)》用到的仪器有吹扫捕集浓缩仪 EST Evolution。
