酒精度测定仪测量波本威士忌中的乙醇浓度 应用资料此应用资料是测定波本威士忌中酒精含量(vol%)、相对密度(t/t)和密度(g/cm3)的范例。高精度酒精度测定仪ALM-155可用于测量波本威士忌酿造过程中的应用。技术说明: 酒精样品必须按照当地法规规定的程序蒸馏,然后才能使用此酒精度测定仪测量乙醇浓度。KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-0223 enLK-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD.1/1 Application Note Determination of alcohol content in bourbon whiskey byAlcohol meter Industry Food and BeverageInstrument Alcohol meterMeasurement method Resonant frequency oscillation, GB 5009.225 1. Scope This is an example about determination of the alcohol content (vol%), specific gravity (t/t) anddensity (g/cm’) in the bourbon whiskey. The alcohol meter can be used enough for determinationof these applications on the bourbon whiskey making process. Technical note: The alcohol sample must be distilled as per the procedure specified on localregulations before the alcohol content can be measured with this alcohol meter. 2. Apparatus 5. Procedure A: Alcohol content (vol%): Take distilled sample solution into beaker Introduce the sampling nozzle into the beaker Press [Meas.] button on the instrument B: Specific gravity (t/t) and Density (g/cm): Take bourbon whiskey sample solution into beaker Introduce the sampling nozzle into the beaker )Press [Meas.] button on the instrument 6. Measurement results Procedure A Procedure B Alcohol (vol%) at 20℃ S.G. (t/t) Density (g/cm’) 1 36.58 0.95031 0.94861 2 36.57 0.95033 0.94863 3 36.57 0.95033 0.94863 Mean 36.57 0.95032 0.94862 SD 0.01 0.00 0.00 RSD(%) 0.02 0.00 0.00 京都电子工业株式会社-可睦电子(上海)商贸有限公司 上海市徐汇区宜山路333号1201室电话: 021-54488867 电邮: kemu-kem@163.com 网址: http://www.kem-china.com
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《波本威士忌中酒精度检测方案(饮用酒检测仪)》,该方案主要用于其他酒中理化分析检测,参考标准《暂无》,《波本威士忌中酒精度检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度酒精度测定仪(GB 5009.225-2023)、DA-130N手持式数字酒精计/酒精浓度计、DA-850台式U形振动管法数字式密度计。
