当前位置: > 理化分析 > 方案详情
甲乙酮、丙酮、环己酮中水分含量检测方案(卡氏水分测定)
检测样品
检测项目 理化分析
关联设备 共1种 下载方案
方案详情
本实验通过容量法对酮和醛的水含量进行测试。样品为液体时,通常通过直接注入滴定池来测量样品。脱水甲醇一般用作滴定溶剂。然而,在酮和醛的测量中,由于它们与甲醇反应生成水,因此测量结果往往高于真实值(式(1))。 R?CO + 2CH?OH → R?C(OCH?)? + H?O ???(1)  由于上述原因,酮和醛的水分测定应使用不含甲醇的卡尔费休试剂。市售的试剂具有特殊的酮和醛成分。本章介绍了一个在甲基乙基酮、丙酮和环己酮中加水至 1% 的水含量测定示例。这些样品通常用作油漆溶剂、粘合剂的原料和合成树脂。
Inspire the Next HITACHI HIRANUMAAPPLICATION DATA Karl Fischer Titrator Data No. KF14V Water contents Ketones and Aldehydes - KF Volumetry, Direct-Injection Methyl ethyl ketone,Acetone, and Cyclohexanone 1.Abstract Water contents of ketones and aldehydes could be determined by Karl Fischer volumetric titrator. In volumetric titration, titrant have a factor whichis the capacity to react with water per 1 mL of titrant. Factor is pre-determined before sample measurement and water content of sample is calculatedfrom consumed titrant volume by sample measurement. When the sample is liquid, generally sample is measured by direct injection into the titration cell. Dehydrated methanol is generally used for titrationsolvent. However, in the measurement of ketones and aldehydes, since these react with methanol to produce water, the measurement result tends to behigher than the true value (formula (1)). R2CO+2CH3OH→R2C(OCH3)2+H2O·.·(1) For above reason, Karl Fischer reagent without methanol should be used for water determination of ketones and aldehydes. There are commerciallyavailable reagents with a special composition for ketones and aldehydes. This chapter introduces an example for the water determination in methylethyl ketone, acetone and cyclohexanone with water added to them to 1%. These samples are often used as paint solvents, raw materials of adhesives,and synthetic resins. 2. Apparatus and Reagents (1)Apparatus (2)Reagents Titrator:Hiranuma Karl Fischer Volumetric titrator AQV-seriesTitration cell:Standard CellTitrant:HYDRANAL Composite 5KTitration solvent:HYDRANAL Working Medium K 3.Procedure (1) Fill 50 mL of titration solvent into the titration cell as shown in Fig.3.1. (2) Start blanking to attain stable background. (3) Wash the syringe with sample. (4) Draw the sample into syringe and then weigh the syringe. (5) Inject sample from rubber septum of titration cell as shown in Fig.3.2. (6) Start titration. Measurement parameter is shown in Table 4.1. (7) Weigh the syringe again and then set the difference of weight to sample size. Fig.3.1 Preparation of the reagents Fig.3.2 Injection of sample 4. Parameters and results Table 4.1. Parameter. Condition File Cal Mode O:Sample weight(net) X=(H-b)xFx1000/SIZE Interval Time 30 sec Max Volume 20 mL Min Feed Vol. 0.01 mL S.Timer 0 min KF Factor 5.4839 mg/mL KF Buret No. 1 KF Speed(OUT) 12 mL/min KF Speed(IN) 24 mL/min Back Ground OFF Sample Size Input Every Time Blank Value 0 mL Unit Mode AUTO E.P Detection uA Solvent S,O,CE C.P Level 150 pA E.P Level 200 pA Auto Interval 0 g Table 4.2 Results of water content measurement in ketones 5.Note When the side reaction cannot be suppressed even though you use reagent for ketones, phenomena such as unstable blanking or undetectable endpoint can be (1) obtained. In that case, it may be improved by reducing the amount of sample or replacing titration solvent with new one. (2) Sampling tools should be dried up well before use. (3) Purge and fill the titrant to fill it homogeneously into the buret. Science fora better tomorrow飞热线电话:立科学仪器(北京)有限公司 本实验通过容量法对酮和醛的水含量进行测试。样品为液体时,通常通过直接注入滴定池来测量样品。
关闭
  • 1/3
  • 2/3
还剩1页未读,是否继续阅读?
继续免费阅读全文
产品配置单
日立科学仪器(北京)有限公司为您提供《甲乙酮、丙酮、环己酮中水分含量检测方案(卡氏水分测定)》,该方案主要用于酮中理化分析检测,参考标准《暂无》,《甲乙酮、丙酮、环己酮中水分含量检测方案(卡氏水分测定)》用到的仪器有卡尔费休水分仪AQV-2200A。
我要纠错
推荐专场
相关方案
