草莓中质谱成像检测方案(质谱部件)
检测样品 其他水果制品
检测项目 理化分析
关联设备 共1种 下载方案
方案详情
滨松多孔氧化铝制作的辅助离子化基板DIUTHAME(Desorption Ionization Using Through Hole Alumina MEmbrane),可大幅缩减质谱成像分析时待测样品进行离子化所需的前期处理的时间。只要将本产品放置在待测样品上,就能完成质量分析的前期处理。与目前主要的离子化方法之一基质辅助激光解析电离(Matrix-Assisted Laser Desorption/Ionization、下面简称MALDI)方法相比,它将前期处理时间缩短到十分之一。产品具备方便易用、无基质噪声、高重现性、高空间分辨率。本案例为使用辅助离子化基板进行的草莓截面质谱成像。
HAMAMATSUPHO TO NIS5 COURBUSINES SHAMAMATSU PHOTONICS K.K., Electron Tube Division314-5, Shimokanzo, Iwata City, Shizuoka Pref., 438-0193, Japan, Telephone:(81)539/62-5248,Fax:(81)539/62-2205MAR. 2020 MS imaging of a fresh strawberryusing blotting method Samples with high moisture content, such as strawberries, are difficult to slice into thin sections, especially when the sample is large. Toperform MS imaging on these kinds of samples, Hamamatsu developed a large-sized DIUTHAME (60 mm X40 mm effective area). This papershows the MS imaging results of a large strawberry using the DIUTHAME blotting method, which does not require thin sectioning. Measurement conditions Measurement mode: Laser pitch 300 pm Positive ion, reflectron mode Sample: Fresh strawberry ("Skyberry" from Tochigi Prefecture), 2L size (35 mm X 40 mm) Method 2 Cutting S etting To lay the strawberry flat, maketwo cuts with a knife. Place DIUTHAME on the cutsurface. Allow the DIUTHAME to soak upthe strawberry's components. After drying, attach the DIUTHAMEon an MTP TLC Adapter (Bruker)and perform MS imaging. Results Measurements were performed in collaboration with Associate Professor Hirofumi Enomoto,The Department of Biosciences, Teikyo University. ( S u bject to local technical requirements and regulations, avai l ability of products incl u ded in this promotional material may vary. Please consult with our sale s office!Information furnished b y HAMAMATSU is believed to be reliable. However, no responsibility is assumed for possible inaccuracies or omissions.Specifications are s ubject to c hange without notice. N o patent rights are granted t o any of the circuits described herein. @2020 Hamamatsu Photonics K.K. ) HAMAMATSU PHOTONICS K.K. www.hamamatsu.com 滨松多孔氧化铝制作的辅助离子化基板DIUTHAME(Desorption Ionization Using Through Hole Alumina MEmbrane),可大幅缩减质谱成像分析时待测样品进行离子化所需的前期处理的时间。只要将本产品放置在待测样品上,就能完成质量分析的前期处理。与目前主要的离子化方法之一基质辅助激光解析电离(Matrix-Assisted Laser Desorption/Ionization、下面简称MALDI)方法相比,它将前期处理时间缩短到十分之一。产品具备方便易用、无基质噪声、高重现性、高空间分辨率。本案例为使用辅助离子化基板进行的草莓截面质谱成像。
关闭
  • 1/1
产品配置单
滨松光子学商贸(中国)有限公司为您提供《草莓中质谱成像检测方案(质谱部件)》,该方案主要用于其他水果制品中理化分析检测,参考标准《暂无》,《草莓中质谱成像检测方案(质谱部件)》用到的仪器有滨松辅助离子化基板DIUTHAME A13331-18-2。
我要纠错
推荐专场
相关方案
