生物柴油中密度检测方案
检测样品
柴油
检测项目
密度
关联设备
共4种
下载方案
数字式密度计测定生物柴油的密度
使用日本京都电子公司(KEM)-数字式密度计(DA-510),
测定生物柴油密度的应用资料。
KMApplication Note NDAA-07033 Petroleum Density of Bio Diesel Fuel(BDF) Density measurement by Density/Specific Gravity Meter Standard JIS K 0061 1.Abstract This application note exemplifies a measurement of density of bio diesel fuel usingadensity/specific gravity meter made by Kyoto Electronics (KEM). 2.Reference 1)JIS K 0061-2001 Method for Density and Specific Gravity Measurement ofChemical Products 3.Cautions in measurement 1)Use a fresh desiccant (silica gel). If its color is reddish, change it with new one(blue). 2) Before sample measurement, perform factor calibration with dry air and purewater. 4.Post-measurement care Drain out residue inside the cell. Rinse well the measuring cell with solvent,and dryit completely. 5.Test equipment ain unit: Density/specific gravity meter 6.Reagent Rinse solvent (clean/dry): Ethanol (SOLMIX) 7.Measurement procedure -Pretreatment一 Set the temperature of density meter to 15°C, and leave it until stabilized. 2)Calibrate the meter with dry air and pure water. -Measurement- 1S)ample the test liquid using sampling pump. Use caution not to produce airbubbles in the cell. Start measurement. 23)After measurement, clean the cell with solvent, and dry it. 上海市漕溪路222号航天大厦北楼902室 9.Example of measurement -Ambient condition- Room temperature :24℃ Humidity 62 % Weather : Cloudy Measurement ParameterTemperature : 15.00℃Stability :0 Limit Time : 600 sSequence :Off Calib. : Air&Water Calculation Parameter Density :d Result :d Temp.Comp. :Off ***Res ult *** Sample No. 01-01 Date 2007/06/13 14:31 Method No. :1 Method Name : Method-1 Meas.Temp. :115.00℃ Period T :1077464 dlg/cm3] :0.88754 Meas.Time :00:03:30 Meaning of printout data: Meaning of printout data: Temperature: of measurement / Stability: level of stability of measurementLimit Time: of measurement / Sequence: built-in sequence /Calib.: calibration liquid《Calculation Parameter>Density: selection of density or specific gravity/ Result selection of measurement resultTemp.Comp.: setting temperature compensation 京都电子工业株式会社-可睦电子(上海)商贸有限公司 上海市漕溪路222号航天大厦北楼902室网址: http://kem.instrument. com.cn -Measurement resultsS-二 N Frequency Density.g/cm8) 1234 5 1077464 107746310774631077463 1077463 0.887540.887530.887530.88753 0.88753 The above data are the results of 5 tests of the same sample.*Red underline shows the data from page 3/4. 10.Summary Bio diesel fuel(BDF) is obtained by refining dehydrated (heated) waste cooking oils,however, trace amount of water may be blended. Sample measurement this time shows a good repeatability with 0.00001g/cm3maximum difference. Reliable measurement of density is assured using a density/specific gravity meter.Density of bio diesel fuel can be precisely measured by any of the following modelsmade by Kyoto Electronics (KEM). 【DA-520】 【DA-510】 【DA-505】 【DA-500】 · High end model · Built-in thermal control · Built-in thermal control · Built-in thermal control · Viscosity compensation 。Measure temp.:4~70℃Accuracy:±0.00002 g/cm · Viscosity compensation· Measure temp.:4~90℃·Accuracy:±0.00005g/cm³ · Built-in thermal controlMeasure temp.:4~90℃· Accuracy:±0.0001 g/cm ·Measure temp.:4~70℃ · Accuracy:±0.00002 g/cm KM KYOTO ELECTRONICSMANUFACTURING CO.,LTD. Overseas Division: Yamawaki Bldg 9F,4-8-21 Kudan-minami,Chiyoda-ku, Tokyo 102-0074JAPAN Phone:+81-3-3239-7333, Fax:+81-3-3237-0537 Head Office: 56-2 Ninodan-cho,Shinden,Kisshoin,Minami-ku, Kyoto 601-8317 JAPAN Phone:+81-75-691-4122, Fax:+81-75-691-9961 URL: http://www.kyoto-kem.com 京都电子工业株朱会社-可睦电子(上海)商贸有限公司 上海市漕溪路222号航天大厦北楼902室 电话:021-54488867 电邮: kemu-kem@163. com 网址: http://kem. instrument. com.cn 京都电子工业株朱会社-可睦电子(上海)商贸有限公司电话: 电邮: kemu-kem@ com网址: http://kem.instrument.com.cn 京都电子工业株式会社-可睦电子(上海)商贸有限公司电话: 电邮: kemu-kem@com网址: http://kem.instrument.com.cnDAA-Ver.
关闭
1/4
2/4
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《生物柴油中密度检测方案 》,该方案主要用于柴油中密度检测,参考标准《暂无》,《生物柴油中密度检测方案 》用到的仪器有DA-6XX+RA-6XX全自动密度计折光仪组合系统、DA-650高精度数字式密度仪/比重仪、DA-645数字式密度计/比重计、DA-640数字式全自动密度计。
我要纠错
