当前位置: 其他酒 > 理化分析 > 方案详情
烈酒中酒精度检测方案(饮用酒检测仪)
检测样品 其他酒
检测项目 理化分析
关联设备 共3种 下载方案
方案详情
使用高精度酒精浓度计ALM-155测定英国烈酒中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的应用实例。高精度酒精浓度计ALM-155也可用于酿酒过程中的测量。 技术说明: 样品必须按照当地规定的程序蒸馏,然后才能用此高精度酒精浓度计测量乙醇的浓度。
KM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-0213ov enLKcMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.1/1 Application Note Determinationof alcoholcontent in BritishSpritsDbyAlcohol meter Industry Food and BeverageInstrument Alcohol meterMeasurement method Resonant frequency oscillation 1. Scope This is an example about determination of the alcohol content (vol%), specific gravity (t/t) anddensity (g/cm’) in British Sprits. The alcohol meter can be used enough for determination of theseapplications on the wine making process. Technical note: The alcohol sample must be distilled as per the procedure specified on localregulations before the alcohol content can be measured by this alcohol meter. 2. Apparatus 5. Procedure A: Alcohol content (vol%): Take distilled sample solution into beaker Introduce the sampling nozzle into the beaker Press [Meas.] button on the instrument B: Specific gravity (t/t) and Density (g/cm): Take sprits sample solution into beaker Introduce the sampling nozzle into the beaker Press [Meas.] button on the instrument 6. Measurement results Alcohol(vol%) at 20℃ S.G. (t/t) Density (g/cm) wil 35.39 0.94963 0.94793 2 35.39 0.94963 0.94793 3 35.39 0.94963 0.94793 Mean 35.39 0.94963 0.94793 SD 0.00 0.00 0.00 RSD(%) 0.00 0.00 0.00 电话:021-54488867 电邮: kemu-kem@163.com 网址: http://www.kem-china. com 高精度酒精浓度计测定 英国烈酒的酒精度(英文版) 使用高精度酒精浓度计ALM-155测定英国烈酒中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的应用实例。高精度酒精浓度计ALM-155也可用于酿酒过程中的测量。技术说明: 样品必须按照当地规定的程序蒸馏,然后才能用此高精度酒精浓度计测量乙醇的浓度。
关闭
  • 1/1
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《烈酒中酒精度检测方案(饮用酒检测仪)》,该方案主要用于其他酒中理化分析检测,参考标准《暂无》,《烈酒中酒精度检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度酒精度测定仪(GB 5009.225-2023)、DA-130Nc便携式密度计/比重计、DA-130N手持式数字酒精计/酒精浓度计。
我要纠错
推荐专场
相关方案
